- litian28
- 213 mesaje
- din 21 Nov 2008
- Astra 2019 B14XFL
- Mehedinti
litian28
- Mesaje scrise: 213
- Masina: Astra 2019 B14XFL
- Cont inregistrat: 21 Nov 2008
FVoda
- Mesaje scrise: 42
- Cont inregistrat: 01 Mar 2019
Se pare ca pentru LED semnalizare spate e multa munca ca sa fie treaba "ca la carte":
https://www.astrakforums.co....wtopic.php?t=5679
zamaraii
- Mesaje scrise: 86
- Masina: Astra 2016 B14XFL
- Cont inregistrat: 05 Sep 2012
@Clanda
"Hi all,
So 'Service ESC' stands for 'Service/Repair Electronic Stability Control'. It's telling you there is a fault with the Electronic Stability Control. It's a vehicle module monitored issue that tracks whether a problem with the car is potentially causing an issue with the car skidding on ice/water. It will trigger in normal conditions if there is a fault with the engine resulting in a loss of power or torque. 9 times out of 10 it's the ignition coil in a petrol engine but with the turbocharged Astra's a larger proportion of issues relate to piston failure due to Low Speed Pre-Ignition.
Book in at a dealer if you have ever had this on the dashboard."
https://www.astrakforums.co....4208&start=10
Se pare ca e problema veche pe forumul din UK. La noi nu prea sunt multi cu problema asta. Poate te ajuta cineva daca a mai intalnit problema. Oricum mai bine intrebi la dealer.
"Hi all,
- litian28
- 213 mesaje
- din 21 Nov 2008
- Astra 2019 B14XFL
- Mehedinti
litian28
FVoda a scris:Se pare ca pentru LED semnalizare spate e multa munca ca sa fie treaba "ca la carte":
Ai dreptate colegule!Timp, indemanare si ceva nervi sa faci lucrarea ca la carte!Nu stiu cat merita dar acum depinde de fiecare.Eu o sa incep cu interiorul, dupa care cu semnalizarile laterale, portbagajul si lampile la numar.
- litian28
- 213 mesaje
- din 21 Nov 2008
- Astra 2019 B14XFL
- Mehedinti
litian28
- litian28
- 213 mesaje
- din 21 Nov 2008
- Astra 2019 B14XFL
- Mehedinti
litian28
In final am rezolvat si cu led-urile la interior.In foto aprinsa doar plafoniera spate si cea de pe fata fara luminile de citit.In masina zici ca e ziua.Am pus led canbus dar cred ca merge si fara,In portbagaj are cineva 2 lampi deoarece cred ca una nu prea ajunge datorita unghiului de reflexie al led-ului w5w?!
- mariocb
- 1,054 mesaje
- din 14 Jun 2016
- Astra 2016 1,4 XFT
- Braila
mariocb
- Mesaje scrise: 1,054
- Masina: Astra 2016 1,4 XFT
- Cont inregistrat: 14 Jun 2016
Este un coleg care are 2 lampi in portbagaj ( gasesti pe sectiunea asta, cateva pagini in urma )....e de ajuns si o singura lampa, insa ai nevoie de un led cu smd-uri pe o singura parte .. ceva de genul: https://www.google.ro/url?sa...=1570823453962360 .
FVoda
- Mesaje scrise: 42
Mi-am pus eu 2 lãmpi în portbagaj, sunt cu led uri pe o parte.. Am fost la electrician sa îmi tragã firele prin spate.
@litian 28, la tine se aude vreun bâzâit de la LED uri, la plafoniera fata și spate inainte sa se stingã?
La mine e destul de enervant acel bâzâit și ma gândeam sa le schimb dar nu știu dacã va face la fel. Ce fel de LED uri ai pus?
Mersi
Mersi
- litian28
- 213 mesaje
- din 21 Nov 2008
- Astra 2019 B14XFL
- Mehedinti
litian28
FVoda
- Mesaje scrise: 42
- litian28
- 213 mesaje
- din 21 Nov 2008
- Astra 2019 B14XFL
- Mehedinti
litian28
- mariocb
- 1,054 mesaje
- din 14 Jun 2016
- Braila
mariocb
A fost actualizat configuratorul pe pagina Opel Romania ....intrati si "savurati" preturile facelifturilor Opel Astra K. https://www.opel.ro/tools/configurator.html
- wanchope
- 240 mesaje
- din 02 Jul 2012
- Astra 2016 B14XFT
wanchope
- Mesaje scrise: 240
- Masina: Astra 2016 B14XFT
- Cont inregistrat: 02 Jul 2012
- litian28
- 213 mesaje
- din 21 Nov 2008
- Astra 2019 B14XFL
- Mehedinti
litian28
- mariocb
- 1,054 mesaje
- din 14 Jun 2016
- Braila
mariocb
- litian28
- 213 mesaje
- din 21 Nov 2008
- Astra 2019 B14XFL
- Mehedinti
litian28
- canan17ro
- 132 mesaje
- din 05 Feb 2005
- Astra 2018 16SHT
canan17ro
- Mesaje scrise: 132
- Masina: Astra 2018 16SHT
- Cont inregistrat: 05 Feb 2005
wanchope a scris:@mariocb: preturile au crescut binisor dar cel mai mult "imi place" c-au inlocuit toate motoarele: sunt numai motoare in 3 cilindri, fie diesel, fie benzina. Iar motoarele pe benzina de 1.2 made by Peugeot sunt o "minune" a tehnicii. In aceste conditii eu unul spun adio acestei marci. Pacat!
Niciunul dintre motoarele de la facelift nu este de la Peugeot. Vezi de exemplu aici, dar si in alte parti.
- wanchope
- 240 mesaje
- din 02 Jul 2012
- Astra 2016 B14XFT
wanchope
akim
- Mesaje scrise: 30
- Cont inregistrat: 01 Jan 2009
- mariocb
- 1,054 mesaje
- din 14 Jun 2016
- Braila
mariocb
Pãi a vandut GM-ul sau nu Opelul la PSA ?! Nu are cum sa fie motoare GM, in cel mai fericit caz ar putea fi creatie proprie Opel ,dezvoltate la Russelsheim, desi ma indoiesc...mai mult ca sigur sunt de sorginte PSA.
https://superspeed.tv/opel-a...voarea-celor-psa/
