Axxell
- Mesaje scrise: 63
- Masina: Astra 2007 Z16XEP
- Cont inregistrat: 20 Jan 2010
Eu am urmarit un ulei 5W-40 mai subtire si mai apropiat de un 0W-40, de obicei uleiurile 5W-40 au cSt @ 40ºC in jur de 85 si cSt @ 100ºC in jur de 14.
Wolf-ul folosit anterior de mine a fost WOLF VITALTECH 5W40 PI C3 si s-a simtit o diferenta cu motorul rece si iarna la frig fata de GM 5W-30
Specification level
ACEA C3-10
API SN/CF
BMW LONGLIFE-04
FOR D WSS -M2C917-A
GM dexos 2
MB 229.31
MB 226.5
PORSCHE A40
RENAULT RN 0710
RENAULT RN 0700
VW Approval 505 01
VW Approval 502 00
VW Approval 505 00
TYPICAL CHARACTERISTICS
Test Method Unit Average result
Density at 15°C ASTM D4052 g/ml 0.851
Kinematic viscosity at 40°C ASTM D445 mm²/s 84,7
Kinematic viscosity at 100°C ASTM D445 mm²/s 13,9
Viscosity index ASTM D2270 170
B.N. (HCLO4 method) ASTM D2896 mg KOH/g 7,5
Pour point ASTM D6892 °C -39
CCS viscosity at -30°C ASTM D5293 mPa.s 5970
Sulfated Ash ASTM D874 Mass % 0,8
Flash Point COC ASTM D92 °C 235
Engine A12XER
Capacity: Capacity 4 liter
Use Normal
Interval Change 30000 km-wtf ??!! / 12 months
65607: WOLF OFFICIALTECH 5W30 C3
21116: WOLF VITALTECH 5W40 PI C3
Asta ma batea gandul acum mai bine de 1 an sa-l folosesc in loc de GM 5W-30 daca tot era sa folosesc un 5W-30, e plin de aprobari
Specification level
ACEA C3-10
ACEA C2*
API SN/CF
BMW Approval LONGLIFE-04
GM Approval dexos 2
MB Approval 229.51
VW Approval 502 00
VW Approval 505 00
VW Approval 505 01
Density at 15°C ASTM D4052 g/ml 0.855
Kinematic viscosity at 40°C ASTM D445 mm²/s 67.1
Kinematic viscosity at 100°C ASTM D445 mm²/s 12.2
Viscosity index ASTM D2270 182
B.N. (HCLO4 method) ASTM D2896 mg KOH/g 7.2
Pour point ASTM D6892 °C -36
CCS viscosity at -30°C ASTM D5293 mPa.s 6280
Sulfated Ash ASTM D874 Mass % 0.77
Flash Point COC ASTM D92 °C 234
Si mai pusesem ochii si pe Havoline Ultra S SAE 5W-40 care merge si la A12XER si care are destule aprobari
Engine A12XER
Capacity 4 liter
Use:Normal
Intervals:Change 30000 km-wtf??!! / 12 months
Products:
Havoline Ultra S SAE 5W-30
Havoline®Ultra S SAE 5W-30 and 5W-40
ACEA C3
API SN/CF
Approvals :
BMW Longlife-04 (restricted to EU countries for gasoline cars)
GM Dexos 2®
Havoline Ultra S 5W-30 license number GB2C1202089
Havoline Ultra S 5W-40 license number GB2C1204089
Mercedes Benz MB-approval 229.51/229.31
Porche A40 (5W-40)
Renault RN 0700/0710 (5W-40)
Volkswagen 502 00 / 505 00 / 505 01 (5W-40)
Performance :
Ford WSS-M2C-917A (5W-40)
Typical test data Test Test methods Results
Viscosity Grade SAE 5W-30 SAE 5W-40
Density, 15°C, kg/l ASTM D4052 0.850 0.850
Kinematic viscosity, 40°C, mm2/s ASTM D445 74.0 84.0
Kinematic viscosity, 100°C, mm2/s ASTM D445 12.3 14.1
Viscosity Index ASTM D2270 167 172
Pour Point, °C ASTM D5950 -38 -42
Flash Point COC, °C ASTM D92 232 232
Havoline nu da TBN si nici Sulfated Ash, dar zice ca e low saps " Formulated with synthetic base stocks and advanced additives with low levels of sulphated ash, phosphorus and sulphur, Havoline Ultra S is a low SAPS lubricant."
Ce nu-mi place la nici unul, inclusiv la Vatoil-ul actual este ca, niciunul nu da HTHS-ul si eventual si NOACK ca sa vedem cat de "performante" sunt aceste uleiuri ( la pret apropiat de GM-ul 5W-30 ) in comparatie cu cei cu renume care ofera aceste detalii.
Specification level
ACEA C3-10
API SN/CF
BMW LONGLIFE-04
FOR D WSS -M2C917-A
GM dexos 2
MB 229.31
MB 226.5
PORSCHE A40
RENAULT RN 0710
RENAULT RN 0700
VW Approval 505 01
VW Approval 502 00
VW Approval 505 00
Engine A12XER
Use Normal
Specification level
ACEA C3-10
ACEA C2*
API SN/CF
GM Approval dexos 2
MB Approval 229.51
VW Approval 502 00
VW Approval 505 00
VW Approval 505 01
Engine A12XER
Capacity 4 liter
Use:Normal
Products:
ACEA C3
API SN/CF
Approvals :
GM Dexos 2®
Porche A40 (5W-40)
Performance :
citu- Mesaje scrise: 59
- Masina: Corsa 2013 a12xer
- Cont inregistrat: 02 Apr 2015
daca sunt atat de multi posesori multumiti de gm dexos2, cu care au facut sute de mii de km, de ce sa nu incercam si altceva?
inca nu l-am pus in motor, vatoil syngold 5w40, dar cat de curand fac schimbul.
castrol edge are 13 *C vascozitatea la 100*C, dar punctul de aprindere e mic si castrol ramane totui cel mai blamat ulei de motor.
Axxell
- Mesaje scrise: 63
Salutare,
@citu
Intr-adevar Castrol recomanda si pentru motorul meu Z16XEP si pentru A12XER-ul tau EDGE 5W-40.
Daca ne uitam doar la vascozitatile la 40 si 100 grade e destul de interesant.
Kinematic viscosity la 40°C - 75 e comparabila cu un 0W-40 ceea ce e chiar foarte ok pentru un 5W-40. La Kinematic viscosity la 100°C - 13 se situeaza practic intre un 5W-30 si un 0W-40.
Cred totusi ca nu ar trebui sa-ti para prea rau dupa Castrol EDGE 5W-40 comparativ cu Vatoil SynGold 5W-40.
Castrol EDGE 5W-40
Density @ 15°C, Relative ASTM D4052 g/ml 0.85
Viscosity, Kinematic 100°C ASTM D445 mm²/s 13
Viscosity, CCS -30°C (5W) ASTM D5293 mPa.s (cP) 5800
Viscosity, Kinematic 40°C ASTM D445 mm²/s 75
Viscosity Index ASTM D2270 None 174
Pour Point ASTM D97 °C -42
Flash Point, PMCC ASTM D93 °C 202
Ash, Sulphated ASTM D874 % wt 0.8
Total Base Number -?!
VATOIL SynGold 5W-40
Density at 15 °C, kg/l 0,849
Viscosity -30 °C, mPa.s 4980
Viscosity 40 °C, mm²/s 79,40
Viscosity 100 °C, mm²/s 13,60
Viscosity Index 176
Flash Point COC, °C 232
Pour Point, °C -42
Total Base Number, mgKOH/g 7,8
Sulphate Ash, % 0,77
Exceptand valoarea vascozitatii la 40 grade unde Castrol sta mai bine, in general e sub Vatoil iar la unele ca flash point si TBN-ul "secret" e chiar corigent.
CCS viscosity at -30°C Vatoil care e un 5W-40, are o valoare un pic sub 5000 ! - nu am mai vazut uleiuri low-cost cu asemenea valoare, doar la unele uleiuri bune si foarte bune.
Asa ca la pornire iarna la ger, cred ca Vatoil se va comporta ceva mai bine ca nea' Castrol
Si sa nu uitam si pretul presupunand ca, Castrol nu e contrafacut, daca consideri si raportul performanta/pret intre cele 2 uleiuri nu cred ca mai ramane prea mult de spus.
PS Am tras cu ochiul si la Castrolul Edge 5W-40 anul trecut cand eram in cautarea "uleiului perfect" dar vazand pretul, caracteristicile si ceea ce imi spusese colegul opelvn ( atunci cand oscliam intre Wolf, Havoline si Vatoil si inclinam catre Havoline ), m-am linistit repede.
@citu
Castrol EDGE 5W-40
Viscosity Index 176
Pour Point, °C -42
opelvn a scris:Texaco-Havoline si Castrol dau cele mai slabe presiuni la cald comparabil cu multe alte marci, unele chiar marci mai mici fa un test in timp....Ieftin si bun din pacate nu prea exista ....
dediKATO
- Mesaje scrise: 43
- Masina: Astra 2008 Z19DT
- Cont inregistrat: 08 Mai 2012
Experienta proprie vis-a-vis de ulei motor:
Opel Astra H 1.9 CDTI Z19DT, an 2008, achizitionat sh in mai 2012. Schimbat distributia si ulei GM.
De la al 2-lea schimb, dupa ce am rasfoit precedentul topic despre uleiuri, am trecut pe mult luadatul Ravenol VMO 5w40. Am facut 2 schimburi cu acest ulei, la al 3-lea, in aprilie 2015, la indicatiile distribuitorului local, am trecut la Ravenol HLS 5w30, care ar fi mai bun si mai special pentru opel. La aproximativ 7mii de km facuti cu el, mi s-a aprins becul de nivel si a trebuit sa completez cam 200ml.Dupa alti 1000km, adica in prezent, iar mi se parinde becul de nivel, dar dupa ce parcurg cu ea cam 100km. Schimbul de ulei il fac cam la 7mii, acum am depasit cu 1000 pentru ca am avut alte pe cap si ..etc. Am fost la mecanicul meu, i-am explicat fenomenul, a scos joja, a verificat uleiul de pe joja si imi arata ca este putin aspru si se vad niste urme argintii prin el, pilitura sau ce este si trebuie sa trec neaparat pe alt ulei.
Deci, cam asta a fost si este experienta mea cu Ravenol.Ideea este: pe ce trec acum? GM ?
Multumesc!
Multumesc!
borsy- Suspendat
- 3,025 mesaje
- din 27 Mai 2013
- Insignia 2011 A20DT
- Alba
borsy- Mesaje scrise: 3,025
- Masina: Insignia 2011 A20DT
- Cont inregistrat: 27 Mai 2013
Nu stiu daca are vreo vina uleiul ca ai pilitura dar nu costa nimic sa incerci altceva. Evita uleiurile medii (GM, Wolf, Vatoil, Comma, Mobil Super, Castrol Magnatec, etc.). In cazul in care schimbi de doua ori pe an si nu depasesti 5k km la un schimb, te poti orienta si spre asa ceva, desi eu le-as evita.
In functie de regim te orientezi ca vascozitate (0w30, 5w30, 0w40, 5w40), exemple de uleiuri gasesti in topic, nu cred ca are rost sa ne repetam. Bafta.
dediKATO
- Mesaje scrise: 43
Masina am luat-o la 103mii si acum am 135mii, in timp de 2 ani+6luni.Schimb ulei maxim x2/an si dupa 7mii km.Mi-e mi-a mai spus un mecanic ca Ravenol nu rupe inima ragului si sa-l schimb, deci ar fi a 2-a persoana care imi recomanda sa schimb.Conform bancului cu betivu, cand 2 insi spun ca esti beat.. te duci si te culci.
Robert01
- Mesaje scrise: 20
- Masina: Astra 2012 A14NET
- Cont inregistrat: 09 Apr 2015
Salutare, ce ulei folositi pe timp de iarna pentru A14NET ? 1,4 turbo. Din cate stiu iarna trebuie pus un ulei mai subtire.. imi puteti recomanda cateva?
Deobicei la masina veche schimbam de 2 ori pe an uleiul.. odata la inceputul iernii si odata prin aprilie pentru vara. Venind dupa un motor 1.9 diesel nu prea ma pricep la motoarele pe benzina mai ales cele turbo.
Multumesc
Multumesc
Axxell
- Mesaje scrise: 63
Salutare,
@dediKATO
Nu ne-ai spus daca ai fost multumit cu RAVENOL VMO 5W-40 si daca ai avut probleme si cu el sau nu.
Dupa care ai trecut la un ulei mai subtire si cu flash point cam mic. Daca tot ti-a recomandat un 5W-30, n-am inteles de ce distribuitorul a recomandat a doua optiune ( RAVENOL HLS SAE 5W-30 ) pentru motorul tau si nu prima optiune RAVENOL LSG SAE 5W-30, recomandata de Ravenol.
Viscosity at 40°C mm²/s 67,0 DIN 51 562
Viscosity at 100°C mm²/s 11,7 DIN 51 562
Viscosity index VI 171 DIN ISO 2909
Flash point (COC) °C 210 DIN ISO 2592
Pourpoint °C -36 DIN ISO 3016
TBN mg KOH/g 7,2 DIN ISO 3771
Sulphated ash ?!
RAVENOL Longlife LSG SAE 5W-30
Flash point (COC) °C 234 DIN ISO 2592
TBN mg KOH/g 7,3 DIN ISO 3771
Sulphated ash %wt. 0,71 DIN 51 575
Daca nu ai avut probleme cu RAVENOL VMO 5W-40 si nu mai vrei Ravenol, cauta tot un 5W-40 C3 ( banuiesc ca ai DPF ) cu specificatii cel putin la fel daca nu poate chiar mai bune, de exemplu Viscosity at 40°C cam la fel sau mai mica, Viscosity at 100°C l cam la fel sau mai mare, Viscosity index VI sa fie macar 170-175 si Flash point (COC) minim 230.
RAVENOL VMO 5W-40
Viscosity at –30°C mPa.s 5800 DIN 51 377
Viscosity at 40°C mm²/s 83 DIN 51 562
Viscosity at 100°C mm²/s 13,8 DIN 51 562
Viscosity index VI 182 DIN ISO 2909
Flash point (COC) °C 225 DIN ISO 2592
Sulphated ash %wt. 0,77 DIN 51 575
Pourpoint °C -39 DIN ISO 3016
TBN mg KOH/g 7.7 DIN ISO 3771
Cred ca mai bine acum uiti de GM 5W-30, ca e subtire, la mine de ex. cu GM a consumat un pic intr-un an de zile mai ales ca vara la drum intins mergeam un pic mai turat, cu Wolf 5W-40 nu mi-a mai consumat vizibil, ma refer asa ochiometric pe joja.
Poti sa incerci intai cu uleiuri 5W-40 C3 la preturi de GM 5W-30, gen Vatoil, Wolf, Havoline, etc, dar sa nu le tii prea multi km.
Daca vrei ceva mai de firma si mai scump ai gen Motul, Valvoline, Mobil 1 ( 0W-40 ).
Si nu trebuie nici sa te iei neaparat dupa mecanici care stiu doar cateva marci de uleiuri "consacrate" si testeaza uleiurile cu degetele.
@Robert01
Daca vrei sa schimbi uleiul de 2 ori pe an, primavara si toamna, atunci poti sa folosesti iarna ulei mai subtire cu 30 in coada si vara ulei cu 40 in coada ( dar nu 10W-40, 15W-40 ), sau poti folosi un 0W-40 bun pentru tot anul, depinde acum si de cati km faci pe an, dar sa fie uleiuri C3 ca doar ai TWC.
Nu aveai turbo si la motorul de 1,9 diesel, sau era ceva gen VW SDI ?
Si daca ai GPL sa fi atent cand cauti pe site-urile fabricantilor de ulei, la uleiul recomandat pentru motorul tau, sa selectezi motorul cu varianta LPG.
@dediKATO
Sulphated ash ?!
RAVENOL VMO 5W-40
@Robert01
Robert01
- Mesaje scrise: 20
- ionutdanica
- 295 mesaje
- din 24 Aug 2014
- Astra 2006 Z19DTH
- Italia
ionutdanica
- Mesaje scrise: 295
- Masina: Astra 2006 Z19DTH
- Cont inregistrat: 24 Aug 2014
borsy- Suspendat
- 3,025 mesaje
- din 27 Mai 2013
- Alba
- ionutdanica
- 295 mesaje
- din 24 Aug 2014
- Astra 2006 Z19DTH
- Italia
ionutdanica
borsy- Suspendat
- 3,025 mesaje
- din 27 Mai 2013
- Alba
Borsy, Opel Romania recomanda la masinile noi revizia la 15 000 km cu banalul gm dexos2, pe mine ma ia groaza cand citesc ca uleiuri multe mai bune ca gm dexos2 sunt tinute intre 6/7000km. prea de tot, chiar asa motoare slabe echipeaza opelul masinile produse?...
apoi apar cei care folosesc uleiul gm regulat 300/400 000km si ne dau peste nas.
in alta ordine de idei am facut schimbul cu uleiul vatoil, nu constat mari diferente de comportament ale motorului, o idee pare mai silentios.
- Marius Popescu
- 700 mesaje
- din 27 Jun 2012
- Astra 2001 z16se
Marius Popescu
- Mesaje scrise: 700
- Masina: Astra 2001 z16se
- Cont inregistrat: 27 Jun 2012
@citu Eu nu am vazut pe forumul asta pe cineva sa afirme "eu am folosit numai ulei GM si am 400 000 km in bord " . Majoritatea de pe forum au pana in 250 000 . Iar o mare parte se vaieta de consumul de ulei , si au pana in 150 000 - 200 000 (asta in bord , dar e deja alta poveste ) .
Deci cine are km multi (macar 300 k), a folosit ulei GM si nu-i consuma ulei ? E cineva ?
Eu unul nu am citit asa ceva pe forumul asta . O fi , dar eu nu am vazut .
Scuze de off topic .
Numai bine !
Numai bine !
am citit pe fostul topic de ulei si am remarcat chestia asta. si chiar avea peste 300 000km fara probleme cu gm dexos 2.
nu asta e important, dar daca folosesc un ulei de calitate macar 15 000km sa nu ma doara capul.
eu am folosit masina si pentru serviciu, de asta si numarul de km, dar acum cam 10 000km/ an.
Axxell
- Mesaje scrise: 63
Salutare,
E o discutie intreaga despre " teoria conspiratiei" pe forumul cel vechi inchis, de exemplu:
N-am fost prea incantat de faptul ca si masina mea a mers primii 75.000km cu GM 5W-30 tinut 15.000km de fiecare data.
In ultimii ani eu consider ca o folosesc in regim destul de sever.
Severe service driving includes:
Frequent short trips (less than 16 km , especially during cold weather) - exceptand uneori vara, restul anului nu merg pe distante mai mari de 10km in oras intre opriri si porniri.
Stop-and-go city traffic driving - binenteles ca mai mult stop and go in oras.
Driving in dusty conditions (gravel roads, etc.) - aici nu teoretic, dar Bucurestiul e plin de praf.
Driving at sustained highway speeds during hot weather. - uneori dar nu pentru multa vreme.
Asa ca ar trebui sa nu depasesc 5.000km in regim sever si intr-adevar eu ma incadrez lejer si pot sa folosesc practic cam orice ulei de 100 ron bidonul mare, inclusiv GM-ul.
Daca borsy schimba uleiuri bune la maxim 7.000km, foarte bine, bravo, inseamna ca tine la motorul lui.
Sincer nici eu nu as tine acum un ulei mai mult de 10.000km in regim (semi)sever, chiar daca e tata uleiurilor de pe planeta - si ma refer aici la uleiuri de top, gen Red Line, Amsoil, Royal Purple, Penrite, Millers etc. si nu astea "clasice".
opelvn a scris:Acum dupa Euro 4 masinile se construiesc din proiectare cu viata mai scurta , castrare parametri calitate ulei, ulei mai putin in baie pe 100 cm cubi de motor, hths mic la ulei, temperatura f mare a lichidului de racire (vezi un termostat de Opel la cat lucreaza si unul de Toyota )(japonezii inca tin la calitate de aceea sant in top 10 la fiabilitate) , norme de constructor la ulei ce te tin captiv in uzura programata, sorb ulei subdimensionat (aduceti-va aminte cat era captarea la ulei la un sorb acum 15 ani , hartie de filtru cu microni multi filtrare mediocra 20 micron la masina de cetatean -10 micron la utilaje de ex....(costa mult agregatul), subdimensionari deliberate, lipsa ceas presiune ulei , si multe altele nu e cazul sa enumeram tot...
" Recomandat "nu inseamna cel mai bun inseamna cel ce te duce sigur 100% fara probleme peste garantie si inca un timp ca nr de km cat au fost programati de proiectare de constructor sant oameni ce vor sa mearga mai mult decat atat sigur pe planeta ........
borsy- Suspendat
- 3,025 mesaje
- din 27 Mai 2013
- Alba
citu a scris:Borsy, Opel Romania recomanda la masinile noi revizia la 15 000 km cu banalul gm dexos2, pe mine ma ia groaza cand citesc ca uleiuri multe mai bune ca gm dexos2 sunt tinute intre 6/7000km. prea de tot, chiar asa motoare slabe echipeaza opelul masinile produse?...
Si ce daca recomanda ei! Ei recomanda si kkatul de ulei GM, care e o porcarie, o nenorocire pentru motor coroborat cu un schimb la 15k km in regim mediu sau 30k km cu schimb LL.
Cei cu 3-400k km cu ulei GM, sunt exceptii care intaresc regula, dar nu e realitatea. Cum am spus de multe ori, bagati un ulei de calitate, schimbati la timp si o sa va scuteasca de multe probleme! Sunt multe uleiuri bune pe piata intre 140-180 lei! Va costa in plus 30-60 lei fata de o panarama, deci dpmdv cred ca merita efortul financiar.
Sau mergeti doar de 3 ori pe luna la spalatorie (in loc de 4) si gata, s-a rezolvat problema. Bafta.
