  • sovian
  • Mesaje scrise: 79
  • Masina: Astra 2005 Z17DTh
  • Cont inregistrat: 17 Jun 2014
Am un cod de eroare: ECN 56003, nu gasesc detalii. A mai patit cineva ?
  • catastefan
  • Mesaje scrise: 5,916
  • Masina: Corsa 2001 Z12XE
Presupun ca e Astra G...pentru ca Astra H nu are eroarea asta
P0560 Reduced Rail Pressure, due to Low Battery Voltage
P0560 System Voltage Low Input
P0560 System Voltage High Input
Verifica bateria si incarcarea
  • sovian
  • Mesaje scrise: 79
A fost descarcata la primul frig, acum e ok porneste din prima . Astra h
  • LFlorin
  • Cont inregistrat: 25 Jan 2017
Ma puteti ajuta cu aceste coduri de erori la un opel astra h 1.3 din 2006
B2740 - Front Fog Lights Switch Circuit Open or High Voltage
(05) - Present
B3899 - No Environment Identifier Learned
(00) - Intermittent
(05) - Present
P0500 - Wheel Speed Sensor Circuit Range/Performance
(71) - Not present
P0654 - Engine Speed Signal Range/Performance
(71) - Not present
P0550 - Mileage Circuit Range/Performance
(71) - Not present
P0460 - Fuel Level Sensor Circuit Range/Performance
(71) - Not present
U2117 - CAN-Bus No Communication with DIS (Display)
(00) - Not present
U2113 - CAN-Bus No Communication with SDM (Airbag)
(00) - Not present
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(00) - Not present
U2140 - CAN-Bus No Communication with UEC (Underhood Electrical Centre)
(00) - Not present
P0115 - Engine Coolant Temperature Signal Range/Performance
(71) - Not present
  • Mesaje scrise: 7,081
  • Masina: Astra 2008 Z19DTH
Aparent erorile nu sunt prezente, cu exceptia proiectoarelor si a ceasurilor de bord care au fost "masluite".
Sterge-le si vezi ce apare din nou.
  • LFlorin
mersi
  • LuvRaluK
  • Mesaje scrise: 30
  • Masina: Astra 2009 Z17DTJ
  • Cont inregistrat: 13 Feb 2013
Salut tuturor.
Am si eu o problema la care nu ii dau de cap; am fost sa vad (pentru cumparare) o Opel Astra H break din 2009, motor 1.7 CDTI.
La testul cu pedale am gasit erorile:
54216 (la ultima cifra da, a clipit de 16 ori) - n-am gasit nici un fel de informatie despre eroarea asta!
0683 - Glow Dispozitiv de eroare generale B-016 (ceva bujie ?)
0409 - recirculare a gazelor de eºapament (EGR) (ceva probleme la valva EGR?)
0302 - cilindru 2 rateu Detectat (aici chiar n-am idee care ar fi baiul
Nu stiu daca am gasit bine informatia in legatura cu codurile, v-as ruga sa ma ajutati sa imi spuneti daca le-am identificat corect si daca sunt chestii minore de rezolvat sau ar costa cam mult.
Multumesc anticipat pentru ajutor.
  • catastefan
La Astra H la testul cu pedalele nu clipeste martorul....erorile le afizeaza pe ecranul mic de la km
  • LuvRaluK
  • Mesaje scrise: 30
Incerc sa pun acum pe youtube filmarea, ca sa o puteti vedea.
https://youtube.com/watch?v=Cb38ZWI8IIM
(Please ignore audio Very Happy)
Ai pus reflectorul pe display si nu se vede nimic.
Noteaza codurile care apar sub ECN. Primele 4 cifre mai exact.
  • LuvRaluK
  • Mesaje scrise: 30
Am inteles, imi cer scuze dar sincer nici nu mi-a trecut prin cap sa ma uit la display-ul respectiv.
Deocamdata nu mai am acces la masina respectiva, deoarece e una din masinile pe care le-am vazut in vederea cumpararii. Voi incerca sa o vad din nou luni si o sa ma uit exact la display atunci.
  • LuvRaluK
  • Mesaje scrise: 30
Am revenit.
Erorile sunt: ECN068302, ECN030204, ECN242F66 si ECN040952.
Multumesc anticipat pentru raspunsuri.
  • vladutsss
  • Mesaje scrise: 969
  • Cont inregistrat: 23 Apr 2015
bujii, EGR, filtru de particule si cum zice colegul mai jos
Ultima modificare facuta de vladutsss la Lun 06 Feb, 2017 7:16 pm
  • catastefan
Senzor arbore cotit? Mai degraba rateuri pe cilindru 2
  • vladutsss
Mersi, am citit rau cand am cautat eroarea.
  • LuvRaluK
  • Mesaje scrise: 30
Mersi de raspunsuri. Am intrebat un mecanic (amator) si mi-a zis ca bujiile se schimba si nu costa mult, si eroarea de filtru de particule si cea de EGR s-ar putea sa dispara la un drum de 50-100km pe autostrada (Cluj-Turda si retur) mers un pic mai turat (gen peste 3000 rpm). Sunt curios ...
De rateu pe cilindrul 2 n-a stiut sa imi zica nimic.
  • max2005alin
  • Cont inregistrat: 08 Feb 2017
Buna seara am si eu 6 coduri de erori
062101
062201
056003
007071
050074
038008
Menționez in termen de un an și jumãtate am schimbat de doua ori alternatorul
Mulțumesc anticipat
O seara plãcutã
  • Bogdan101996
  • Mesaje scrise: 128
  • Masina: Astra 2005 Z13DTH
  • Cont inregistrat: 14 Aug 2015
Ce motorizare ai?
  • max2005alin
opel astra 2005 1.7 cdti
max2005alin a scris:Buna seara am si eu 6 coduri de erori
062101
062201
056003
007071
050074
038008
P0070 Ambient Air Temperature Sensor Malfunction - senzor temp. aer defect;
P0500 Vehicle Speed Signal Range/Performance - necorelare viteza roti;
P0621 Generator Lamp "L" Control Circuit Malfunction IPC (Instrument) - alternator defect sau incompatibil cu instalatia masinii;
P0622 Generator Field "F" Control Circuit Malfunction - alternator defect sau incompatibil cu instalatia masinii;
P0560 System Voltage Low Input - tensiune mica;
P0380 Glow Device Circuit Open Circuit - minim o bujie arsa.
