Este vorba despre
V-CHECKER CAN-BUS OBD2 SCANNER la 69$
Features
With large LCD display: the trouble code description will be displayed directly on the screen, no need for search it in the user's manual
Each code will be continuously displayed until the [↑] or [↓] key is pressed. This is an important advantage to compare with the old type trouble code reading tools
With extension cable, comfortable for operation
With live data or data stream function
Support all OBD2 protocols: OBD-I, OBD-II, EOBD, JOBD, and CAN-BUS
With professional mode
With large DTC database
Powered via diagnostic connector, no additional power is needed
Plug and play, ease to use
Turn off check engine light
High reliable and accurate
Main Functions
Display DTC descriptions in text mode
Read DTC
Erase DTC
Data Stream
Freeze Frame Data
Oxygen Sensor Test
On Board Monitor
Request Control Test
ECU Information
Al doilea echipament este
OPEL TECH2 USB INTERFACE 29$
Functions
This item can perform diagnosis of Engine, Transmission, Chassis, and Body systems for OPEL vehicles from year 1997 to 2004.
Package Contains
OPEL TECHII USB Interface
USB cable
Software CD
Workable Models
1997: CORSA-B, TIGRA, ACTRA-F, VECTRA-B, CALIBRA, OMEGA-B, FRONTERA, MONTEREY
SINTRA
1998: CORSA-B, TIGRA, ACTRA-F, ACTRA-G, VECTRA-B, OMEGA-B, FRONTERA, MONTEREY
SINTRA, ARENA
1999: CORSA-B, TIGRA, ACTRA-F, ACTRA-G, ZAFIRA, VECTRA-B, OMEGA-B, FRONTERA-B
SINTRA, ARENA, MOVANA
2000: AGILA, CORSA-B, TIGRA, ACTRA-F, ACTRA-G, ZAFIRA, VECTRA-B, OMEGA-B, FRONTERA-B, ARENA, MOVANA
2001: AGILA, CORSA-B, CORSA-C, ACTRA-F, ACTRA-G, ZAFIRA, SPEEDSTER/VX220
VECTRA-B, OMEGA-B, FRONTERA-B, CAMPO, VIVORO, MOVANA
2002: AGILA, CORSA-B, CORSA-C, ACTRA-F, ACTRA-G, ZAFIRA, SPEEDSTER/VX220
VECTRA-C/SIGNUM, OMEGA-B, FRONTERA-B, CAMPO, VIVORO, MOVANA
2003: AGILA, CORSA-B, CORSA-C, MERIVA, ASTRA-G, ZAFIRA, SPEEDSTER/VX220
VECTRA-C/SIGNUM, OMEGA-B, FRONTERA-B, VIVORO, MOVANA
2004: AGILA, CORSA-C, MERIVA, ASTRA-G, ZAFIRA, SPEEDSTER/VX220, VECTRA-C/SIGNUM, VIVORO, MOVANA
Stie cineva care este mai profitabil?
Din cate am inteles, primul este cel mare este compatibil cu mai multe masini si nu iti trebuie laptop la el, deci este mai comod.
Am nevoie de parerea voastra!
Si cu ocazia asta - cenzurat - data viitoare, daca ai asemenea idei, creaza topic la publicitate, eventual un PFA
