- octav13
- 2,072 mesaje
- din 17 Nov 2006
- Vectra 2003 y 22 dtr
- Teleorman
octav13
- Mesaje scrise: 2,072
legat de range...
asa se intampla si la mine,daca am un consum mediu mare..9 de ex,apare pompita si gange 50!si mai am inca 2 liniutze rosii.nici becul de rezerva nu e inca aprins.posibil ca in rezervor sa mai am cel putin 10 L de motorina,dar,cf BC,mai merg doar 50 km raportat la consumul mediu.
ala era ML 55,mai mult ca sigur
- danutz22
- 189 mesaje
- din 27 Jun 2008
- Signum 2005 Z19DTH
danutz22
- Mesaje scrise: 189
- Masina: Signum 2005 Z19DTH
- Cont inregistrat: 27 Jun 2008
@ Bertone
Daca aflii ceva preturi pt fusta aia, sa imi spui si mie te rog, ca si pe mine ma intereseaza, arata foarte fain.
Cat despre Cruise Control, uite ce zice manualul GM:
(buton m=cel mic, de sus
buton g=cel mic, de jos
buton §=cel mare, din spate)
"Cruise control can store and maintain speeds from approx. 20 to 125 mph (30 km/h to 200 km/h). For safety reasons, cruise control cannot be activated until the foot brake has been activated. Cruise control is operated with buttons m, g, and § on the turn signal stalk.
Do not use the cruise control if it is not advisable to maintain a constant speed (e.g. in situations presenting a danger to yourself and other road users, in heavy traffic or on winding, slippery or greasy roads).
For automatic transmission 3, it is best to only activate cruise control when in D or in stepless automatic mode. When the cruise control is active, reaction times may be increased due to the different position of the feet.
Control indicator m Illuminates for several seconds after switching the ignition on. The system is now ready for operation. When driving, the control indicator m will light up as soon as the system is switched on.
To activate:
Tap button m: the current speed is stored and maintained. The accelerator pedal can be released. Vehicle speed can be increased by depressing the accelerator pedal. When the accelerator pedal is released, the previously stored speed is resumed. Increase With cruise control active, hold down button m or tap it repeatedly: speed is increased continuously or in steps of 1.2 mph (2 km/h) without using the accelerator pedal.
When button m is released the current speed is stored and maintained. Disregard of these instructions may lead to injuries or end anger life.
Decelerate
With cruise control active, press button g or tap it repeatedly: speed is reduced continuously or in steps of 1.2 mph (2 km/h). When button g is released the current speed is stored and maintained.
To deactivate:
Tap button §: Cruise control is switched off, control indicator m goes out and the vehicle slowly dec elerates. To continue driving, depress the accelerator pedal in the usual manner. For reasons of safety, cruise control switches off automatically under certaindriving conditions.
For example:
- the vehicle's speed drops below approx. 20 mph (30 km/h) or
- the brake pedal is depressed or
- the clutch p edal is depressed or
- Automatic transmission selector lever * to N.
Resuming the stored speed
Tap button g at a speed above 20 mph (30 km/h): the speed selected before the cruise control was switched off is resumed.
The stored speed is erased when the ignition is switched off."
To activate:
Decelerate
To deactivate:
For example:
- bertone
- 2,294 mesaje
- din 13 Jun 2005
- buzau
bertone
- Mesaje scrise: 2,294
- danutz22
- 189 mesaje
- din 27 Jun 2008
danutz22
- bertone
- 2,294 mesaje
- din 13 Jun 2005
- buzau
bertone
- bertone
- 2,294 mesaje
- din 13 Jun 2005
- buzau
bertone
- danutz22
- 189 mesaje
- din 27 Jun 2008
danutz22
Ai mei caluti s-au nascut in august 2005 si au mers 120.000km, eu am luat-o la 104.000km din Germania.
Referitor la distributie, ma indoiesc ca a fost schimbata si stiu ca se face la 150.000 la motoarele astea (Z19DTH).... ce imi recomandati, cam cand sa o schimb? Sa o mai las si cat sau sa o schimb?
- lucio
- 783 mesaje
- din 29 Aug 2008
- Signum 2006 Z19DTH
- Neamt
lucio
- Mesaje scrise: 783
- Masina: Signum 2006 Z19DTH
- Cont inregistrat: 29 Aug 2008
- bertone
- 2,294 mesaje
- din 13 Jun 2005
- buzau
bertone
danutz22 a scris:Ai mei caluti s-au nascut in august 2005 si au mers 120.000km, eu am luat-o la 104.000km din Germania.
In Romania daca ai masina in garantie te pune dealerul sa semnezi de injumatatirea intervalelor de revizie , dat fiind conditiile de trafic
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Signum 2005 Z19DTH 190CP
- Timis
tonytm
- Mesaje scrise: 4,479
- danutz22
- 189 mesaje
- din 27 Jun 2008
danutz22
- bertone
- 2,294 mesaje
- din 13 Jun 2005
- buzau
bertone
- lucio
- 783 mesaje
- din 29 Aug 2008
- Neamt
lucio
- bertone
- 2,294 mesaje
- din 13 Jun 2005
- buzau
bertone
- DB77AAA
- 6,715 mesaje
- din 19 Jan 2007
- Vectra 2005 Z19DTH 200CP
- Dambovita
DB77AAA
- Mesaje scrise: 6,715
Pai bre @bertone, dupa ce vei termina autonomia zisa de el, o sa-ti aprinda becul de la benzina intermitent. Mai ai ceva benzina, numa ca sa spunem ca e un fel de ultima avertizare. Pe undeva citisem ca e recomandat in astfel de situatii neaparat sa alimentezi , evitand astfel functionarea in gol sau cu goluri a pompei de benzina. Evident masina va functiona, dar pompa de benzina se va incalzi - gripa - arde.
- bertone
- 2,294 mesaje
- din 13 Jun 2005
- buzau
bertone
- poll_colin
- 31 mesaje
- din 17 Oct 2008
- Signum 2003 Y22DTR
- Bistrita-Nasaud
poll_colin
- Mesaje scrise: 31
- Masina: Signum 2003 Y22DTR
- Cont inregistrat: 17 Oct 2008
- lucio
- 783 mesaje
- din 29 Aug 2008
- Neamt
lucio
- danutz22
- 189 mesaje
- din 27 Jun 2008
danutz22
- msv_64
- 862 mesaje
- din 27 Jan 2008
- Vectra 2005 Y20DTH
msv_64
- Mesaje scrise: 862
- Masina: Vectra 2005 Y20DTH
- Cont inregistrat: 27 Jan 2008
