- sever iulian
- 1,325 mesaje
- din 17 Sep 2006
- Insignia 2017 B20NFT
- Bacau
sever iulian
- Mesaje scrise: 1,325
- Masina: Insignia 2017 B20NFT
- Cont inregistrat: 17 Sep 2006
MOTORUL MEU E Y20DTH NU Y22DTH CUM A SCRIS FLORINIKE. MASINA O AM DE SAMBATA SI NU PREA AM AVUT TIMP SA O CUNOSC. ABIA AM TERMINAT AZI ACTELE PT INMATRICULARE. DIN ULTIMILE OBSERVATII POT SPUNE CA PORNESTE GREU DOAR CAND E CALD AFARA SI MOTORUL E RECE. DIMINEATA PORNESTE FARA PROBLEME. ORICUM IN 4 ZILE MI S-A INTAMPLAT DE 3 ORI. MAINE MA DUC LA IASI SI POATE AM TIMP SA INCERC SI SERVICE-UL DE ACOLO CACI CU BACAU M-AM LAMURIT. AZI A PORNIT LA 4 SECUNDE. AM MAI VORBIT AZI CU CINEVA IN DOMENIU SI MI-A SPUS CA A MAI VAZUT PROBLEMA ASTA LA ALTA MASINA CARE AVEA PROLEMA MEA DOAR VARA ,IARNA PORNEA FARA PROBLEME. TKS LA TOATA LUMEA
relu1406
- Mesaje scrise: 86
- Masina: Vectra 2003 Y20DTH
- eduard33
- 1,502 mesaje
- din 24 Nov 2004
- Omega 1997 X20XEV
eduard33
- Mesaje scrise: 1,502
- Masina: Omega 1997 X20XEV
- Cont inregistrat: 24 Nov 2004
adry
- Mesaje scrise: 81
- Masina: Vectra 2002 Y20DTH
- Cont inregistrat: 11 Jun 2006
- maiandrei
- 4,711 mesaje
- din 20 Dec 2004
- Insignia 2018 B20DTH
maiandrei
- Mesaje scrise: 4,711
@adry: exact asa se intampla si altora:
https://www.clubopel.com/vie...jii+incandescente
@sever iulian: nu te grabi sa cheltui banii, asteapta sa te obisnuiesti cu masina. Intre timp, cauta pe forum raspunsuri la tot ce ti se pare suspect
- Daniel
- 2,832 mesaje
- din 06 Dec 2004
- Astra 2012 A17DTJ
Daniel
- Mesaje scrise: 2,832
- Masina: Astra 2012 A17DTJ
- manfred
- 130 mesaje
- din 02 Aug 2006
- Omega 1998 X25DT
manfred
- Mesaje scrise: 130
- Masina: Omega 1998 X25DT
- Cont inregistrat: 02 Aug 2006
1. dupa ce se sting bujiile incandescente mai numara 6 secunde si da la cheie....vezi cum e.
2. daca face asa doar la cald...cand nu pune bujiile, dar la rece porneste bine (respectand cele 6 secunde) da de veste si mai vedem ce are...senzor turatie volanta, computer de bord, capul de la injectie...etc
- sever iulian
- 1,325 mesaje
- din 17 Sep 2006
- Bacau
sever iulian
revin cu noi observatii. Am probleme in continuare cu pornirea am schimbat returul la injectoare si nu am rezolvat nimic. Vineri la 8 am programare la brasov. Am rezolvat in schimb astazi potentiometrul de volum de la radiocd. Daca intereseaza pe cineva pot da detalii. Referitor la problema cu pornirea grea,de la gold-platin iasi mi s-a spus ca la tipul de motor y20dth trebuie schimbate dupa 2 ani retururile de la injectoare ceea ce am si facut.Daca nu merge mi-au spus sa fac programare sa schimb injectoarele. Am ales sa merg la brasov pt ca am inteles ca ar fi mai seriosi.
- mikhai
- 215 mesaje
- din 12 Jun 2006
- Astra 2004 y20dth
mikhai
- Mesaje scrise: 215
- Masina: Astra 2004 y20dth
- Cont inregistrat: 12 Jun 2006
apropo de "MASINI PROASTE":singura proasta in chestia asta este linia
materna a dobitocului de mecanic ce a zis asta,incepind cu eva,trecind
prin maimutza alfa si pina la ma-sa si ma-sa a ma-sii mari.
daca nu o scotzi la cap cu opel bv ,anuntza-ma si facem o simulare de
test pe banc adevarat,nu pe vorbe si impresii.
oricum,daca mai dai pe la bacau,zi-i aluia sa-i dea d-zeu un frate de sa-i fie tata...
- ionutz2008
- 211 mesaje
- din 13 Mai 2006
- Vectra OPC 2005 Z28NET
ionutz2008
- Mesaje scrise: 211
- Masina: Vectra OPC 2005 Z28NET
- Cont inregistrat: 13 Mai 2006
Am un prieten disperat si dezamagit ce are o astra G 2003 cu motor Y20DTH si ii porneste foarte greu cu motorul cald ,cand este rece porneste foarte bine. A facut urmatoarele reparatii la GTT Bucuresti si la sfatul acestora ca nici ei nu stie de ce: prima oara a schimbat oringurile de la injectoarea poi i-a pus soft 2006 dupa care a schimbat senzorul de temperatura a apei pentru motor. Acum ce ar mai trebui sa ii faca sa porneasca bine.Cei de la GTT nu mai stie ce sa ii mai spuna sa schimbe.
Va multumesc in numele lui.
- ionutz2008
- 211 mesaje
- din 13 Mai 2006
ionutz2008
- G-power
- 178 mesaje
- din 20 Aug 2004
G-power
- Mesaje scrise: 178
- Cont inregistrat: 20 Aug 2004
- Drogas
- 1,260 mesaje
- din 11 Sep 2006
Drogas
- Mesaje scrise: 1,260
- G-power
- 178 mesaje
- din 20 Aug 2004
G-power
- ionutz2008
- 211 mesaje
- din 13 Mai 2006
ionutz2008
- eduard33
- 1,502 mesaje
- din 24 Nov 2004
- Omega 1997 X20XEV
eduard33
- ElSpa
- 178 mesaje
- din 13 Feb 2006
ElSpa
- Cont inregistrat: 13 Feb 2006
- eduard33
- 1,502 mesaje
- din 24 Nov 2004
- Omega 1997 X20XEV
eduard33
daca o astra G 2003 cu motor Y20DTH deja are probleme cu injectoarele, inseamna ca e de rau
...ma cam indoiesc,dar nu exclud posibilitatea...e primul caz pe care il aud de o asemenea maniera....raman totusi la parerea mea, gandindu-ma(dupa spusele initiatorului topicului) ca problemele se ridica doar cand e motorul cald.
![Confused](http://www.clubopel.com/images/2013/blank.gif)
- sever iulian
- 1,325 mesaje
- din 17 Sep 2006
- Bacau
sever iulian
aceeasi problema o am cu vectra c 2004, y20 dth. la rece porneste bine pt ca intra bujiile. porneste greu doar cand motorul e rece. de exemplu dimineata porneste la sfert. daca o opresc repede astfel incat motorul nu apuca sa se incalzeasca(dupa ce o las jumatate ora) porneste mai greu. am fost la 3 reprezentante opel(bacau iasi si brasov) si situatia s-a imbunatatit dupa service-ul de la brasov. concluzia o fost ca problema vine din pompa de injectie. una noua costa 2450euro+tva. am luat decizia sa o dea jos si sa o trimita la bosh si primeam inapoi alta pompa reconditionata care costa in jur de 1200. dupa o saptamana m-au sunat si mi-au spus ca nu au tipul meu de pompa (ca ar fi cu 2 mufe ). le-am spus sa o monteze inapoi ca iau masina asa cum a fost. dupa asta surpriza: masina a mers perfect 2 saptamani pana azi noapte cand a luat-o la a doua cheie. ce am observat ca motorul ere rece(masina nepornita 8 ore) si afara erau 3 grade celsius si nu au intrat bujiile de loc. am sa verific si eu senzorul de temperatura. imi spune cineva unde e pozitionat?
![Shocked](http://www.clubopel.com/images/2013/blank.gif)
- sever iulian
- 1,325 mesaje
- din 17 Sep 2006
- Bacau
sever iulian
