- gyzmo
- 3,753 mesaje
- din 01 Jun 2011
- Insignia 2009 A20DTJ
gyzmo
- Mesaje scrise: 3,753
- Cont inregistrat: 01 Jun 2011
De asta stiai?
Technical Service Bulletin 2626
Subject: Engine A20DTx - Glow plug with pressure sensor related failure codes
Only vehicles with C2 technology affected,e.g. glow plug with integrated pressure sensor.
Remedy
In case of customer complaint please reflash with latest software
available as of CW 40/2011 on TIS2Web.
Once the new software was applied please delete all DTC´s and
perform a driving cycle under full load for about 20 minutes and
check again for upcoming DTC´s. In case above mentioned DTC´s
are set again please refer to checking procedure in TIS2Web.
Please note I:
The checking procedure is currently under revision and
will not be updated before Q1/2012.
Please note II:
The new software will not activate the SVS light any longer
in terms of any malfunction from the glow plugs.
If the DTC´s are logged but there is NO! complaint mentioned by
the customer in terms of driving behaviour, e.g. loss of power,
jerking, etc. there is NO need to replace any parts,
especially not the glow plugs.
Remedy
Please note I:
Please note II:
cipriancv- Mesaje scrise: 38
- Masina: Insignia 2010 Y20DTH
- Cont inregistrat: 11 Sep 2015
Salutare.
Scuze pentru postare. Nu reusesc sa incep postare noua. Am cautat pe forum si nu am gasit.
Ma dispera apa care intra in tripla din dreapta.
A mai avut cineva aceasta problema?
Am dato jos de 3 ori si am bagat silicon pe la imbinari dar tot degeaba. Am pus chiar si pe langa montura becurilor dar degeaba.
Multumesc si scuze de postare.
- mihai.vlad
- 15 mesaje
- din 31 Mai 2013
- Insignia 2009 A20DTH
- Ilfov
mihai.vlad
- Mesaje scrise: 15
- Cont inregistrat: 31 Mai 2013
Salutare tuturor!
Am primit si eu SVS in bord. Testul spune ca bujia din clindrul 1 are probleme (eroare este P0671 - Cilindrul 1 circuit bujie intermitent).
Din pacate nici macar nu stiu ce fel de bujii sunt (cu senzor/fara). Am reusit sa fac totusi cateva poze, in urma cu putin timp, pe care le-am atasat.
Puteti, va rog, cei care sunteti patiti sa va dati cu parerea ce fel de bujii sunt?! Am inteles ca-s oarece diferente...intre cele 2 tipuri.
A ....si inca o intrebare : care-i cilindrul 1? dreapta sau stanga stand cu fata catre motor?
Multumesc
Multumesc
- clau70
- 3,337 mesaje
- din 11 Apr 2013
- Astra 2010 A20DTH
clau70
- Mesaje scrise: 3,337
- Masina: Astra 2010 A20DTH
- vsc84
- 107 mesaje
- din 17 Mai 2014
- Insignia 2009
vsc84
- Mesaje scrise: 107
- Cont inregistrat: 17 Mai 2014
Salutare! Am avut si eu svs acum 2-3 luni si mi s-a spus ca e bujia nr 3 cu probleme,am avut alte operațiuni mai costisitoare si prioritare de facut la masina si nu am schimbat bujiile nici acum, de 2-3 sãptãmâni,uneori,nu mereu,porneste putin mai greu,învârte o data in plus, sa fie de la bujia cu probleme!
- clau70
- 3,337 mesaje
- din 11 Apr 2013
- Astra 2010 A20DTH
clau70
- vsc84
- 107 mesaje
- din 17 Mai 2014
- Insignia 2009
vsc84
Asta mi s-a sput la diagnoza,apãruse svs a doua oara,erau si alte probleme atunci cauzate de regenerarea dpf-ului, pe care l-am anulat atunci,am ignorat bujia cu pricina, dar acum am sintomele menționate anterior si am facut o legatura cu bujia sau problema e alta!
Mentionez ca nu am mai avut nici un svs de atunci! Din fericire!
- clau70
- 3,337 mesaje
- din 11 Apr 2013
- Astra 2010 A20DTH
clau70
- vsc84
- 107 mesaje
- din 17 Mai 2014
- Insignia 2009
vsc84
adykyr
- Mesaje scrise: 6
- Cont inregistrat: 07 Jun 2016
- gyzmo
- 3,753 mesaje
- din 01 Jun 2011
gyzmo
- iulius
- 1,798 mesaje
- din 09 Jun 2004
- Insignia 2019
iulius
- Mesaje scrise: 1,798
- Masina: Insignia 2019
- canguru
- 850 mesaje
- din 11 Jul 2014
- Insignia 2011 A20DT LBR
canguru
- Mesaje scrise: 850
- Masina: Insignia 2011 A20DT LBR
- Cont inregistrat: 11 Jul 2014
- Avram Adrian
- 654 mesaje
- din 15 Sep 2007
- Insignia 2010
Avram Adrian
- Mesaje scrise: 654
- Cont inregistrat: 15 Sep 2007
- canguru
- 850 mesaje
- din 11 Jul 2014
canguru
adykyr
- Mesaje scrise: 6
gyzmo a scris:Daca ai bujii cu sensor de presiune poate fi de la ele...
Mai exact, care sunt codurile de eroare?
Nu stiu exact care era codul erorii dar mi au zis la tester ca am eroare la bujiile2 3 si ca sunt bujii cu senzori 500ron bucata.posibil ca mersul nergulat al motorului doar la pornire la plecarea de pe loc sa fie cauzat de aceste bujii?
robertexe
- Mesaje scrise: 86
- Masina: Insignia 2010 A20TDH
- Cont inregistrat: 22 Apr 2015
adykyr
- Mesaje scrise: 6
