- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- Mesaje scrise: 5,916
- Masina: Corsa 2001 Z12XE
manea1517
- Mesaje scrise: 32
- Masina: Zafira 2012 a20dth
- Cont inregistrat: 03 Jan 2016
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
manea1517
- Mesaje scrise: 32
- ginta alex
- 3 mesaje
- din 16 Nov 2016
- Astra 2011 A20DTH
ginta alex
- Mesaje scrise: 3
- Masina: Astra 2011 A20DTH
- Cont inregistrat: 16 Nov 2016
Zahadum
- Mesaje scrise: 20
- Masina: Astra 2005 Z17DTL
- Cont inregistrat: 24 Jun 2016
Salut Alex
Numar sasiu W0LPD8EN7B8101559
Cod model 0PD35
Caroserie D35
Cod pachet M7J2
An model 2011 (A)
Data fabricatie 17.05.2011
Prima inmatriculare 01.06.2011
Cod motor LBS
Cod cutie de viteze MYJ
Tip motor A20DTH
Serie motor 17722388
Cod culoare GBG
Tapiþerie TADB
Caracteristicã Denumire
01A TRIM COLOR SEAT JET BLACK
1AB TRIM COLOR DR PANEL JET BLACK
2BQ MOLDING DOOR INTR SILVER DUST
4AA INTERIOR TRIM JET BLACK
5EA EQUIP. PACKAGE, CO2-REDUCTION
6X1 COMP FRT LH NON-COMP. SEL SUSP
7X1 COMP FRT RH NON-COMP. SEL SUSP
8X2 COMP RR LH NON-COMP. SEL SUSP
9X2 COMP RR RH NON-COMP. SEL SUSP
A53 SEAT ADJ, PASS, MANUAL 6 WAY
A64 SEAT RR SPLIT, FOLDING, 40/60
A69 RESTRAINT SEAT BELT TENSIONER
A8Z ENHANCED SIGHT A. LIGHTING PKG
A9U SEAT BACK ONE-TOUCH FOLDING
AE4 SEAT FRONT BUCKET SPORT
AEF POW. WINDOWS PASS,EXPR,UP/DOWN
AER POW. WINDOWS, RR, EXPR UP/DOWN
AFA INTERIOR TRIM CONFIG #1
AH4 8-WAY MAN SEAT ADJ, DRIVER
AHC CONTROL SEAT, MAN CUS EXTN DR
AHF CONTROL SEAT,MAN CUS EXTN PASS
AHN RESTRAINT PROVISIONS LATCH
AHS RESTRAINT HEAD, FRT SEAT, UP/D
AJT RESTR.PROV. CARGO,NET,TIE-DOWN
AKO WINDOW TYPE PRIVACY
AKW WINDSHIELD TYPE TINTED
AL9 CONTROL SEAT POWER LUMBAR DRIV
AP9 SAFETY NET
AQP REAR CENTER HEADREST
ASV EQUIPMENT SENSOR AIR MOISTURE
AT9 CONTROL SEAT POWER LUMBAR PASS
AWO RESTR.SYS.RR SEAT BELT,3P CENT
AXG ELECTRIC WINDOW - ONE TOUCH
AXX VEHICLE TYPE - NOT REQUIRED
AYC AIRBAG,DR&CODR,FRT&SIDE&ROOF
B6U FLOOR LUGGAGE, ADJUSTABLE
B75 COVER LUGGAGE COMPARTMENT
BAH SECURITY IMMOBILIZATION, VAR.2
BX6 BREAKING POINT 2011 1/2 M.Y.
C1R ORNAMENT. INTR I/P ,JETBLACK
C25 WASHER + WIPER-BACK WINDOW
C32 REINFORCED HEATING, ELECTRIC
C49 REAR WINDOW-DEFOGGER
C95 LAMP INTR, RF, DUAL READING
C99 PASSENGER AIRBAG,MANUAL CUTOFF
C9D LAMP INTR, AMBIENT, CONSOLE
CE1 WIPER SYS, MOISTURE SENSITIVE
CE4 WASHER-HEADLAMP
CJ2 DUAL ZONE ELEC CLIMATE CONTROL
CT3 GERMANY-MANDATORY
D6I MIRROR I/S FRT VAN SUNSHADE DS
D75 HANDLE O/S, DR, COLORED
DBU CONSOLE FRT COMPT,FLOOR, ARM
DD8 MIRROR IS/RV, LT SENSITIVE
DP6 MIRROR HOUSING, PAINTED
DT4 ASHTRAY - LIGHTER
DVA INST. BLACK,BLACK/SILVER RINGS
DWE MIRROR L+R,RC,ELEC,HEAT,MANFOL
E17 BUMPER 2.5 MPH
E3C COVER EXHAUST, REAR PIPE
E94 COVER, RR COMPT, LOADING EDGE
EA1 POCKET, FRONT SEAT BACK, LH
EA2 POCKET, FRONT SEAT BACK, RH
EBY TRIM CLOTH, LACE
FBD TRIM DOOR CLOTH, ATLANTIS
FX3 VEH. STABILIZING SYSTEM (ESP)
FX4 AXLE RATIO - 3.35
GBG BLACK SAPPHIRE, MICA(G)
GNA CHASSIS EQUIP FRONT STRUT ASM
GNG CHASS. EQUIP,RR AXLE,WATT LINK
J60 ABS 16",FRT & RR DISC, POWER
J71 BRAKE PARKING POWER OPERATED
K34 CRUISE CNTRL, AUTO ELECTRONIC
K4F BATTERY LN4,AGM,12V,80AH
KB5 CONTROL ECM GRADE BRAKING
KC8 RECEPT. ELECTRICAL, LOAD COMP.
KCL HEATER DUCT, RR (2ND POSN)
KG9 ALTERNATOR-140 A
KL9 START/STOP ENGINE CONTROL
KTM KEY PRIMARY FOLDABLE ADD RIGID
LBS ENG-4 CYL 20L,DIESEL,TURBO HO
LHD LEFT HAND DRIVE
MDB MOLDING B/S UPPER BLACK
MM3 TRANS-MAN, MERCHANDISED EQUIP.
MYJ TRANS-MAN, 6-SP, F40,FWD
N34 STEERING WHEEL LEATH. 3 SPOKES
N37 MAN.TILT TELESCOPING STEERING
NE9 EMISSION-SYSTEM EEC 09
NJ1 POWER STEER,NON VARIA.RATIO,EL
OHA MODEL UPGRADE 02
PHOI SUB - PACK PHOi
PWX WHEEL 17x7, ALU, DESIGN 8
QZZ TIRES 225/50R17-94VBWR/STTLHW4
SRY SALESPACK ERGON.SPORT SEATS
T39 TURN SIGNAL LAMPS
T3N DAYT. RUNNING LAMPS,SEP CAVITY
T3U LAMP FRT FOG, ECE
T4F HEADL. HIGH INTENS DISCHARGE
T74 HEADLAMPS CONTROL AUTO, DELAY
T79 FOG LAMP, REAR
T95 HEADL. CONTR BEAM,DIRECTIONAL
TADB LACE JET BLACK
TQ5 CONTROL INTELLIGENT HIGH BEAM
TR0 LAMP INTERIOR,ROOF,RR,COURTESY
TR7 HEADLAMPS CONTROL LEV.SYS.AUTO
TS6 STOPLAMP, CENTER, HIGH MOUNTED
TSP ILLUMINATION PACK
TSQ LAMP PACKAGE, INTERIOR, DELUXE
TTW HEADL CNTRL AUTO ON-OFF TUNEL
TTX RADIO EQUIPMENT AUX CONNECTOR
U04 HORN SINGLE NOTE
U18 SPEEDOM. KM
U65 SPEAKER SYSTEM 7, PREMIUM
U68 INFORMATION-COMPUTER
UC3 CONTROL STEERING WHEEL, RADIO
UD5 SENSOR IND. PARKING ASSIST
UDC INFO DISPLAY ONE COLOR GRAPHIC
UDK COLOR INFO DISPLAY (CID)7"QVGA
UH0 INDICATOR SEAT BELT WARNING,LH
UH1 INDICATOR SEAT BELT WARNING,RH
ULS LOCK CONTROL STEERING COLUMN
UPJ WIREL INTERF SHORT RANGE SMS
US3 ANTENNA - Diversity
UXW RADIO,NAV,CD-ROM,CAF,USB,RSA
V2T LUGG. CARR. ROOF, POWDER COAT
V3X PAN. 1 LAYER PAINT SILVERDUST
V83 VEHICLE STATEMENT ECE ORG
VD1 PROVISION OPTIONS EUROPE
VHY PROTECTOR BODY SHEET METAL
VNF ISOLATOR, BATTERY
VRG V.A. ASM COCKPIT
VRH V.A. ASM STEERING COLUMN
VRK V.A. ASM ROOF TRIM
VRL V.A. ASM FRONT HORIZONTAL SUSP
VRM V.A. ASM FRONT VERTICAL SUSPEN
VRN V.A. ASM REAR SUSPENSION
VRR V.A. ASM TIRES & WHEELS
W4Y GEARING CODE
WGC EQUIP. RECEIVING UNIT, GPS
WTC TIRE & WHEEL INFLATOR KIT
Y67 DISPLAY REMINDER PACKAGE
Cod model 0PD35
Caroserie D35
Cod pachet M7J2
An model 2011 (A)
Cod motor LBS
Tip motor A20DTH
Cod culoare GBG
Tapiþerie TADB
AP9 SAFETY NET
CE4 WASHER-HEADLAMP
E17 BUMPER 2.5 MPH
LHD LEFT HAND DRIVE
T79 FOG LAMP, REAR
TADB LACE JET BLACK
U18 SPEEDOM. KM
W4Y GEARING CODE
- ginta alex
- 3 mesaje
- din 16 Nov 2016
- Astra 2011 A20DTH
ginta alex
- Mesaje scrise: 3
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- sergyu
- 324 mesaje
- din 13 Jun 2005
- Astra 2005 Z20LER
- Mures
sergyu
- Mesaje scrise: 324
- Masina: Astra 2005 Z20LER
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- sergyu
- 324 mesaje
- din 13 Jun 2005
- Astra 2005 Z20LER
- Mures
sergyu
- Tuzgureanu
- 31 mesaje
- din 30 Mai 2016
- Astra 2007 Z17DTH
Tuzgureanu
- Mesaje scrise: 31
- Masina: Astra 2007 Z17DTH
- Cont inregistrat: 30 Mai 2016
fl0r1n86
- Mesaje scrise: 1
- Masina: Astra 2006 Z13DTH
- Cont inregistrat: 14 Nov 2016
alentin
- Mesaje scrise: 10
- Masina: Vectra 2001
- Cont inregistrat: 22 Feb 2009
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
alentin
- Mesaje scrise: 10
- nick_florin
- 183 mesaje
- din 14 Feb 2008
- Astra 2002 Z16XE
- Cluj
nick_florin
- Mesaje scrise: 183
- Masina: Astra 2002 Z16XE
- Cont inregistrat: 14 Feb 2008
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- nick_florin
- 183 mesaje
- din 14 Feb 2008
- Astra 2002 Z16XE
- Cluj
nick_florin
ion-marin
- Mesaje scrise: 65
- Masina: Astra 1999 x17dtl
- Cont inregistrat: 28 Jan 2011
