[quote="nilf40f"]
costygsm a scris:Salut,am niste erori la diagnosticarea unui Astra H 1.7 CDTI cu op-com si as vrea sa stiu ce inseamna ele si cum se pot rezolva
Ai aflat ce inseamna codul urmator?
B1016 - Vehicle Identification Number Not Programmed
(00) - Intermittent
Nu e asociat cumva cu Insp4 pe bord? Ai avut cumva apa in filtrul de motorina?
Salut
Chiar are legatura B1016 - Vehicle Identification Number Not Programmed cu apa in filtrul de motorina? Si eu suspectez carburantul, ca a inceput sa mearga cu hacuri la ceva vreme dupa ce am alimentat.
Nu mai trage si se aprinde masina cu cheie (la inceput rar si reprize scurte) acum aproape continuu.
Si intra turbina ca nebuna. (Z19DTH)
Am mai gasit:
ECN 050074 - Vehicle Speed Sensor (VSS) Error = > P0500Â
P0500Â - Vehicle Speed Signal not plausible with Engine Speed and Injection Mass:Â
The control unit receives the following signal not or wrong:Â
Vehicle Speed Input SignalÂ
orÂ
The fuel consumption is too high for the corresponding power output.Â
P0500Â - Vehicle Speed Signal Range/Performance:Â
ECN 161450: problem with communication between immobiliser and key- transponderÂ
Multumesc
