MITY 56
- Mesaje scrise: 3
- Masina: Astra 2006 Z13DTH
- Cont inregistrat: 06 Jun 2012
- BV19MAX
- 2,508 mesaje
- din 01 Aug 2007
- Astra Y17DT
BV19MAX
- Mesaje scrise: 2,508
- Masina: Astra Y17DT
- Cont inregistrat: 01 Aug 2007
MITY 56
- Mesaje scrise: 3
- BV19MAX
- 2,508 mesaje
- din 01 Aug 2007
- Astra Y17DT
BV19MAX
- iulian1971
- 7,038 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- Mesaje scrise: 7,038
P1901 Particulate Filter Pressure Sensor Low Voltage C-030
P1901 Particulate Filter Pressure Sensor Low Differential Pressure C-030
P1901 Particulate Filter Pressure Sensor High Differential Pressure B-056
P1901 Particulate Filter Pressure Sensor High Voltage C-030
P1901 Particulate Filter Pressure Sensor Range/Performance B-056
P2003 Particulate Filter Pressure Sensor Much too High Differential Pressure C-030
P1901 Particulate Filter Differential Pressure Signal not Plausible with Mass Air Flow C-030
P1901 Particulate Filter Pressure Sensor Hose Line Malfunction
In principiu poti curata DPF-ul cu spuma si jet puternic la spalatorie. Exista si varianta DPF off.
Gasesti explicatii pe forum.
Bafta.
- BV19MAX
- 2,508 mesaje
- din 01 Aug 2007
- Astra Y17DT
BV19MAX
