- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- Mesaje scrise: 5,916
- Masina: Corsa 2001 Z12XE
Cojocel
- Mesaje scrise: 12
- Masina: Astra 2004 Z17DTL
- Cont inregistrat: 17 Feb 2016
- andrei.marca
- 2 mesaje
- din 13 Oct 2016
- Corsa 2011 A13DTE
andrei.marca
- Mesaje scrise: 2
- Masina: Corsa 2011 A13DTE
- Cont inregistrat: 13 Oct 2016
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
trasor
- Mesaje scrise: 4
- Masina: Astra 2011
- Cont inregistrat: 08 Jul 2011
Zahadum
- Mesaje scrise: 20
- Masina: Astra 2005 Z17DTL
- Cont inregistrat: 24 Jun 2016
Salut Trasor
Numar sasiu W0LPC6DG3CG020639
Cod model 0PC68
Caroserie C68
Cod pachet JH61
An model 2012 (A)
Data fabricatie 26.09.2011
Prima inmatriculare 15.12.2011
Cod motor LPV
Cod cutie de viteze MZ4
Tip motor A17DTR (A17DTJ)
Serie motor 2307595
Cod culoare GAZ (40R)
Tapiþerie TACW
Caracteristicã Denumire
01A TRIM COLOR SEAT JET BLACK
1AB TRIM COLOR DR PANEL JET BLACK
2BP MOLDING DOOR INTR DK PEARL
4AA INTERIOR TRIM JET BLACK
A51 SEAT FRONT
A64 SEAT RR SPLIT, FOLDING, 40/60
A69 RESTRAINT SEAT BELT TENSIONER
AEF POW. WINDOWS PASS,EXPR,UP/DOWN
AFA INTERIOR TRIM CONFIG #1
AG5 SEAT ADJ, R, MANUAL 2 WAY
AH3 ADJ. FRT ST, MAN,4 WAY, DRIVER
AHN RESTRAINT PROVISIONS LATCH
AJC RESTRAINT HEAD, FRT SEAT, UP/D
AJG AIRBAG,DR&CODR,FRT&SIDE,SINGLE
AKN WINDOW TYPE TINTED
AKW WINDSHIELD TYPE TINTED
AQP REAR CENTER HEADREST
AWO RESTR.SYS.RR SEAT BELT,3P CENT
AXG ELECTRIC WINDOW - ONE TOUCH
AXJ VEHICLE TYPE PASSENGER CAR
B75 COVER LUGGAGE COMPARTMENT
C1R ORNAMENT. INTR I/P ,JETBLACK
C25 WASHER + WIPER-BACK WINDOW
C67 AIR CONDITIONING
C95 LAMP INTR, RF, DUAL READING
C99 PASSENGER AIRBAG,MANUAL CUTOFF
CR7 HUNGARY-MANDATORY
D31 MIRROR IS/RV, TILT
D75 HANDLE O/S, DR, COLORED
DLU MIRROR I/S,SUNSHADE,DR W/O MIR
DP6 MIRROR HOUSING, PAINTED
DT4 ASHTRAY - LIGHTER
DVA INST. BLACK,BLACK/SILVER RINGS
DWE MIRROR L+R,RC,ELEC,HEAT,MANFOL
EBW TRIM CLOTH, CORDOBA
FBD TRIM DOOR CLOTH, ATLANTIS
FX3 VEH. STABILIZING SYSTEM (ESP)
FXB AXLE RATIO, FINAL DRIVE 3.65
GAZ SUMMIT WHITE (was OLYMPIC WHT)
GNA CHASSIS EQUIP FRONT STRUT ASM
GNG CHASS. EQUIP,RR AXLE,WATT LINK
J60 ABS 16",FRT & RR DISC, POWER
K3S BATTERY, 12V, 75AH, 720 CCA
K60 ALTERNATOR-100 A
KCL HEATER DUCT, RR (2ND POSN)
LHD LEFT HAND DRIVE
LPV ENG-4 CYL 17L,DIESEL,TURBO,HO
MDB MOLDING B/S UPPER BLACK
MM3 TRANS-MAN, MERCHANDISED EQUIP.
MZ4 TRANS-MAN, 6-SPEED, M32 WR
N37 MAN.TILT TELESCOPING STEERING
N45 STEERING WHEEL-3 SPOKES
NE9 EMISSION-SYSTEM EEC 09
NJ1 POWER STEER,NON VARIA.RATIO,EL
OEX PLUS PACK 1 (ESSENTIA BASED)
OHI MODEL UPGRADE 10
PWM WHEEL 16x6.5, STEEL, DESIGN 2
QZQ TIRES 215/60R16-95HBWR/STTLHW3
RU5 SPAREWHEEL,16X4.0,J,STEEL,DES1
T39 TURN SIGNAL LAMPS
T3N DAYT. RUNNING LAMPS,SEP CAVITY
T3Z DAYT. RUNNING, SEP. INCANDESC.
T4A HEADLAMPS HALOGEN
T79 FOG LAMP, REAR
TACW CORDOBA JET BLACK
TR6 HEADLAMPS-LEVELLING, MAN
TS6 STOPLAMP, CENTER, HIGH MOUNTED
TTX RADIO EQUIPMENT AUX CONNECTOR
U04 HORN SINGLE NOTE
U18 SPEEDOM. KM
U91 ANTENNA SHORT, ROOF, RADIO
UDB INFO DISPLAY SEGMENTED
UFD DISPLAY TIME,EXT TEMP, RADIO
UH0 INDICATOR SEAT BELT WARNING,LH
ULS LOCK CONTROL STEERING COLUMN
UW4 4 LOUDSPEAKERS, CUSTOM
UYB RADIO,CDROM,CAF,RSA GME/ME/TAI
V2O PAN. CTR ONE LAYER PAINT PEARL
V48 COOLANT - MAXIMUM PROTECTION
V83 VEHICLE STATEMENT ECE ORG
VD1 PROVISION OPTIONS EUROPE
VG9 EXTERIOR WAX PROTECTION
VRG V.A. ASM COCKPIT
VRH V.A. ASM STEERING COLUMN
VRK V.A. ASM ROOF TRIM
VRL V.A. ASM FRONT HORIZONTAL SUSP
VRM V.A. ASM FRONT VERTICAL SUSPEN
VRN V.A. ASM REAR SUSPENSION
VRR V.A. ASM TIRES & WHEELS
W4Y GEARING CODE
WGA EQUIP. RECEIVING UNIT, RADIO
XL8 FREQUENCIES 433 MHZ
Cod model 0PC68
Caroserie C68
Cod pachet JH61
An model 2012 (A)
Cod motor LPV
Serie motor 2307595
Tapiþerie TACW
A51 SEAT FRONT
LHD LEFT HAND DRIVE
T79 FOG LAMP, REAR
U18 SPEEDOM. KM
W4Y GEARING CODE
- taxi43edy
- 1,208 mesaje
- din 23 Apr 2009
- Zafira 2001 Z18XE
taxi43edy
- Mesaje scrise: 1,208
- Masina: Zafira 2001 Z18XE
- Cont inregistrat: 23 Apr 2009
- andrei.marca
- 2 mesaje
- din 13 Oct 2016
- Corsa 2011 A13DTE
andrei.marca
- Mesaje scrise: 2
daurel
- Mesaje scrise: 3
- Masina: Astra 2010 A17DTR
- Cont inregistrat: 16 Oct 2016
- luciferus4ever
- 2 mesaje
- din 01 Aug 2016
- Astra 2011
- Dambovita
luciferus4ever
- Mesaje scrise: 2
- Cont inregistrat: 01 Aug 2016
daurel
- Mesaje scrise: 3
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
c0rsar
- Mesaje scrise: 63
- Cont inregistrat: 22 Dec 2014
Aflare dupa VIN dotarile de fabrica ale masinii. Se da click in dreapta pe pictograma cu masina.
Deasemenea dand click pe modelul masinii dupa introducere VIN se poate afla codul original la aproape orice piesa.
http://www.catcar.info/opel/?lang=en
P.S. Page Up la http://www.catcar.info/ pentru alte marci.
sfinx
- Mesaje scrise: 63
- Masina: Vectra 2008 z22yh
- Cont inregistrat: 10 Dec 2008
ady2dan
- Mesaje scrise: 7
- Cont inregistrat: 01 Mar 2015
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- adelyn2712
- 4 mesaje
- din 10 Nov 2014
- Insignia 2010 A18XER
- Arges
adelyn2712
- Mesaje scrise: 4
- Masina: Insignia 2010 A18XER
- Cont inregistrat: 10 Nov 2014
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- adelyn2712
- 4 mesaje
- din 10 Nov 2014
- Arges
adelyn2712
- Mesaje scrise: 4
- taxi43edy
- 1,208 mesaje
- din 23 Apr 2009
- Zafira 2001 Z18XE
taxi43edy
