  3. Motoare diesel
  • nedelculeon
  • Mesaje scrise: 30
  • Masina: Astra 2003 y20dth
  • Cont inregistrat: 17 Mar 2010
Dupa mai multe incercari de a posta, am reusit in sfarsit.
Nu stiu daca valorile inregistrate se incadreaza in parametrii normali.Atasez rezultatele testului si astept pareri despre valorile inregistrate.
Measuring blocks information:
Battery Voltage 14.1 V
Ignition Status On 12V
APP at Idle Position (Accelerator Pedal Position) Inactive
APP Sensor 1 (Accelerator Pedal Position) 1.41 V
APP Sensor 2 (Accelerator Pedal Position) 0.70 V
Calculated Pedal Position 12%
Barometric Pressure 101 kPa
Barometric Pressure 4.13 V
Boost Pressure Command 125 kPa
Boost Pressure 102 kPa
Boost Pressure 1.64 V
Mass Air Flow Sensor 301 mg/strk
Mass Air Flow Sensor 2.58 V
Intake Air Temperature 35 °C
Intake Air Temperature 1.95 V
Coolant Temperature 80 °C
Coolant Temperature 1.20 V
Engine Oil Temperature 72 °C
Engine Oil Temperature 2.48 V
Fuel Temperature 43 °C
Brake Switch 1 Inactive
Brake Switch 2 Inactive 12V
Desired Engine Idle Speed 800 RPM
Engine Speed 1.812 RPM
Injection Pump Speed 905.44 RPM
Desired Injection Start 6.6 °CA
Actual Injection Start 6.9 °CA
Actual Injection Quantity 5.1 mg/strk
A/C Information Switch Inactive
A/C Relay (Air Conditioning) Active
A/C Load Signal (Air Conditioning) 19%
A/C Pressure (Air Conditioning) 538 kPa
EGR Valve (Exhaust-Gas Recirculation) Active
EGR Position Command (Exhaust- Gas Recirculation) 24%
EGR Pulse Ratio (Exhaust Gas Recirculation) 27%
EGR Feedback (Exhaust Gas Recirculation) Incorrect
Pulse Ratio Boost Pressure Solenoid Valve 54%
Swirl Level Control Solenoid Valve Pulse Ratio 4%
Pulse Ratio Throttle Control Solenoid Valve 5%
Outside Temperature Sensor_ 12 °C
Outside Temperature Sensor_ 2.34 V
Glow Time Relay Active 0V
Diagnosis Glow Time Relay Inactive
Glow Time Telltale Off
Malfunction Indicator (MI) Off
Service Vehicle Soon (SVS) Indicator ON
Vehicle Speed 0 km/h
Clutch Switch Inactive
Cruise Control Tip Switch Not Programmed
Vehicle Speed in Cruise Control Range Not Programmed
Immobiliser Function Programmed - - -
Security Wait Time - - -
  • DB77AAA
  • Mesaje scrise: 6,606
Si problema?
Erori ai stocate?
Ce ai aratat sunt valorile reale, ce arata ca ai nevoie de o curatare de admisie si chiar si de evacuare.
  • nedelculeon
  • Mesaje scrise: 30
Am o singura eroare P0400 - Exhaust Gas Recirculation Valve Feedback Signal Malfunction (09) - Not present
Admisia am curatat-o acum 10000 de km, eu cred totusi ca ar fi supapa egr care nu prea lucreaza cum trebuie, sper sa nu fie supapa ca e un sac de bani fiind modelul nou de supapa.
  • DB77AAA
Mai curata odata EGR. Verifica membrana din el daca tine vacumul sau incearca cu alt EGR de test.
  • nedelculeon
  • Mesaje scrise: 30
DB77AAA a scris:Mai curata odata EGR. Verifica membrana din el daca tine vacumul sau incearca cu alt EGR de test.
Am mai curatat egr, la mine nu e cazul de membrana, al meu fiind electronic, totusi am impresia ca nu mai ma duce mult, probabil inclina secera si ramane blocata.
In principiu valorile sunt bune?
  • DB77AAA
Corect. Daca este electronic nu ai decat sa incerci sa-l reconditionezi, sau daca nu, altul.
  • nedelculeon
  • Mesaje scrise: 30
Nu stiu cum sa o reconditionez, e destul de dificil de separat partea electronica de cea mecanica.O sa mai caut sa vad o modalitate de reconditionare.
Mersi oricum pt timpul acordat.
  • iriahu
  • Mesaje scrise: 261
  • Masina: Omega 1998 X25td
  • Cont inregistrat: 31 Mai 2008
Hi Nedelcu, nu iti este mare consumul global ? Cat ia la 100Km? Cati Km are masina ?
De cate ori ai reparat pompa ? Cam multe intrebari nu asa ?
Intreb mai ales pentru masuratoarea :Actual Injection Quantity 5.1 mg/strk
Cred ca 5,1 este tare mult ! Ar trebui sa fie pe la 3
Ce consum instantaneu ai la relanti ?
Stie cineva sa interpreteze toate masuratorile din aceasta testare a lui Nedelcu?
Este pe undeva scris care ar trebuii sa fie masuratorile ideale prescrise de fabricant ?
Numai bine !
  • raku21
  • Mesaje scrise: 519
  • Masina: Astra 2000 Y20DTH
  • Cont inregistrat: 30 Mar 2008
Trebuie sa fie intre 4 si 10 mg/strk
  • nedelculeon
  • Mesaje scrise: 30
iriahu a scris:Hi Nedelcu, nu iti este mare consumul global ? Cat ia la 100Km? Cati Km are masina ?
Numai bine !
Pompa nu am reparat-o niciodata de cand am masina(14luni), in momentul achizitiei masina avea in bord 166.ooo, nu cred ca sunt reali.
Asta vara(in concediu) am consumat in 125litri de motorina si am facut 2100 de km, mers si pe munte si pe autostrada.iese undeva la 6-6,5 litri, consum mixt.Nu pot sa iti zic cat consuma la relanti pt ca nu am BC.
Ce ai vazut tu, cantitatea de motorina injectata este la turatie de aproximativ 2000 de ture.
  • iriahu
Buna dimineata baieti, aceasta valuare a cantitati de motorina, stroke/gram, este direct legata de consumul de combustibil !
Prietenul Nedelcu o are acum de 5 la 2000 t/min . Dar poate poti face inca o data masuratoarea la RELANTI adica la 800-850 t/min.
Si un alt coleg este de parerea ca trebuie sa fie un nr. intre 4-10 . OK ! dar intre aceste valori pot fi multe reglari care dau si un consum diferit.
Nu a gasit nimeni scris pe TIS 2000 care ar trebui sa fie acesta valuare ? Sau poate in Auto Data ?
Nedelcu daca nu ti-e greu masoara si la relanti acesta valoare stroke/gram
La masina mea a fost de 7,2 si am crezut ca am o conducta de motorina sparta ! Asa se termina de repede motorina din rezervor. Cam 70 de litri pentru 350Km. Am inceput sa caut pana cand un destept mi-a spus "hai sa-i modificam pozitia capului" si am adus-o cam la 3,4 iar situatia s-a schimbat in bine.
Cred ca fabrica da niste propuneri de reglaj pe care profesorii dela garaj inca nu le-au descoperit.
Asa ca efortul nostru comun va fi spre binele tuturora .
Numai bine la toti !
  • nedelculeon
  • Mesaje scrise: 30
iriahu a scris:Buna dimineata baieti, aceasta valuare a cantitati de motorina, stroke/gram, este direct legata de consumul de combustibil !
Momentan nu mai pot masura nimic deoarece am trimis interfata op-com la reparat.Cand voi reintra in posesia ei voi face din nou masuratori si le voi posta.Numai bine tuturor.
  • raku21
@iriahu : Din tis am luat ...
  • iriahu
Hi Nedelcu, am citit inca o data toata lista de testare si ce vad? ca viteza motorului la care ai fact acest test era de 800 de ture si nu ce ai sustinut tu :2000
Asa ca inca mai suntem in ceata !?
Prietenul Raku25 , ce ai luat din TIS ? nu am inteles. Daca poti descarca pagina din tis cu aceste reglaje RECOMANDATE !
M-ar interesa si pentru omega 2,5td cu motor bmw ( typ motor X25TD). Poate poti scrie unde ai gasit acestea scrise. La ce capitol ,ce sub capitol ?
Sa poata gasi si alti prieteni ! Nu este nici-o crima sa ne informam uni pe alti . Pentru asta este internet !
Numai bine tuturora !
  • raku21
Vad ca nu prea stapanesti acesti parametri, nu este nici o crima. Engine speed este la 1.812 RPM. Am sa te rog sa imi dai si anul masinii sa pot identifica mai bine, iar despre tis s-a mai discutat ce si unde. Am sa revin cand ajung acasa acum sunt la o inmormantare.
Ps sa nu uiti sa imi dai anul fab.
  • nedelculeon
  • Mesaje scrise: 30
iriahu a scris:Hi Nedelcu, am citit inca o data toata lista de testare si ce vad? ca viteza motorului la care ai fact acest test era de 800 de ture si nu ce ai sustinut tu :2000
Tin sa te contrazic despre viteza motorului, ce ai citit tu
Desired Engine Idle Speed 800 RPM - este turatia de relanti
Engine Speed 1.812 RPM - turatia la care am facut testul.
  • raku21
Da corect. Desired e ce zice ecu ca trebuie sa fie la relanti.
  • iriahu
Hi baieti , o fi asa cum spuneti voi ! eu nu ma contrazic dar sunt dispus sa aud si sa invat.
Nu cred ca este normal sa spuna testerul ce ar vrea de fapt (sau ar astepta sa vada ) in timpul masuratorilor.
El citeste ceiace ECU "simpte" si afiseaza . Daca te axsezi pe un anumit parametru iti poate da plaja de masura (range) . Dar daca plaja este destul de larga ( cum spunea prietenul mai sus pe post 4......10strok/gr) atunci
dai cu banul pentru ceiace cauti ? Cred ca ar trebuii sa gasim cumva valori recomandate si sa incercam sa ne reglam masinile cat mai aproape de aceste valor. Nu asa baieti ?
Rakule spuneai ca este ceva scris prin Tis ? ! Afiseaza baiatule ! Nu te lasa ! Citeste Regulamentul!
  • raku21
Anul masinii ....
  • iriahu
Omega 2.5td model1998 typ X25TD
  3. Motoare diesel
