  3. Motoare Diesel
  • cobraro22
  • Mesaje scrise: 39
  • Masina: Corsa 2004 z13dt
  • Cont inregistrat: 06 Jun 2010
salut,
bateria slaba, vreme -20 grade, am fortat pana s-a consumat bateria.
la ultimele incercari bordul se manifesta ca luminile de la pomul de craciun.
am pus bateria pe redresor, conectat la masina, dar am martorul cu masinuta cu cheita service intermitent.
erori:
P1615 wrong vehicle ID from body control module
P1616 wrong vehicle id from instrument control module
am reprogramat BCU si am scapat de eroare P1615, dar de P1616 nu reusesc.
inainte sa se descarce bateria, masina mergea foarte bine. pornea la prima cheie.
Model: Corsa
An fabricatie: 2004
Cod motor: z13dt
  • cmarius53
  • Mesaje scrise: 454
  • Masina: Astra 2000 y20dth
Subject: Column Integration Module (CIM) - Engine does not start, DTC P1614 / P1616 and/or B3055 set
Models: Engines: Option:
Astra-H 2004...2007,Zafira-B 2005...2007 All,All
Complaint: Engine does not start, DTC P1614 / P1616 and/or B3055 set.
Cause: Software weakness of the Column Integration Module (CIM).
Production: As of MY 2008 improved CIMs with new software have been introduced in production.
Remedy:
In case of customer complaint reprogram the CIM as described in TIS 2000
with TIS 2000-DVD, version 83 or higher.
Important: For a successful programming follow the instructions in
TIS 2000 and set up the CIM for programming by Tech-2 before reprogram.
Procedure for CIM SPS programming:
--> After selection of MY and Vehicle "Enter"
--> Body "Enter"
--> CIM "Enter"
--> Additional Funktions "Enter"
--> SPS programming set up "Enter" - CIM SPS programming will be performed
--> Exit
Afterwards carry out the CIM SPS programming (Old software version:
M: --.57; New software version: M: --.62).
Important: During the CIM set up ignore all "switch off ignition" messages,
otherwise the programming of the CIM won´t be successful.
Note: Vehicles with PEPS are not affected and therefore it is not possible
to program a CIM with PEPS.
FunctionalGroup: N - Electrical Equipment
Complaint Group: 04 - Electrical failures,21 -Poor Startability
Trouble Code: P1614,P1616,B3055
Multumim luciraica.Folositi functia de cautare.Face minuni.
  3. Motoare Diesel
