sovian
- Mesaje scrise: 79
- Masina: Astra 2005 Z17DTh
- Cont inregistrat: 17 Jun 2014
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- Mesaje scrise: 5,916
- Masina: Corsa 2001 Z12XE
sovian
- Mesaje scrise: 79
LFlorin
- Mesaje scrise: 4
- Cont inregistrat: 25 Jan 2017
Ma puteti ajuta cu aceste coduri de erori la un opel astra h 1.3 din 2006
B2740 - Front Fog Lights Switch Circuit Open or High Voltage
(05) - Present
B3899 - No Environment Identifier Learned
(00) - Intermittent
(05) - Present
P0500 - Wheel Speed Sensor Circuit Range/Performance
(71) - Not present
P0654 - Engine Speed Signal Range/Performance
(71) - Not present
P0550 - Mileage Circuit Range/Performance
(71) - Not present
P0460 - Fuel Level Sensor Circuit Range/Performance
(71) - Not present
U2117 - CAN-Bus No Communication with DIS (Display)
(00) - Not present
U2113 - CAN-Bus No Communication with SDM (Airbag)
(00) - Not present
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(00) - Not present
U2140 - CAN-Bus No Communication with UEC (Underhood Electrical Centre)
(00) - Not present
P0115 - Engine Coolant Temperature Signal Range/Performance
(71) - Not present
(05) - Present
(00) - Intermittent
(05) - Present
(71) - Not present
(71) - Not present
(71) - Not present
(71) - Not present
(00) - Not present
(00) - Not present
(00) - Not present
(00) - Not present
(71) - Not present
- iulian1971
- 7,081 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,081
- Masina: Astra 2008 Z19DTH
LFlorin
- Mesaje scrise: 4
LuvRaluK
- Mesaje scrise: 30
- Masina: Astra 2009 Z17DTJ
- Cont inregistrat: 13 Feb 2013
Salut tuturor.
Am si eu o problema la care nu ii dau de cap; am fost sa vad (pentru cumparare) o Opel Astra H break din 2009, motor 1.7 CDTI.
La testul cu pedale am gasit erorile:
54216 (la ultima cifra da, a clipit de 16 ori) - n-am gasit nici un fel de informatie despre eroarea asta!
0683 - Glow Dispozitiv de eroare generale B-016 (ceva bujie ?)
0409 - recirculare a gazelor de eºapament (EGR) (ceva probleme la valva EGR?)
0302 - cilindru 2 rateu Detectat (aici chiar n-am idee care ar fi baiul
Nu stiu daca am gasit bine informatia in legatura cu codurile, v-as ruga sa ma ajutati sa imi spuneti daca le-am identificat corect si daca sunt chestii minore de rezolvat sau ar costa cam mult.
Multumesc anticipat pentru ajutor.
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
LuvRaluK
- Mesaje scrise: 30
Incerc sa pun acum pe youtube filmarea, ca sa o puteti vedea.
https://youtube.com/watch?v=Cb38ZWI8IIM
(Please ignore audio )
- iulian1971
- 7,081 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
LuvRaluK
- Mesaje scrise: 30
LuvRaluK
- Mesaje scrise: 30
- vladutsss
- 969 mesaje
- din 23 Apr 2015
vladutsss
- Mesaje scrise: 969
- Cont inregistrat: 23 Apr 2015
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- vladutsss
- 969 mesaje
- din 23 Apr 2015
vladutsss
LuvRaluK
- Mesaje scrise: 30
Mersi de raspunsuri. Am intrebat un mecanic (amator) si mi-a zis ca bujiile se schimba si nu costa mult, si eroarea de filtru de particule si cea de EGR s-ar putea sa dispara la un drum de 50-100km pe autostrada (Cluj-Turda si retur) mers un pic mai turat (gen peste 3000 rpm). Sunt curios ...
De rateu pe cilindrul 2 n-a stiut sa imi zica nimic.
- max2005alin
- 4 mesaje
- din 08 Feb 2017
- Astra 2005
max2005alin
- Mesaje scrise: 4
- Cont inregistrat: 08 Feb 2017
- Bogdan101996
- 128 mesaje
- din 14 Aug 2015
- Astra 2005 Z13DTH
- Hunedoara
Bogdan101996
- Mesaje scrise: 128
- Masina: Astra 2005 Z13DTH
- Cont inregistrat: 14 Aug 2015
- max2005alin
- 4 mesaje
- din 08 Feb 2017
- Astra 2005
max2005alin
- Mesaje scrise: 4
- iulian1971
- 7,081 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
max2005alin a scris:Buna seara am si eu 6 coduri de erori
062101
062201
056003
007071
050074
038008
062101
062201
056003
007071
050074
038008
P0070 Ambient Air Temperature Sensor Malfunction - senzor temp. aer defect;
P0500 Vehicle Speed Signal Range/Performance - necorelare viteza roti;
P0621 Generator Lamp "L" Control Circuit Malfunction IPC (Instrument) - alternator defect sau incompatibil cu instalatia masinii;
P0622 Generator Field "F" Control Circuit Malfunction - alternator defect sau incompatibil cu instalatia masinii;
P0560 System Voltage Low Input - tensiune mica;
P0380 Glow Device Circuit Open Circuit - minim o bujie arsa.
