  2. Opel Mokka A/X/B
  • 195417
  • Mesaje scrise: 26
  • Masina: Mokka 2015 A17DTS
  • Cont inregistrat: 08 Aug 2010
Fa o conexiune din panoul de sigurante cu alimentare continua la bricheta si asa rezolvi problema. Eu asa am facut.
  • adisan2002
  • Mesaje scrise: 81
  • Masina: Mokka X 2017 B14NET
  • Cont inregistrat: 07 Mai 2008
Pai... asta caut.. siguranta cu alimentare continua 😊
  • yeti
  • Mesaje scrise: 408
  • Masina: Mokka 2016 B1.4NET
  • Cont inregistrat: 05 Nov 2006
Conform: http://www.vauxhall.co.uk/c...-january_2016.pdf pagina 180, versus http://www.vauxhall.co.uk/c...l-august-2016.pdf pagina 191, panourile de sigurante sunt aproape identice la cele doua modele Mokka. Deosebirile, le-am marcat cu rosu mai jos si in functie de nevoi, poti gasi ce te intereseaza pe oricare dintre variante.
Mokka ---- MokkaX
1 Body control module ---- 1 Body control module
2 Body control module ---- 2 Body control module
3 Body control module ---- 3 Body control module
4 Body control module ---- 4 Body control module
5 Body control module ---- 5 Body control module
6 Body control module ---- 6 Body control module
7 Body control module ---- 7 Body control module
8 Body control module ---- 8 Body control module
9 Ignition switch ---- 9 Ignition switch
10 Safety diagnosis module ---- 10 Safety diagnosis module
11 Data link connector ---- 11 Data link connector
12 Climate control ---- 12 Climate control
13 Tailgate ---- 13 Tailgate
14 Parking assist ---- 14 Central gateway module
15 Lane departure warning/Interior mirror ---- 15 Lane departure warning/Interior mirror
16 Adaptive forward lighting ---- 16 Adaptive forward lighting
17 Power window driver ---- 17 Column lock
18 Rain sensor ---- 18 Ultrasonic park assist module
19 Body control module/Regulated voltage control ---- 19 Body control module/Regulated voltage control
20 Steering wheel ---- 20 Steering wheel
21 AC accessory power outlet/Automatic transmission ---- 21 -
22 Cigarette lighter/DC accessory power outlet ---- 22 Cigarette lighter/DC accessory power outlet (front)
23 Spare ---- 23 Cigarette lighter/DC accessory power outlet (rear center console)
24 Spare ---- 24 Spare
25 Spare ---- 25 Telematics service module
26 Spare ---- 26 Heated steering wheel
27 Instrument panel cluster/Auxiliary heater/Clutch switch ---- 27 Instrument panel cluster/Auxiliary heater/Clutch switch
28 Adaptive forward lighting/Voltage converter/Headlamp switch ---- 28 Trailer socket
29 Spare ---- 29 Display/Infotainment system
30 Spare ---- 30 Transmission control module
31 Instrument panel cluster ---- 31 Instrument panel cluster
32 Infotainment system/Chime ---- 32 Infotainment system/Chime
33 Display/Infotainment system ---- 33 Trailer socket
34 Onstar UHP/DAB ---- 34 Passive entry/Passive start module
S/B Fuses
01 Spare ---- 01 Power seat switch
02 Spare ---- 02 Spare
03 Power windows front ---- 03 Power windows front
04 Power windows rear ---- 04 Power windows rear
05 Logistic mode ---- 05 Logistic mode
06 Spare ---- 06 Power seat switch
07 Spare ---- 07 Spare
08 Spare ---- 08 Spare
Ultima modificare făcută de yeti la Mar 20 Jun, 2017 11:46 pm, modificat de 3 ori în total
  • adisan2002
  • Mesaje scrise: 81
Multumesc, @yeti.
Da, asa pare, eu m-am uitat aici http://www.autogenius.info/...fuse-box-diagram/ (tablou identic, explicatii sigurante diferite).
Se pare ca era o alta editie de Mokka 😃
Multumesc mult pentru postare, am prins curaj sa testez camera pe siguranta 6 (Body Control Module). Aceste BMC-uri or fi identice ca functionare pe cele 2 versiuni de Mokka?
  • Partnoi Marcel
  • Mesaje scrise: 32
  • Masina: Astra 2008 Z14XEP
  • Cont inregistrat: 13 Nov 2016
Eu am facut o instaratie separata de cea a masinii,bineinteles inseriata cu o siguranta de 5 Amp. La unele masini pot aparea probleme la UCH daca pui consumatori suplimentari gen pom de iarna (de aceia iau foc).Treci doua fire de la baterie catre brichetã , imediat linga baterie pe plus pui o siguranta ,iar in habitaclu gasesti loc pentru un intrerupator.Sau poti lua tensiune de la memoria casetofonului care nu trece prin contact .
  • adisan2002
  • Mesaje scrise: 81
Multumesc. Am sa incerc pe F6 si F22, cu siguranta de 5A (prefer din panou, decat de la baterie).
  • adisan2002
  • Mesaje scrise: 81
Pot confirma acum, pentru toți cei interesați, cã pentru Mokka X alimentarea permanentã este sigur pe S / B02 și poate pe F10. De asemenea, pot confirma cã Mio Smartbox II (în opinia mea, cel mai bun kit de alimentare ca funcții comparativ cu prețul) a fãcut într-adevãr deconectarea camerei la valoarea selectatã a tensiunii (în cazul meu 12,2V). De asemenea, Samsung microSDXC EVO+ este un card compatibil, nu numai Transcend, dar NU recomand sub nicio forma Kingston (a generat mai multe erori). Testat pentru mai mult de 3 zile, 24 / 24h.
  2. Opel Mokka A/X/B
