florinp13
- Mesaje scrise: 43
- Masina: Vectra 2006 z19dt
- Cont inregistrat: 18 Sep 2010
- lucio
- 783 mesaje
- din 29 Aug 2008
- Signum 2006 Z19DTH
- Neamt
lucio
- Mesaje scrise: 783
- Masina: Signum 2006 Z19DTH
- Cont inregistrat: 29 Aug 2008
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Signum 2005 Z19DTH 190CP
- Timis
tonytm
- Mesaje scrise: 4,479
Field Remedy: 1849
Subject: Engine Z19DT/H - Jerking
Models: Engines: Option:
Vectra-C 2004...2005,Signum 2004...2005 Z19DT| Z19DTH,Z19DT| Z19DTH
Complaint: Customer complains about a kind of jerking at steady state or at slight acceleration.
Cause: The problem is caused by high EGR-rate in combination with component tolerances.
Production:
Remedy:
In case of customer complaint reprogram the ECU with new software as of TIS 2000-CD, Version 67.
If the problem occurs with the new software again, contact ETAC for further information.
Please note:
A replacement of any parts (injectors, high-pressure pump, EGR valve, ECU, etc.)is not necessary.
FunctionalGroup: J - Engine
Complaint Group: 18 - Poor Drivebility
Trouble Code: None
Production:
Remedy:
Please note:
Trouble Code: None
florinp13
- Mesaje scrise: 43
- alexx1402
- 1,753 mesaje
- din 17 Aug 2010
- Astra 2017 B16DTH
alexx1402
- Mesaje scrise: 1,753
- Masina: Astra 2017 B16DTH
- Cont inregistrat: 17 Aug 2010
- Bryan99
- 1,147 mesaje
- din 02 Oct 2007
- Astra 2011 A1.7DTJ
Bryan99
- Mesaje scrise: 1,147
- Masina: Astra 2011 A1.7DTJ
- Cont inregistrat: 02 Oct 2007
Salut! Se pare ca am patit si eu aceeasi problema cu egr-ul , masina merge in suturi in treapta 1 si 2 , am pus Op-Com -ul pe ea si mi-a dat eroare egr.L-am dat jos l-am curatat era jale acolo pamant nu alceva , valva aceea mica din egr era blocata am bagat spray de curatare a iesit multa mizerie si apoi si-a revenit , inchide si deschide , l-am pus pe masina a mers bine ozi apoi i-ar a inceput sa traga in suturi , am pus din nou Op-Com-ul si numi da nici o eroare , am dat test la egr si imi arata MAF 28-29 , deci cred ca a ramas pe deschis sa blocat din nou , m-am uitat si la injectoare si injectorul 3 imi arata ca baga 2.87 , sa fie din cauza egr sau e si alceva ?
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
- Bryan99
- 1,147 mesaje
- din 02 Oct 2007
Bryan99
- Bryan99
- 1,147 mesaje
- din 02 Oct 2007
Bryan99
- Bryan99
- 1,147 mesaje
- din 02 Oct 2007
Bryan99
spike7you
- Mesaje scrise: 5
- Masina: Astra 2007 Z19DT
- Cont inregistrat: 27 Feb 2011
Si eu am aceeasi speta la astra mea, z19dt : dimineata am pornit si mi s-a aprins becul galben (MIL am aflat ca ii zice) si merea indacait, parca ar fi fost in 2-3 cilindri si era gata sa se si opreasca de vreo 2 ori daca nu ii dadeam niste sprituri.
Am plecat dupa cateva minute si nu trage deloc bine nici daca ii pun mod sport cand in mod normal ...
Am fost la test cu ea, eroare 2279 si baiatul m-a trimis la un mecanic.
Mi-a scos EGR-ul, era imbacsit cu mizerie neagra si dupa ce l-a curatat dar mi-a zis ca i s-a parut ca in timp ce il curata a observat ca valva aceea nu se inchide si ca scapa lichidul ala cu care el il curata.
Ce parere aveti ? Ce pot spera si ce pot face ?
- Bryan99
- 1,147 mesaje
- din 02 Oct 2007
Bryan99
spike7you a scris:Si eu am aceeasi speta la astra mea, z19dt : dimineata am pornit si mi s-a aprins becul galben (MIL am aflat ca ii zice) si merea indacait, parca ar fi fost in 2-3 cilindri si era gata sa se si opreasca de vreo 2 ori daca nu ii dadeam niste sprituri.
Pai vezi cum merge dupa ce la curatat , s-au cel mai bine o pui pe tester si faci un test la EGR sa vezi daca inchide si deschide , daca numai inchide inseamna ca trebuie sa-l schimbi , bafta si tine-ne la curent , salut
spike7you
- Mesaje scrise: 5
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
- sebi4fc
- 1,576 mesaje
- din 06 Apr 2009
- Vectra 2005 Z19DT
- Cluj
sebi4fc
- Mesaje scrise: 1,576
- Masina: Vectra 2005 Z19DT
- Cont inregistrat: 06 Apr 2009
florinp13 a scris:lumeeee am rezolvat cu masina cu intreruperile si cu suieratu cand reduceam
a trebuit sa imi faca la servis doar niste update si ga ta
nu era de la niciun egr de la nimic
Explici te rog cum se manifesta suieratu acela? il aveai si pe accelerare sau doar pe deccelerare se mai auzea daca scoteai la punctu mort?
florinp13
- Mesaje scrise: 43
florinp13
- Mesaje scrise: 43
pe accelerare nu aveam nimk merge normal cand reduceam incepea sa haraie si sa mearga intrerupt asa dar s-a rezolvat doar din calculator mi-a facut-o baiatu ala
a venit cu un aparat nu stiu ce era ca nu prea ma pricep a bagat o mufa la scrumiera acolo undeva dupa s-a dus la calculator si a copiat ceva a venit la masina a bagat iar mufa si a descarcat datele si a mers de atunci nu am mai avut nicio problema cu masina merge perfect
- ionut codreanu
- 117 mesaje
- din 12 Jan 2010
- Vectra 2006 z19dth
ionut codreanu
- Mesaje scrise: 117
- Masina: Vectra 2006 z19dth
- Cont inregistrat: 12 Jan 2010
salut,
la pornire dimineata imi tremura motorul si da sa se opreasca,iar in mers imi da socuri ca si cum nu se alimenteaza bine.Daca vreau sa o accelerez abia se ridica la 2000rpm.Initial am crezut ca e de la filtru de motorina. Am schimbat filtru de motorina si tot asa face.dupa ce am schimbat filtrul a mers bine cam 2 zile dar acum iar merge prost .azi s-a aprins martorul masina cu cheita care se stinge in mers iar martorul egr a ramas aprins
multumesc
multumesc
- Y-GreK
- 1,280 mesaje
- din 11 Jul 2007
Y-GreK
- Mesaje scrise: 1,280
- Cont inregistrat: 11 Jul 2007
Hmm...la mine statea aprins martorul de gaze evacuate si sta aprins si acum in timp ce e motorul pornit.EGRul l-am curatat si am mers cu eroarea in bord vreo 800km cu gandul ca senzorii vor depista faptul ca EGRul e in parametrii normali.Nu s-a stins si am sters eroarea cu ajutorul unui prieten prin OP-COM,dar a revenit.Problema e ca acum oscileaza,cand se aprinde masina cu cheita cand martorul de gaze evacuate.Nu am reusit nici acum sa depistez problema,ce poate fi?Masina trage bine de tot de cand am curatat EGRul,chiar nu are nici-o problema,sa fie bobina de vina?
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
