  2. Ingrijire si Intretinere
  3. Uleiuri, Lichide si Carburanti
  • MaxDDM
  • Mesaje scrise: 709
  • Masina: Corsa 2008 Z17DTR
  • Cont inregistrat: 10 Mar 2011
Dintre cele specificate de tine...pe care il recomanzi?
Tin sa precizez ca eu am schimbat odata uleiul in cutie si am pus GM dar nu prea sunt multumit de el.
Uite specificatiile de la Ravenol...
RAVENOL Getriebeoel TSG SAE 75W-90 is suitable for highly stressed manual transmissions (with and without synchronising), transfer cases and steering gearboxes in vehicles and work machines.
Quality Classifications:
Specifications:
API GL-4
Practice and tested in aggregates with filling:
PSA Standard B 71 2315, VW 501 50, Ford M2C-175, GM Opel B 040 104 3
Characteristics:
RAVENOL Getriebeoel TSG SAE 75W-90 offers:
• excellent ageing resistance
• extra high pressure absorption properties
• optimal viscosity-temperature properties
• excellent low temperature properties
• shearing stability
• stable lubricating film even under high stress
• extremely low pour point
• good elastomer compatibility to prevent leaks
Characteristics Unit Data Audit
Colour gelbbraun -
Density at 20°C kg/m³ 876 EN ISO 12185
Viscosity at 40°C mm²/s 76,3 DIN 51 562
Viscosity at 100°C mm²/s 14,2 DIN 51 562
Viscosity index VI 194 DIN ISO 2909
Pourpoint °C -42 DIN ISO 3016
All indicated data are approximate values and are subject to the commercial fluctuations.
Multumesc.
  • borsy
  • Mesaje scrise: 3,025
  • Masina: Insignia 2011 A20DT
Fuchs, Valvoline, LM, in ordinea asta. Cat despre 75w-90 de la Ravenol, daca era recomandat de ei pentru tipul tau de cutie, iti aparea pe site, asa mergi la risc.
  • MaxDDM
Ok....voi merge pe mana ta cu Fuchs...insa il pot gasi la orice magazin de piese auto?
Sau e necesar sa fac un research?
Multumesc.
  • borsy
Nu stiu daca se gaseste la fiecare magazin de piese auto, asa ca nu strica un research. Drumuri bune.
Fuchs Sinthofluid 75w-80, Opel 19 40 182, 19 40 757. 19 40 768, 19 40 767:
Viscosity, mm2/s @ 100 ºC. ASTM D-445 9,4
Viscosity, mm2/s @ 40 ºC. ASTM D-445 49.8
Viscosity Index ASTM D-2270 175
Pour Point, ºC ASTM D-5950 -48
Specific Gravity @ 15.6°C. ASTM D-4052 0,882
Flash Point, PMCC, ºC. ASTM D-93 190
Dynamic Viscozity -40°C. 37000 mPas
  • MaxDDM
Fuchs unde este fabricat?
  • borsy
Germania.
  • MaxDDM
Am gasit o firma care distribuie FUCHS...fratee e crima...costa 50 ron litrul.....pai la Ravenol; cumparam 2L cu pretul 56 Ron..nu stiu ce sa zic....ma mai gandesc....
  • borsy
Tu stii........dar sa nu ai probleme ulterior! Valvoline-ul cat e?
  • MaxDDM
Valvoline costa 40 Ron.
  • borsy
Baga unul din ele doua si nu te uita la 30 lei! Un ulei necorespunzator in cutie, te va face sa plangi ulterior.
  • MaxDDM
M-am gandit si la asta.
Nu mai stiu exact cat am dat pe GM data trecuta...era buna o comparatie...binenteles ca sunt adeptul calitatii in detrimentul pretului dar nici chiar asa Smile
  • borsy
Ideea e ca nu il schimbi in fiecare zi..........si daca tot ti-ai propus, macar sa folosesti ce trebuie, dar alegerea iti apartine.
  • MaxDDM
Borsy multumesc.
Raman la FUCHS.
Revin cu pareri dupa schimb.
  • MaxDDM
M-am interesat si la Ravenol...au si ulei pt cutie cu norma GM 19 40 182 ..se numeste Ravenol MTF-1 si e din gama profi...si ..suprizaaaaa...costa tot 50 Ron litrul.
  • MaxDDM
uite si specificatiile pentru el.
http://www.ravenolromania.r...-1-SAE-75W-85.pdf
RAVENOL MTF-1 SAE 75W-85 este un ulei de transmisie, full-sintetic , bazat pe poli-alpha-olefina, de vascozitate scazuta pentru transmisiile manuale, cutiile de transfer si cele diferentiale
RAVENOL MTF-1 SAE 75W-85 este creat din uleiuri de baza sintetice si supus unui tratament de aditivare controlat.
RAVENOL MTF-1 SAE 75W-85 este ideal pentru a fi folosit in conditii mecanice severe si stres termic si mareste intervalele de schimb al uleiului.
Aplicatii:
RAVENOL MTF-1 SAE 75W-85 este un ulei de transmisie de inalta calitate pentru transmisiile manuale, cutiile de transfer si cele diferentiale.
Specificatii:
API GL-5/Gl-4
Testate si Folosite in Motoarele:
General Motors 1940182, General Motors 93740319, Hyundai 04300-00110, Hyundai 04300-00140, Hyundai 08950-00020-B, Hyundai 08950-00020-A, MB 235.7, MB 235.4, Mitsubishi 3717610, MTF BOT 402 BOT 0063 für F35/MU3 5-Gang SAAB/GM/Opel, Nissan KLD26-75802, KE91699931, KE91699942, 999MP-MTF00P, OPEL B 040 2071, TOYOTA 08885-02606, TOYOTA 08885-81070, TOYOTA 08885-81060
Caracteristici : RAVENOL MTF-1 SAE 75W-85 ofera:
Stabilitate termica excelenta
Folosire usoara a transmisiei la temperaturi joase
Protectie foarte ridicata anti-rugina, anti-coroziune, anti- spumare
Punct de solidificare extrem de scazut
Proprietati excelente EP(presiune extrema)
Economie de combustibil
Prelungeste durata de functionare a transmisiei
Parametru Unitate de masura Valoare Metoda de testare
Culoare rosu
Densitate (la 15°C) kg/m3 876 EN ISO 12185
Punct de curgere °C -45 DIN ISO 3016
  • borsy
Daca iti ofera incredere mai multa Ravenol, foloseste-l pe asta.........nu imi place ca nu da prea multe detalii tehnice, dar.....
  • MaxDDM
Sincer Ravenol folosesc de vreo 6 schimburi incoace si sunt foarte multumit de aceasta marca.
Motorul e curat si nu consuma ulei deloc intre schimburi.
  • borsy
Stiu, fac uleiuri bune dar si Fuchs le fac la fel de bune! Inca odata, foloseste ce iti ofera o incredere mai mare in produs.
  • ionutknz
  • Cont inregistrat: 29 Mar 2016
Salut . la un opel astra h 2005 , 1.7 cdti z17DTH imi poate spune cineva cati litri de ulei intra in cutie ?
  • T.ion
  • Mesaje scrise: 3,454
  • Masina: Zafira 2001 Z16XE
Cele cu 5 trepte 1.75L
Cele cu 6 trepte 2.4L
