Schnupe
- Mesaje scrise: 19
- Masina: Insignia 2011 A20DTH
- Cont inregistrat: 16 Mai 2016
- dragosh84
- 163 mesaje
- din 02 Jun 2011
- Astra 2002 Z16XE
dragosh84
- Mesaje scrise: 163
- Masina: Astra 2002 Z16XE
Clauuu
- Mesaje scrise: 3
- Masina: Insignia 2015 A20DTH
- Cont inregistrat: 23 Jun 2016
viulian
- Mesaje scrise: 8
- Masina: Astra 2005 Z16XEP
- Cont inregistrat: 25 Apr 2016
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- Mesaje scrise: 5,916
- Masina: Corsa 2001 Z12XE
viulian
- Mesaje scrise: 8
Zahadum
- Mesaje scrise: 20
- Masina: Astra 2005 Z17DTL
- Cont inregistrat: 24 Jun 2016
Clau..
W0LGT6EM6E1195753
Numar sasiu W0LGT6EM6E1195753
Cod model 0JT68
Caroserie T68
Cod pachet MYJ1
An model 2014 (A)
Data fabricatie 04.12.2014
Prima inmatriculare 31.03.2015
Cod motor LBS
Cod cutie de viteze MR6
Tip motor A20DTH
Serie motor 17D55131
Cod culoare GAR
Tapiþerie TALM
Rezultatele FI in cadrul cataloagelor sunt numai propuneri care vor fi analizate din punct de vedere veridicitate si logica
Date autoDotare
Caracteristicã Denumire
01A TRIM COLOR SEAT JET BLACK
1AB TRIM COLOR DR PANEL JET BLACK
2D4 MOLDING DR INTR,ECHELON COOL
3CW MOLD I/PECHELON COOL
4AA INTERIOR TRIM JET BLACK
5EA EQUIP. PACKAGE, CO2-REDUCTION
6X1 COMP FRT LH NON-COMP. SEL SUSP
7X1 COMP FRT RH NON-COMP. SEL SUSP
8X2 COMP RR LH NON-COMP. SEL SUSP
9X2 COMP RR RH NON-COMP. SEL SUSP
A51 SEAT FRONT
A69 RESTRAINT SEAT BELT TENSIONER
A6B ADJ FRT ST MAN 6-WAY PWR, DR
A70 RESTR. SEAT BELT TENSIONER,FRT
AB7 EFF. PT CTRL,SAFETY REGULATION
AEF POW. WINDOWS PASS,EXPR,UP/DOWN
AER POW. WINDOWS, RR, EXPR UP/DOWN
AFA INTERIOR TRIM CONFIG #1
AG5 SEAT ADJ, R, MANUAL 2 WAY
AJF REST HEAD,FRT SEAT,UP/DOWN ADJ
AKN WINDOW TYPE TINTED
AKW WINDSHIELD TYPE TINTED
APG CONTROL SEAT, POWER LUMBAR, LH
ASV EQUIPMENT SENSOR AIR MOISTURE
ATS REM. ENTRY STD.RANGE PASSIVE
AUY BREAKPOINT MY14.5
AXG ELECTRIC WINDOW - ONE TOUCH
AXJ VEHICLE TYPE PASSENGER CAR
AY0 AIRBAGS FRT,DR&CO,SIDE & ROOF
AY9 HEAD RST-RR,CENTRE
BTM SWITCH ENGINE START, KEYLESS
C25 WASHER + WIPER-BACK WINDOW
C59 VENT AIR, CONSOLE, RR
C99 PASSENGER AIRBAG,MANUAL CUTOFF
CE1 WIPER SYS, MOISTURE SENSITIVE
CE4 WASHER-HEADLAMP
CJ2 DUAL ZONE ELEC CLIMATE CONTROL
CR7 HUNGARY-MANDATORY
D7A HANDLE O/S, DR,B/C CHROMESTRIP
DA1 CENTER ARMREST, RR, W. STORAGE
DD8 MIRROR IS/RV, LT SENSITIVE
DH6 MIRRORS I/S SUNSHADE, ILLUM
DK6 CONSOLE ROOF INTERIOR
DWH MIRROR L+R,R/C,EL.HEAT PWRFOLD
EA1 POCKET, FRONT SEAT BACK, LH
EA2 POCKET, FRONT SEAT BACK, RH
ERT TRIM CLOTH, QUANT
F45 CONT REAL TIME DAMPING SUSP.
F46 CHASSIS ALL WHEEL DRIVE
FBE TRIM DOOR PVC, SIENA
FHY VEHICLE FUEL DIESEL B10
FW4 AXLE RATIO, FINAL DRIVE 3.89
FX3 VEH. STABILIZING SYSTEM (ESP)
G96 AXLE POSITRACTION LIMITED SLIP
GAR CARBON FLASH MET (G)
GNA CHASSIS EQUIP FRONT STRUT ASM
GNE CHASSIS EQUIP REAR AXLE H-ARM
I14 ENGINEERING YEAR 2014
IO6 RDO INFOTAINM SYS,UPLEVEL,CONN
J61 ABS 17",FRT & RR DISC, POWER
J71 BRAKE PARKING POWER OPERATED
K13 FILTER,EXHAUST SYSTEM,PARTICLE
K33 CRUISE CNTRL, AUTO ELEC. SPEED
K4R BATTERY LN4,12V,80AH,801,ENCCA
KB5 CONTROL ECM GRADE BRAKING
KD4 RECEPTACLE ELECTR, FRT CONSOLE
KG9 ALTERNATOR-140 A
KL9 START/STOP ENGINE CONTROL
KOT CTRL CONSOLE,INFOTAINMENT,REDU
KPA POWER OUTLET, REAR
LBS ENG-4 CYL 20L,DIESEL,TURBO HO
LHD LEFT HAND DRIVE
LP1Y Local Package
LPV0MAE LPV0MAE
MCR RECEPTACLE MEMORY CARD
MDE BELT LINE MOLDING, CHROME, ALL
MM3 TRANS-MAN, MERCHANDISED EQUIP.
MR6 TRANS-MAN, 6-SPEED, F40WR
N34 STEERING WHEEL LEATH. 3 SPOKES
N37 MAN.TILT TELESCOPING STEERING
NC0 EU-EQUIPMENT
NE9 EMISSION-SYSTEM EEC 09
NV7 STEERING POWER, VAR EFFORT
OHD MODEL UPGRADE 05
Q7B WHEEL 18x8, ALU, DESIGN 10
QCL TIRE SPARE T125/70 R17 SL 98M
RGV TIRE ALL 245/45R18 SL 96WHW4
RV9 WHEEL SPARE 17X4.0,T,STEEL,D1
T3U LAMP FRT FOG, ECE
T4F HEADL. HIGH INTENS DISCHARGE
T79 FOG LAMP, REAR
T7E LAMP SYS,DAY RUNNING LIGH,LED
T95 HEADL. CONTR BEAM,DIRECTIONAL
TALM TRIM CLOTH QUANT, BLACK
TG5 PLAYER COMPACT DISC & MP3
TQ5 CONTROL INTELLIGENT HIGH BEAM
TR7 HEADLAMPS CONTROL LEV.SYS.AUTO
TSP ILLUMINATION PACK
TSQ LAMP PACKAGE, INTERIOR, DELUXE
TTW HEADL CNTRL AUTO ON-OFF TUNEL
U18 SPEEDOM. KM
UD5 SENSOR IND. PARKING ASSIST
UDD INFO DISPLAY MULTI COLOR GRAPH
UH1 INDICATOR SEAT BELT WARNING,RH
UJN TIRE PRESS INDICATOR AUTOLEARN
UK4 DISPLAY PRESSURE BY TIRE
ULS LOCK CONTROL STEERING COLUMN
UQA SPEAKER SYSTEM PREMIUM AUDIO
US3 ANTENNA - Diversity
V33 TOOL KIT
V83 VEHICLE STATEMENT ECE ORG
VG2 WITHOUT WAX PROTECTION
VRG V.A. ASM COCKPIT
VRH V.A. ASM STEERING COLUMN
VRK V.A. ASM ROOF TRIM
VRL V.A. ASM FRONT HORIZONTAL SUSP
VRM V.A. ASM FRONT VERTICAL SUSPEN
VRN V.A. ASM REAR SUSPENSION
VRR V.A. ASM TIRES & WHEELS
VZE VIN MODEL YEAR 2014
W1Y STEERING WHEEL CONTROL-RADIO
W4Y GEARING CODE
WFF ORNAMENTATION LETTERING,"4x4"
WRA WIRING PROV CUSTOM WIRING BODY
WRB WIRING PROV CUSTOM WIRING (IP)
XJ2 SPORT-CHASSIS, LOWERED
XL8 FREQUENCIES 433 MHZ
W0LGT6EM6E1195753
Cod model 0JT68
Caroserie T68
Cod pachet MYJ1
An model 2014 (A)
Cod motor LBS
Tip motor A20DTH
Cod culoare GAR
Tapiþerie TALM
Date autoDotare
A51 SEAT FRONT
CE4 WASHER-HEADLAMP
LHD LEFT HAND DRIVE
LP1Y Local Package
LPV0MAE LPV0MAE
NC0 EU-EQUIPMENT
T79 FOG LAMP, REAR
U18 SPEEDOM. KM
V33 TOOL KIT
W4Y GEARING CODE
- Bryan99
- 1,147 mesaje
- din 02 Oct 2007
- Astra 2011 A1.7DTJ
Bryan99
- Mesaje scrise: 1,147
- Masina: Astra 2011 A1.7DTJ
- Cont inregistrat: 02 Oct 2007
Clauuu
- Mesaje scrise: 3
gabi12you
- Mesaje scrise: 43
- Masina: Astra 2003 xep
- Cont inregistrat: 18 Jan 2011
Zahadum
- Mesaje scrise: 20
Salut Gabi
Numar sasiu W0L0TGF4835185262
Cod model 0TT48
Caroserie F48
Cod pachet IYS1
An model 2003 (A)
Data fabricatie 09.04.2003
Prima inmatriculare 02.09.2003
Cod motor LJ7
Cod cutie de viteze MG4
Tip motor Z16XEP
Serie motor 20BB9265
Cod culoare 4AU
Tapiþerie XXKJ
23F STEERING WHEEL COLOR BLACK
2F4 RADIO CDR 500
2J1 FLOOR COVER-INNER, STANDARD
4AU SILVER LIGHTNING, M2
80I BLACK-INTERIOR
80X TRIM COLOUR-BLACK
80Y DOOR TRIM-COLOR, BLACK
A32 POWER WINDOWS, FRONT DOORS
A50 SPORT SEATS FRONT
AG4 SEAT ADJ,FRT,DRIVER,2WAY,MANUL
AHA CONTROL SEAT, MAN. LUMBAR, LH
AHB CONTROL SEAT, MAN. LUMBAR, RH
AJ3 AIRBAG, DRIVER SIDE ONLY
AJ4 AIRBAG, CODRIVER SIDE ONLY
AP0 SIDE AIRBAG, LEFT
AP1 SIDE AIRBAG, RIGHT
AT0 HEADRESTS, REAR, CLOTH
AU0 POWER DOOR LOCKS
AY3 HEAD RST-CLOTH, FRONT
AY5 HEAD RST-CLOTH,RR,CENTER
B86 MOLDING B/S IN BODY COLOR
BB7 CHROME DOOR OPENERS, INSIDE
C35 HEATER-REAR, LEGROOM
C60 AIR CONDITION FRT, MAN CONTROL
C73 LAMP, TAIL, DARK LENS
C87 READING LAMPS, REAR
CT3 GERMANY-MANDATORY
D1J INST. WHITE,BLACK,SILVER RINGS
D75 HANDLE O/S, DR, COLORED
DA5 CENTER ARMREST, REAR
DL8 POWER MIRRORS
DP6 MIRROR HOUSING, PAINTED
DT4 ASHTRAY - LIGHTER
G61 PROV. WHEEL, 4 HOLE MOUNTING
GX8 AXLE RATIO - 3.74
J65 BRAKE SYST., DISC FRONT & REAR
JL9 ANTILOCK TYPE BRAKE SYSTEM
K09 ALTERNATOR-120 A
LHD LEFT HAND DRIVE
LJ7 ENG-4 CYL 16 FIP, DOHC
MG4 TRANS-MAN 5-SPEED CR
N35 STEERING WHL-SPRT,LEATH.,3 spk
N40 POWER STEERING
NC0 EU-EQUIPMENT
NT4 EMISSION-SYSTEM EEC 05
OAV PRE-LAUNCH
OHB MODEL UPGRADE 03
P34 FULL SIZE SPARE WHEEL
PFL SALES PACKAGE,EQUIPMENT SPORTS
QE3 WHEEL 6 Jx16, ALU, 5TRZLO, SP
QTQ TIRES 205/50 R 16-87V
T9L TRIM PANEL,INNER,MALTA
T9P ORNA. HEADLAMPS, HOUSING, DARK
TN6 BATTERY - 55 AH
U07 DUAL TONE HORN
U96 6 LOUDSPEAKERS, VAR.2
UJ3 INDICATOR SERVICE INTERVAL
V22 RAD. GRILLE WITH CHROME MOLD.
VG9 EXTERIOR WAX PROTECTION
W4Y GEARING CODE
W7I TRIM CLOTH, TEXAS/MALTA
W8X ADD.PARTS FOR RADIO INSTALL.
XK0 SPORTY PACK
XK5 JEWEL PACK
XXKJ TEXAS / MALTA, BLACK
Z0F GERMANY, EQUIPMENT ADDITIONAL
Z1F IDENTIFICATION SPEEDOMETER KMH
Z3E LETTERING SPORT
Cod model 0TT48
Caroserie F48
Cod pachet IYS1
An model 2003 (A)
Cod motor LJ7
Tip motor Z16XEP
Cod culoare 4AU
Tapiþerie XXKJ
2F4 RADIO CDR 500
80I BLACK-INTERIOR
DL8 POWER MIRRORS
LHD LEFT HAND DRIVE
N40 POWER STEERING
NC0 EU-EQUIPMENT
OAV PRE-LAUNCH
TN6 BATTERY - 55 AH
U07 DUAL TONE HORN
W4Y GEARING CODE
XK0 SPORTY PACK
XK5 JEWEL PACK
Z3E LETTERING SPORT
Cyponne81
- Mesaje scrise: 2
- Cont inregistrat: 26 Jul 2016
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
Cyponne81
- Mesaje scrise: 2
Zahadum
- Mesaje scrise: 20
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
Zahadum
- Mesaje scrise: 20
- 4di
- 498 mesaje
- din 06 Nov 2008
- Corsa 2005 Z13DT
- Mures
4di
- Mesaje scrise: 498
- Masina: Corsa 2005 Z13DT
- Cont inregistrat: 06 Nov 2008
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
Zahadum
- Mesaje scrise: 20
Salut Cyponne81 din nou.
Numar sasiu W0LPD5ED2GG136979
Cod model 0PD69
Caroserie D69
Cod pachet IMG1
An model 2016 (A)
Data fabricatie 03.06.2016
Prima inmatriculare 29.07.2016
Cod motor LDE
Cod cutie de viteze MDG
Tip motor B16XER (A16XER)
Serie motor 20UD4908
Cod culoare GWD
Tapiþerie TANL
2HQ MOLDING DOOR, DOLOMITE PEARL L
A51 SEAT FRONT
A64 SEAT RR SPLIT, FOLDING, 40/60
AH3 ADJ. FRT ST, MAN,4 WAY, DRIVER
AHN RESTRAINT PROVISIONS LATCH
AQP REAR CENTER HEADREST
AVV BREAKING POINT 2016 1/2 M.Y.
AWO RESTR.SYS.RR SEAT BELT,3P CENT
AYC AIRBAG,DR&CODR,FRT&SIDE&ROOF
C1R ORNAMENT. INTR I/P ,JETBLACK
C95 LAMP INTR, RF, DUAL READING
D31 MIRROR IS/RV, TILT
D6I MIRROR I/S FRT VAN SUNSHADE DS
DBU CONSOLE FRT COMPT,FLOOR, ARM
DVN INST.BLACK, TRANSLUCENT RINGS
DWE MIRROR L+R,RC,ELEC,HEAT,MANFOL
EYF TRIM CLOTH, WEGA/ATLANTIS VAR1
FBD TRIM DOOR CLOTH, ATLANTIS
FX1 AXLE RATIO - 3.94
GNF CHASS EQUIP,RR AXLE,COMP CRANK
GWD FLIP CHIP MET (161V)
I16 ENGINEERING YEAR 2016
J67 BRAKE PWR,FRT&RR DISC,ABS 15"
K3L BATTERY, 12V, 60AH, 438 CCA
K60 ALTERNATOR-100 A
KC5 CONNECTION ELECTRIC ACCESSORY
KCL HEATER DUCT, RR (2ND POSN)
LDE ENG-4 CYL, 1.6 MFI, PT-JV
LHD LEFT HAND DRIVE
LP84 Local Package
MDB MOLDING B/S UPPER BLACK
MDG TRANS-MAN 5 SPEED, F17-5
N40 POWER STEERING
NE4 EMISSION-SYSTEM EEC 14
NQ1 FLUSH WHEEL COVER-VAR.10
OAY GEAR.CODE-LOCAL EQUIPMENT 1
OHA MODEL UPGRADE 02
PWM WHEEL 16x6.5, STEEL, DESIGN 2
QVF TIRES 205/60R16-92HBWR/STTLHW3
RU5 SPAREWHEEL,16X4.0,J,STEEL,DES1
T39 TURN SIGNAL LAMPS
T3N DAYT. RUNNING LAMPS,SEP CAVITY
T3Z DAYT. RUNNING, SEP. INCANDESC.
T4A HEADLAMPS HALOGEN
T79 FOG LAMP, REAR
TANL CLOTH WEGA/ALTLANTIS JET BLK
TR0 LAMP INTERIOR,ROOF,RR,COURTESY
TR6 HEADLAMPS-LEVELLING, MAN
TS6 STOPLAMP, CENTER, HIGH MOUNTED
TTX RADIO EQUIPMENT AUX CONNECTOR
U04 HORN SINGLE NOTE
U18 SPEEDOM. KM
U68 INFORMATION-COMPUTER
U91 ANTENNA SHORT, ROOF, RADIO
UC3 CONTROL STEERING WHEEL, RADIO
UDC INFO DISPLAY ONE COLOR GRAPHIC
UDN COLOR INFO DISPLAY (CID)7"WVGA
UFW RADIO STEREO,SGL CD, MP3, USB
UH0 INDICATOR SEAT BELT WARNING,LH
UJM TIRE PRESS INDIC. MANUAL LEARN
UP9 WIREL INT SR,VOICE REC,MUSICN
UZ6 6 SPEAKERS, PREMIUM
V48 COOLANT - MAXIMUM PROTECTION
VA4 PANEL CENTER,DOLOMITE PEARL L.
VD1 PROVISION OPTIONS EUROPE
W4Y GEARING CODE
WGA EQUIP. RECEIVING UNIT, RADIO
WMG VIN MODEL YEAR 2016
ZP5 SEAT ARRANGEMENT - 5 PASSENGER
Cod model 0PD69
Caroserie D69
Cod pachet IMG1
An model 2016 (A)
Cod motor LDE
Cod culoare GWD
Tapiþerie TANL
A51 SEAT FRONT
LHD LEFT HAND DRIVE
LP84 Local Package
N40 POWER STEERING
T79 FOG LAMP, REAR
U18 SPEEDOM. KM
W4Y GEARING CODE
