  • thirteen
  • Mesaje scrise: 337
  • Masina: Astra 2005 Z16XEP
  • Cont inregistrat: 17 Feb 2013
P1483
Fan Control 3 Circuit High Voltage
Final stage diagnosis in control unit
(Short circuit to voltage)
P2108 – Throttle actuator control (TAC) module – performance problem
P0500
Vehicle Speed Signal Range/Performance
The control unit recognises the malfunction of the circuit via an internal evaluation logic.
P1604
REPLACE
ECU
• The control unit cannot store the learned values and adjustments in the EEPROM
• The fault is immediately recognised with ignition ON.
Effect:
• The system telltale is switched on.
• The EEPROM configuration number read by the control unit is not correct
Effect:
• The engine does not start.
P1125
Throttle Actuator Feedback Signal Range/Performance
Signal lead indicates an implausible value.
Above condition must be fulfilled for at least 0.3 - 4 s .
P1278 - Accelerator Pedal Position Sensor 1 Circuit High Voltage
Le poti traduce pe fiecare cu google translate dar in principal e defect ECU si trebuie inlocuit...restul erorilor (pedala de acceleratie,senzor de viteza...) sunt adiacente si decurg din eroarea principala P1604 - Inlocuire ECU.
  • IRoberto102
  • Cont inregistrat: 19 Oct 2019
Daca este defect nu porneste deloc ? Mie nu mi porneste masina deloc
  • thirteen
Nu trebuie ECU nou ...e bun si unul din dezmembrari dar sa fie de pe o masina la fel (astra h 1.7 101 cp) si cineva priceput ca sa-l inlocuiasca. cauta aici https://www.clubopel.com/rez...+ECU&sa=Cauta
  • thirteen
Scrie clar,,,"The engine does not start."
  • thirteen
Poti incerca cu un op-com "reset ECU" ...nu tu...cineva care se pricepe...slabe sanse dar ...maybe look.
  • IRoberto102
Poate sa fie o eroare mai veche care nu s a sters ? Adica totul a inceput de la o simpla curatare de egr..
  • thirteen
Nu cred ,Erorile cu ce le-ai citit? op com ? incearca testul cu pedale si vezi care-i prima....ECN...daca-i ECN 160400 ...asta-i ECU .Fa reset prima data..who knows.
  • IRoberto102
148304 e prima.. cum fac reset ? Nu stiu mai nimic despre mecanica sau chestii de genul
  • IRoberto102
De fapt 062101 e prima si da am facut cu testul pedalelor
  • thirteen
Esti figura mare ...P0621 nici nu l-ai mentionat anterior...cauta ia electromotor si alternator e unfir sectionat sau altceva,,,oricum astea 2 .Cum vrei sa te ajute cineva cu informatii eronate?
  • thirteen
I"m out
  • lobea
  • Mesaje scrise: 21
  • Masina: Astra 2006 Z16XEP
  • Cont inregistrat: 06 Jan 2017
Salutare!ma ajuta si pe mine cineva cu un cod de eroare ce semnifica?cod eroare 13055!opel astra h 1.6 benzina twinport! Multumesc!
  • lobea
  • Mesaje scrise: 21
  • thirteen
Banuiesc ca e ECN 013055 Nu? codul ECN e din 6 cifre primele 4 sunt codul P0130 sonda lambda 1 defecta Este pozitionata pe evacuare inainte de catalizator si se vede cum deschizi capota
http://www.youtube.com/watch?v=9nA3Us8hk24
  • lobea
  • Mesaje scrise: 21
Da!se poate sa fi ramas codul de eroare memorat?am scos mufa de la sonda lambda si am dat cu spray de contact! Multumesc de raspuns!
  • catastefan
  • Mesaje scrise: 5,916
  • Masina: Corsa 2001 Z12XE
Daca aveai contactul pus...da de acolo a aparut eroarea...Daca contactul nu era pus nu e de acolo
  • lobea
  • Mesaje scrise: 21
Salut catastefan!Felul sta in felul urmator:La rece cand o accelerez in relanti are un moment de ezitare ca si cum ar da in nas,citeodata mai da si rateuri,pana se incalzeste dupa nu mai da in nas!
  • lobea
  • Mesaje scrise: 21
Si pornirea mai greoaie la rece,mentionez faptul ca masina e si pe gpl!
  • thirteen
Nu iti apare si P0135 ?
  • lobea
  • Mesaje scrise: 21
Da mi a pare codul,dar mi a spus cineva sa dau cu spray de contact la mufa de la sonda lambda ca se mai oxideaza pinii si de acolo ar putea veni acest "dat in nas"!Am scos si mufa in timpul functionarii motorului!Testul l am facut cu pedalele(acceleratie,frana).Inainte de a scoate mufa nu imi dadea nici un cod de eroare!Multumesc!
