- popescu iulian
- 1,400 mesaje
- din 19 Jun 2006
- Antara 2012 A22DMH
- Timisoara
popescu iulian
- Mesaje scrise: 1,400
- Masina: Antara 2012 A22DMH
- Cont inregistrat: 19 Jun 2006
- zafira 2.0 automatic
- 1,031 mesaje
- din 15 Nov 2005
- Zafira 2003 y20dth
- Mesaje scrise: 1,031
- Masina: Zafira 2003 y20dth
- Cont inregistrat: 15 Nov 2005
Mama! eu am fost printre primii care s-au luat de omul asta!
Ca sa punem pct. eu zic ca adevarul e urmatorul:
Opelul e o masina satisfacatoare ca si pret / calitate atat ca masina de noua cat si piese / consumabile. Desigur ca era loc de mai mult, dar traim intr-o societate de consum, in care e clar ca, dupa o perioada de timp trebuie sa schimbam produsul cu altul nou.
Calitatea se plateste si optionalele!
Desigur ca si eu am o intrebare catre producator de ce a folosit in pi....a lu m...sa asa sistem prost la air bag-ul volanului si cauciuc de kkt.........
- asfalttango
- 50 mesaje
- din 04 Aug 2006
- Astra 2003 y17dt
- CONSTANTA
asfalttango
- Mesaje scrise: 50
- Masina: Astra 2003 y17dt
- Cont inregistrat: 04 Aug 2006
CONFIDENTIAL, for internal use only!
Number: TACI/004/04 Date: 01/14/2004
Originator: Attila Vaczi
Model: Vectra-C, Signum MY 2003, 5
Group: J
Subject: Engine Oil Change Interval - Engine Oil change conditions for
ECOService-Flex
Complaint: The correct engine oil life can not be determined anymore.
Cause: Due to manual changes of the service interval adjustment in
the instrument the determination of the correct engine oil
life is not possible anymore.
Remedy: If there is a deviation of more than +/-90 days between the
data that is stored in the instrument and the manual data that
is loaded via TECH2 an engine oil change has to be performed
to avoid engine damage. If the service interval system was
changed from ECOService to ECOService-Flex the last engine oil
change should not be longer than 3 month or 3900 km ago
otherwise the engine oil has to be changed too. The engine oil
used has to fulfill the ECOService-Flex specification. All
engine oil changes have to be documented in the service
booklet. For further information please refer to Tis 2000
documents: 00302248, 00302251
Mainly affected are MY 2003,5 vehicles with software
deviations in the instrument. Modified software for the
instrument is available since start of MY04. Breakpoints:
Ellesmere Port: W0L0ZCF6838131726 and Rüsselsheim:
W0L0ZCF6931157315
Group: J
ECOService-Flex
W0L0ZCF6931157315
- asfalttango
- 50 mesaje
- din 04 Aug 2006
- Astra 2003 y17dt
- CONSTANTA
asfalttango
- Mesaje scrise: 50
Subject: Engine and Drivetrain Control Module (3.2V6/6VD1 and 4L-30E) -
Diagnostic Trouble codes set if SPS Programming is attempted
Complaint: Engine Management warning lamp illuminates. DTCs P0601 and
P1125 present.
Cause: Power Control System is not SPS programmable.
Remedy: The 3.2V6 (6VD1) Power Control System ECU is not SPS
Programmable. In the event of SPS programming being attempted,
either to a replacement unit or as a service upgrade, the
diagnostic trouble codes listed above will be set and cannot
be erased, making it necessary to replace the unit.
When fitting a new unit, the only programming function
necessary via Tech2 is the initialisation of the immobiliser
function, which should be carried out in accordance with
TIS2000 Checking procedures.
P1125 present.
- asfalttango
- 50 mesaje
- din 04 Aug 2006
- Astra 2003 y17dt
- CONSTANTA
asfalttango
- Mesaje scrise: 50
Field Remedy 1824
Subject: Door Lock - Door does not open from outside
Models: Tigra-B 2005...
Engines: All
Complaint: Door Lock - Door does not open from outside
Remedy:
In case of customer complaint replace the linkage from outer door handle to door lock in the left and the right door.
Working Procedure:
1. Remove inner panelling of front door
- see working procedure "Inner Panelling – Front Door, Remove and Install", Group "C", Service Instruction Tigra-B (Document-Number 00702313).
2. Remove water deflector foil partially.
Important: Remove water deflector foil carefully!
3. Remove outer door handle linkage (Picture I).
- unlatch clip (1) and (2) carefully
. Install new outer door handle linkage
- latch 2x clip carefully
5. Secure clip door lock (Picture II).
- install cable strap (1)
Engines: All
Remedy:
Working Procedure:
- asfalttango
- 50 mesaje
- din 04 Aug 2006
- Astra 2003 y17dt
- CONSTANTA
asfalttango
- Mesaje scrise: 50
Model: All
Group: C
Subject: Interior Trim - Painted interior trim surfaces damaged by air
refreshers
Complaint: Customer complains about loosing paint on interior trim
components like radio, dashboard, switches and the center
console.
Cause: Painted surfaces will be attacked and damaged by usage of air
refreshers in vehicles. Air refreshers contain aggressive
ingredients therefore it should be avoid to get in direct
contact with painted surfaces.
Remedy: Customers have to be informed about this concern. Often a hint
is even printed on the air refresher packaging that every
contact with painted surfaces has to be avoided. Parts damaged
by usage of air refreshers in the vehicle will not be accepted
by warranty.
Atit pentru azi....Cine este "open mind" intelege....cine nu....baneaza(sau editeaza postarile....doar este mult mai simplu).
Group: C
refreshers
console.
by warranty.
- bertone
- 2,294 mesaje
- din 13 Jun 2005
- buzau
bertone
- Mesaje scrise: 2,294
- asfalttango
- 50 mesaje
- din 04 Aug 2006
- Astra 2003 y17dt
- CONSTANTA
asfalttango
- Mesaje scrise: 50
Movano - Steering Wheel
Problem:
The steering wheel may vibrate so impairing control of the vehicle.
Cause:
The steering wheel mounting not tightened according to specification.
Remedy:
Replace steering wheel and fix with new bolt according attached tightening procedure.
Vehicle Marking:
All vehicles, which have been reworked according to this information, have to be clearly marked by a green dot on the inner side of the cover, fuse box (below steering column).
Scope:
Model Plant From To
Movano Battily 28860791 30041452
Movano - MY 2004 - Only vehicles listed in the attached VIN information files have to be re-worked.
Parts:
Qty Part Name Part No. Cat. No.
1 Wheel, Steering, Three Spokes 93 183 708 44 15 907
1 Bolt, Steering Wheel to Steering Column 93 183 709 44 15 908
Warranty Claim Information:
Claims will be accepted without any time or mileage limit.
Number Labor Description TC Hours AW
T 0942 00 Replace steering wheel and bolt steering wheel to steering column 96 0.6 7
T 0942 70 Vehicle already reworked 96
T 0942 80 Customer cannot be reached 96
T 0942 90 Vehicle stolen or scrapped 96
Please note that the regular setup time is already included in the time allowance.For cus-tomer notification it is allowed to claim an administrative fee of Euro 3.65 (or local
equivalent).
Rework Details:
1. Disconnect battery negative lead
• Remove nut
Warning: Follow universal safety regula-tions when handling airbag components.
2. Remove drivers airbag (1) from steering wheel
• Release 2x clip
• Release locking tag
• Disconnect harness connector
Figure 01
3. Remove, then discard, steering wheel from vehicle
Note: Steering wheel should be in a straight-ahead position before removing.
• Remove bolt, then discard
• Feed airbag harness through aper-ture in steering wheel
4. Install new steering wheel to vehicle
• Install new bolt
Important:
• Pretighten to 50 Nm ± 15%
• Loosen the bolt by one turn (360°)
• Rethighten the bolt to a torque of
44 Nm
5. Install drivers airbag (1) to steering wheel
• Connect harness connector
• Secure locking tag
• Secure 2x clip
6. Connect battery negative lead
• Install nut 12 Nm
7. Program all volatile memories
RO RO0180 0010DNWS VN1F9CUL630079192
RO RO0180 0055DQY3 VN1F9CUL630087545
RO RO0190 0003DQPF VN1F9CUH630087462
RO RO0190 0018DQAN VN1U9CVK530096747
RO RO0190 0031DPV7 VN1F9CVH530087523
RO RO0190 0041DPYR VN1F9CUM630087530
RO RO0190 0053DR8M VN1F9CUH630087538
RO RO0210 0066DPRA VN1F9CVH530087556
RO RO0210 0075DRC8 VN1F9BVH530087570
RO RO0220 0073DQFZ VN1F9CVH530087566
RO RO0230 0005DQ1D VN1F9CUJ630087474
RO RO0280 0003DPZ2 VN1U9CUK630079167
RO RO0290 0008DPQH VN1F9CVM530087484
RO RO0290 0060DQ3G VN1F9CUM630087548
Problem:
Cause:
Remedy:
Vehicle Marking:
Scope:
Model Plant From To
Parts:
equivalent).
Rework Details:
• Remove nut
• Release 2x clip
Figure 01
• Install new bolt
Important:
44 Nm
• Secure 2x clip
• Install nut 12 Nm
- asfalttango
- 50 mesaje
- din 04 Aug 2006
- Astra 2003 y17dt
- CONSTANTA
asfalttango
- Mesaje scrise: 50
Vectra C, Signum – Graphic Info Display (GID) and Radio CD30
Problem:
Radio CD30, tip switches 'bass' and 'treble' as well as 'rocker' do not work, adjustments are impossible and no optical display.
Cause:
Manufacturing deviations.
Remedy:
Reprogram graphic info display (GID) with Tech2 software version 13.401 or later (TIS2000 CD 54). Select radio type 'CD30MP3' even if 'CD30' is installed during variant programming.
Vehicle Marking:
No marking necessary.
Scope:
No Model Plant From To
205 Vectra C, Signum, Rüsselsheim 5 1 000127 5 1 002654
Vectra C, Signum - MY 2005 - Only vehicles with graphic info display (GID) and radio CD30 listed in the attached VIN information files have to be reworked.
Warranty claims will be accepted until 30/09/2006.
T 0946 00 Reprogram graphic info display (GID) 92 0.4
Problem:
Cause:
Remedy:
Vehicle Marking:
Scope:
- asfalttango
- 50 mesaje
- din 04 Aug 2006
- Astra 2003 y17dt
- CONSTANTA
asfalttango
- Mesaje scrise: 50
Movano - Power Steering Fluid Reservoir
Problem:
Power steering fluid reservoir may become detached from its bracket, which may result in a loss of power steering hydraulic fluid.
Cause:
Power steering fluid reservoir bracket securing lug deformed.
Remedy:
Secure power steering fluid reservoir to bracket with an additional retaining strap. (See figure 01 and 02 below)
Figure 01 Figure02
Vehicle Marking:
Scope:
7.186 Movano Battily 28860791 31185885
Movano - MY 2004 - Only vehicles listed in the attached VIN Information files have to be reworked.
Parts:
1 Retaining strap 90 159 651 22 08 882
T 0947 00 Install retaining strap 92 0,1 1
Problem:
Cause:
Remedy:
Figure 01 Figure02
Vehicle Marking:
Scope:
Parts:
- asfalttango
- 50 mesaje
- din 04 Aug 2006
- Astra 2003 y17dt
- CONSTANTA
asfalttango
- Mesaje scrise: 50
Subiect: Casete de directie Corsa-C, Combo, Meriva
Catre departamentul de Service, Garantii
Stimati Colaboratori
Conform informatiilor primite la sedinta de Aftersales din data de
05.Mar.2004 la toate modelele Corsa-C, Combo, Meriva la verificarea PDI
casetele de directie trebuie gresate.
Pana nu primiti o circulara care anuleaza aceasta procedura, acesta trebuie
efectuata.
Important: gresarea trebuie efectuata la PDI.
Daca in sistem nu este inregistrata efectuarea gresarii, in cazul in care
apare o problema cu caseta de directie, sistemul nu o sa accepte cazul ca
garantie.
In cazul acesta dealerul care nu a respectat procedura data de GMSE trebuie
sa suporte costul reparatiei.
efectuata.
garantie.
- asfalttango
- 50 mesaje
- din 04 Aug 2006
- Astra 2003 y17dt
- CONSTANTA
asfalttango
- Mesaje scrise: 50
Z18XE, Z18XEL - Engine Telltale
Problem:
Engine telltale / MIL might come on and trouble code P0335 ( 8 ) is set due to a problem of the diagnosis software.
Cause:
Software calibration is not according to specification.
Remedy:
Reprogram Engine Control Unit with modified TECH2 software update CD 51.1.
All vehicles with a green dot or a white cross on the Engine Control Unit are already reprogrammed by the plant and can be released immediately to the customer. Please do not hand over vehicles which have not been reworked.
Note: Modified TECH2 software is available as an update CD 51.1 and covers the above mentioned issue only.
Vehicle Marking:
All vehicles, which have been reworked according to this information, have to be clearly marked by a green dot on the Engine Control Unit.
Affected:
Corsa C, Meriva, Astra G, Astra H, Zafira A, Vectra C and Signum - MY 2004 - Only vehicles with Z18XE or Z18XEL engine are affected.
Problem:
Cause:
Remedy:
Vehicle Marking:
Affected:
- LDivora
- 3,098 mesaje
- din 30 Mai 2005
- Astra 2003 Y20DTH/PSG16
LDivora
- Mesaje scrise: 3,098
- Masina: Astra 2003 Y20DTH/PSG16
- Cont inregistrat: 30 Mai 2005
- jE
- 8,436 mesaje
- din 04 Jun 2006
- Astra 2005 Z18XE
jE
- Mesaje scrise: 8,436
- Masina: Astra 2005 Z18XE
- mihai_b
- 746 mesaje
- din 12 Feb 2008
- Vectra 2003 Z16XE
mihai_b
- Mesaje scrise: 746
- Masina: Vectra 2003 Z16XE
- Cont inregistrat: 12 Feb 2008
omu vad ca e hotarat si inversunat in a ne demonstra ce masini aiurea si penibile ne-am luat...in loc sa infieram acest comportament, eu zic sa ne turnam cenusa in cap...sa ne cerem scuze public in fata lui pentru alegerile facute...iar joia cand ne intalnim sa ne dam foc la masini intr-o procesiune solemna...In plus, vineri, ne prezentam toti la dealeri ( de la maserati in sus...) si fiecare isi ia o masina care nu are atatea probleme...eu incep prin a ma concentra asupra unui lexus...
P.S. acu serios vorbind, ar trebui atrasa atentia omului ca deja insista prea mult, si "pacifismul" meu, cat si al altora are totusi niste limite...
- ktapet
- 485 mesaje
- din 13 Mai 2005
- Zafira 2007 Z19DT
- Ilfov
ktapet
- Mesaje scrise: 485
- Masina: Zafira 2007 Z19DT
- Cont inregistrat: 13 Mai 2005
defero
- Mesaje scrise: 22
- Masina: Corsa 2008 z13dth 90cp
- Cont inregistrat: 30 Mai 2008
- bertone
- 2,294 mesaje
- din 13 Jun 2005
- buzau
bertone
- marian_sro
- 3,793 mesaje
- din 08 Apr 2007
- Vectra 1999 x20xev
- piatra neamt
marian_sro
- Mesaje scrise: 3,793
- Masina: Vectra 1999 x20xev
la naiba, acum eu ce ma fac ca am doar vectra a?
oare sunt open mind?
nu trebuia suspendat,era distractiv
sunt de acord cu incendierea,maine ma duc sa imi iau golan.
@asfaltango logan nu vinzi?
@bertone nu faci tu un gest sa anunti pe cine trebuie ca domnul "open mind" a dat in public niste chestii interne?secrete? hai, te rog eu mult!
- dancuciureanu
- Moderator
- 16,464 mesaje
- Agila 2001 Z10XE + Z12XE
dancuciureanu
- Mesaje scrise: 16,464
In TIS exista o parte de informari service si remedieri.
Orice service din reteaua Opel primeste prin mail ultimele noutati si mi se pare corect.
Nu stiu de unde le are dar personal mi se par binevenite atita timp cit nu am acces facil la ele din alte surse.
Si eu am citit tirziu in TIS cu modificarea chederului capota (35lei) si chestia asta m-a costat un debitmetru de 650lei. Baietii de la Opel au luat caroseria de Suzuki dar nu si motorul cu priza de aer...
Decit sa ne certam aiurea mai bine facem o baza de date pe modele cu aceste informari, mi se par binevenite. Daca el ne ajuta la asta si nu mai declara ca Opel e o masina proasta (ne atinge direct) eu zic sa ridicam suspendarea. Orice masina are probleme specifice, pina si un Mercedes are bube de fabricatie.
