  3. Sistem electric
  • cmarius53
  • Mesaje scrise: 452
  • Masina: Astra 2000 y20dth
Ptr. lecramluoar ia legatura cu userul catalinpav66.cere-i sfatul si vei vedea daca reusesti ceva.Spor.
  • marius popa
  • Mesaje scrise: 32
  • Masina: Astra 2005 z19dtj
  • Cont inregistrat: 17 Mar 2008
Poate ajuta pe cineva. Si eu am problema asta pe o astra din 2005 z19dtj (pleaca sindur radioul) si nu i-am dat de cap.
Field Remedy: 1979
Subject:Radio CD30/CD30MP3/CD50Phone
Flat battery due to self switching on of the radio Models:Enginesption:Astra-H 2004...2005,All 2005All,All
Complaint:Flat battery due to self switching on of the radio.
Cause:Malfunction of the "CD-In-Recognition" switch of the CD drive.
Production:Modified radio devices have been implemented as of: Astra-H (Bochum, Ellesmere Port, Antwerp): W0L0AHL3552121099 04.02.2005 W0L0AHL4858073270 07.02.2005 W0L0AHL4855140513 22.02.2005 VectraC, Signum (Rüsselsheim): ...51 083 965 28.02.2005 Combo C (Azambuja): ...53 039 620 28.02.2005 Corsa C, Meriva (Zaragoza): ...54 221 944 28.02.2005 Corsa C (Eisenach): ...56 071 222 28.02.2005 Agila (Gliwice): ...5G 070 084 28.02.2005
Remedy:
In case of customer complaint the radio has to be replaced by a modified device with a new designed "CD-In-Recognition" switch. New parts can be recognized on the manufacturing date on the housing. From CW 04/2005 on (FD 0405 on the label) the radios are equipped with a modified CD drive.
Note: Radios produced after mentioned breakpoint will not be accepted at radio-supplier and will be sent back to the dealer immediately.
FunctionalGroup:N - Electrical EquipmentComplaint Group:13 - No/Poor FunctionTrouble Code:
  • nicunicu
  • Mesaje scrise: 2,593
  • Masina: Zafira 2002 z16xe
se inlocuieste aparatu
  • T.ion
  • Mesaje scrise: 3,454
  • Masina: Zafira 2001 Z16XE
reset
Sa ai CAR PASS-ul pentru radio OK.
Scoti borna negativa 30 min, si o pui inapoi.
Si vezi.
  • Maryo78
  • Mesaje scrise: 119
  • Masina: Astra 2005 z14xep
  • Cont inregistrat: 08 Aug 2013
Si eu am avut aceeasi problema.Am fost la reprezentanta Opel Focsani si nu ia dat de capat,in Bacau am fost la mai multe service-uri la fel nici unul nu ia dat de capat.Am incercat tot felul de chitibusuri auzite pe la altii (sa ramana Cd-ul la inchidere in aparat: sa decuplez doar contactul de la cd aflat in interiorul aparatului si sa ramana functional doar radio),dar niciunul nu a functionat. Pana la urma am improvizat de la siguranta aflata in spatele aparatului 2 fire subtiri duse pana in torpedo unde am pus un mic intrerupator (pe unul din fire am pus cu pistolul de lipit o siguranta ) Si asa decate ori ma urcam in masina si vroiam sa folosesc aparatul,deschideam torpedoul conectam intrerupatorul si aveam muzica, la sfarsit inchideam iar intrerupatorul si asa am mers cam 1 an si jumatate fara a mai avea probleme. La un moment dat incepuse sa nu mai pot folosi butoanele de pe el unul cate unul pana nu mai mergea niciun buton. Atunci mi-a trecut prin cap sa sterg cu spirt integratul unde fac conexiune butoanele (asa facusem cand nu mai functiona telecomanda televizorului o desfaceam si o curatam si mergea fara probleme) am scos aparatul din bord l-am luat in casa si am dat jos fata aparatului (e prinsa in niste mici surubele) am curatat cu spirt integratul si butoanele de cauciuc, le-am pus la loc si acum in jur de 8 luni de cand dupa aceasta operatiune nu mi s-a mai aprins niciodata radioul in masina. (bineinteles ca am renuntat la acea modificare cu intrerupatorul).
  • marius popa
  • Mesaje scrise: 32
Multumesc pentru sugestii. O sa incerc si resetarea si stergerea contactelor butoanelor. Daca nu o sa mearga si va trebui inlocuit, nu va fi unul original. Nou cred e prea scump iar sh mi se pare riscant la electronice. Ma tot uit de ceva vreme la WITSON W2-D9823L.
  • sorinn89
  • Masina: Astra 2004 1,7 cdti
  • Cont inregistrat: 05 Dec 2016
Mare problema cu casetofoanele astea de pe opel astra h zici k sunt facute asa la vrajeala sau o alta chestie ar fi putut da ink un cd player de rezerva
  • sorinn89
Chiar sunt curios dak functioneaza chestia asta cu cd_ul introdus
  • jgyprime
  • Mesaje scrise: 9,929
  • Masina: Vectra 2005 Z19DT
eu de 6 ani de cand am masina cu cd30 (fara mp3) nu am avut niciodata problema asta...
cand il vedeti pornit, verificati sa nu fie afisat pe ecran "extern in".
daca e afisat "extern in" inseamna ca firul TEL-MUTE din spatele mufei ajunge (cumva) la masa.
eu am modificat cd30-ul meu si i-am pus un fel de aux-in pe intrarea de telefon.
aceasta intrare se activeaza punand firul TEL-MUTE la masa.
din greseala am lasat un fir care nu era izolat corect si accidental ajungea pe caroseria masinii, si culmea chestia asta se intampla doar cand era masina oprita.
l-am prins odata pornit si am vazut pe ecran "extern in".
am izolat toate firele corect si acum problema nu mai exista.
  • luxa
  • Masina: Zafira 2005
  • Cont inregistrat: 29 Mai 2017
Buna seara am si eu o prob asemanatoare poneste casetofonul singur la 30 de sec dupa ce scoti cheia scoate cd de navigatie si porneste pe radio sau pe cd sau chiar doar displaiul desi am umblat in setari Ignition logic On sau Off nu am reusit sa ii dau de cap porneste indiferent de ce setez .Multumesc anticipat
  • luxa
Buna seara . Am un opel zafira si de 2 zile ma confrunt cu o problema dupa 1 min de la scoaterea cheia din contact daca am cd introdus de navigatie il scoate afara porneste casetofonul sau radio sau doar dispaiul il opresc din buton si dupa alte 30 de sec sau un min porneste iar am scos borna sa nu raman fara baterie si am
  • luxa
Multumesc o sa incerc
  • lucian_c
  • Mesaje scrise: 21
  • Masina: Vectra 2005 Z19DTH
  • Cont inregistrat: 29 Jul 2015
Buna ziua,am o unitate audio CD30MP3 cu 6 butoane care a inceput sa nu mai citeasca cd-urile sau sa apara error cd,iar pe aceasta varianta nu cred ca se poate monta aux.As dori o recomandare la un modulator fm care sa se auda bine,mentionez ca am avut unul dar se auzea foarte incet.
Multumesc!
  • 34KLA
  • Mesaje scrise: 4,021
  • Masina: Corsa 2008 Z13DTJ
se schimba lentila cu una noua sau se face aux pe iesirea de telefon.
  • jgyprime
O mica corectie, aux pe intrarea de telefon (extern in)...
  • 34KLA
  • lucian_c
  • Mesaje scrise: 21
si sunetul nu va fi mono?
costul unei noi lentile care o fi?
  • jgyprime
intrarea va fi stereo, modificarea e de asa natura cat intrarea de telefon sa devina stereo.
de fapt integratul stie stereo dar blaupunkt l-a facut mono legand ambele canale de intrare in paralel ca sa se auda acelasi sunet.
spor la citit: https://www.clubopel.com/viewtopic.php?t=73566
am asa ceva de cativa ani pe masina si ma declar foarte multumit..
  • 34KLA
interzis
  • ionut870
  • Masina: Corsa 2008 Z14XEP
  • Cont inregistrat: 21 Jun 2022
Salut!
A mai intalnit careva ca unitatea sa-si piarda setarile de sunet la oprirea motorului?
De ficare data se pierd setarile de bass / inalte / fade / preset. Nu stiu sa fi umblat cineva la unitate inainte sa fie masina la mine.
Nici nu imi dau seama daca se pierd si alte setari odata cu astea. Cum pot sa verific si sa remediez problema?
  3. Sistem electric
