- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
- Mesaje scrise: 337
- Masina: Astra 2005 Z16XEP
- Cont inregistrat: 17 Feb 2013
Nu s-a sters sigur,probabil ca ai mai multe memorate dar Not Present.Oricum daca ai erori memorate e simplu sa-ti dai seama...cand masina e OK si nu are erori (prezente sau memorate) la cateva secunde dupa ce ai pus contactul si s-au stins martorii de pornire se stinge si masina cu cheita.Daca in schimb se va stinge doar DUPA ce ai pornit motorul atunci ai erori stocate (probabil nu si prezente).
dre
- Mesaje scrise: 28
- Masina: Astra 2006 idh17
- Cont inregistrat: 28 Apr 2007
Salut, la un Opel astra h 1.6 xep mi-au apãrut niște coduri de eroare dupã ce a fost implicat într-un accident. Cel de la service ori e lemn ori a vrut sa pãcãleascã proprietarul și i-a dat mașina asa cu martorul cheita în bord aprins..
Ce înseamnã urmãtoarele coduri?
Ecn 130000
Ecn 111606
Ecn 111505
Ecn 053003
Ecn 130000
Ecn 111606
Ecn 111505
Ecn 053003
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
P1300
Misfire Detected at Low Fuel Level
5 s elapsed time since engine start
Battery voltage between 9 V and 16 V
Coolant temperature between -40 °C (-40 °F) and 118 °C (244 °F)
Engine running in engine speed range 500 rpm to 6500 rpm
Too many misfires detected by the crankshaft position sensor
Note:
This trouble code is only stored after longer engine operation under different operating conditions
P0530
A/C Pressure Sensor Circuit High Input
The control unit recognises the malfunction of the circuit via an internal evaluation logic
P1115
Radiator Outlet Coolant Temperature Sensor Circuit Open or Low Voltage
10 s elapsed time since engine start
Coolant temperature is greater than 134.75 °C (273.20 °F)
P1116
Coolant Thermostat Valve Circuit Low (High)Voltage
Final stage diagnosis in control unit
(Short circuit to ground or circuit interruption/low ;Short circuit to voltage/high)
P1300 se va sterge(cu op-com) dupa remedierea defectului...P0530 la fel
Problema pare a fi la senzorul termostatului (P1115) care cred ca trebuie shimbat...de aici apare si eroarea P1116-termostatul lucreaza necorespunzator....si de aici si masina cu cheita.Daca nu se remediaza cu schimbarea senzorului atunci e defecta si supapa controlata de calculator ce se afla in termostat (P1116).Oricum trebuie luate pe rand...prima data vezi de ce nu lucreaza senzorul (inlocuit daca-i defect) apoi stergi toate erorile si vezi daca mai apare supraincalzirea apei in radiator (P1116)....atunci inlocuiesti termostatul....Ai grija la temperaturi sa nu arzi garnitura de chiuloasa ca atunci e mai grav.
Note:
P0530
P1115
P1116
dre
- Mesaje scrise: 28
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
dre
- Mesaje scrise: 28
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
B7866
- Mesaje scrise: 67
- Masina: GT 2006
- Cont inregistrat: 23 Aug 2018
- iulian1971
- 7,081 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,081
- Masina: Astra 2008 Z19DTH
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
P1614 - Wrong Transponder Key -Si mie-mi apare periodic...o sterg cu op-com si dupa un timp apare iar.Am crezut ca-i bateria slaba la telecomanda dar si dupa ce am schimbat bateria mi-a mai aparut.Ce-i nasol e ca atata timp cat o am stocata si nestearsa nu se mai stinge masina cu cheita cand se sting toti martorii ci numai dupa pornirea motorului si nu-mi prea place asta dar influenta la functionarea masinii nu are deloc
danypop
- Mesaje scrise: 46
- Masina: Astra 2007 Z13DTH
- Cont inregistrat: 03 Jun 2017
Buon,am fãcut și eu testul pedalelor dupã ce am tot meșterit una alta pe la mașinã timp de vreo douã sãptãmâni,tot am luat și pus bateria pe mașinã, uneori am rãmas și fãrã curent. In fine, e vorba de Astra h gtc 1.3cdti 2007 189700km. Așa,am urmãtoarele erori: ECN 068304
161450
119103
161900
162562
224408
210870
011005
013001
226408
119167
161450
119103
161900
162562
224408
210870
011005
013001
226408
119167
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
In primul rand nu lasa niciodata masina fara curent...daca ai nevoie de spatiu si trebuie sa dai bateria jos alimentezi masina punand o baterie baterie de amperaj mai mic (44A) la picioarele scaun pasager si alimentand masina prin mufa brichetei (2 cleme,2 buc cablu si mufa care intra la bricheta...simplu).In continuare.... ai coduri de eroare gramada ...ai resetat inclusiv CIM-ul ca ai P1614 -wrong transporder key.Nu ai scris daca a pornit masina.Oricum trebuie sa cauti pe cineva cu op-com sau Tech 2...stergi toate erorile...pornesti motorul (daca porneste-daca nu fa-i programare la cheie cu op-comul)...deci pornesti ...opresti,si citesti iar erorile Ai aici si toate codurile daca vrei
https://www.clubopel.com/viewtopic.php?t=8087
spor
spor
danypop
- Mesaje scrise: 46
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
danypop
- Mesaje scrise: 46
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
- MMaryus984
- 1 mesaje
- din 06 Sep 2018
MMaryus984
- Mesaje scrise: 1
- Cont inregistrat: 06 Sep 2018
danypop
- Mesaje scrise: 46
- iulian1971
- 7,081 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
@MMaryus984
P1614 Wrong Transponder Key - CIM cu probleme;
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) - sonda lambda 2;
P0420 Catalyst System Efficiency Below Threshold (Bank 1) - catalizator spart/infundat;
P0621 Generator Lamp "L" Control Circuit Malfunction - alternator defect.
@danypop
P0683 - minim o bujie arsa.
@danypop
danypop
- Mesaje scrise: 46
