eu_adik_eu- Suspendat
- 29 mesaje
- din 20 Mai 2011
- Astra 2001
eu_adik_eu- Mesaje scrise: 29
- Masina: Astra 2001
- Cont inregistrat: 20 Mai 2011
- 29 mesaje
- din 20 Mai 2011
- Astra 2001
Pe diagnoza arata ca ele functioneaza , la fel si la maneta , cand apas imi arata in opcom ca functioneaza - apare ,,SET'' . Deci maneta da semnale . Ma gandesc sa nu fie vreun contact imperfect la pinii de la ecu sau pe fir pana la ecu. Vreau zilele astea sa ma apuc sa verific toate cablajele . Nu ma las pana nu il rezolv.
sh3rkhan
- Mesaje scrise: 67
- Masina: Zafira 2001 Z16XE
- Cont inregistrat: 18 Dec 2008
Sgura
- Mesaje scrise: 5
- Masina: Astra 2003
- Cont inregistrat: 05 Mai 2008
- 29 mesaje
- din 20 Mai 2011
- Astra 2001
Uite ce spune diagnoza :
Selected model>,2001,Astra-G,Engine,Z 16 XE
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0TGF4815075384
RepairShopCodeOrTesterSerialNumber: S001015423
ProgrammingDate: 20100401
systemSupplierECUHardwareNumber: DEL 0115351289
vehicleManufacturerECUHardwareNumber 09353489 BE
systemSupplierECUSoftwareNumber: DJTX
systemSupplierECUSoftwareVersionNumber: 0005
exhaustRegulationOrTypeApprovalNumber: D01004
systemNameOrEngineType: Z16XE
Identifier: 1594
CalibrationDate: P0201A07
Measuring blocks information:
Battery Voltage,14.0 V
Main Relay,Active
Fuel Pump Relay,Active
APP Sensor 1 (Accelerator Pedal Position),0.96 V
APP Sensor 2 (Accelerator Pedal Position),0.47 V
Calculated Pedal Position,0 %
APP at Idle Position (Accelerator Pedal Position),Active
TP Sensor 1 (Throttle Position),0.69 V
TP Sensor 2 (Throttle Position),4.33 V
Calculated Throttle Position,9 %
Throttle Position,Idle
Engine Speed,827 RPM
MAP Sensor (Manifold Absolute Pressure),1.17 V
MAP Sensor (Manifold Absolute Pressure),32 kPa
Coolant Temperature,3.39 V
Coolant Temperature,53 °C
Intake Air Temperature,3.86 V
Intake Air Temperature,17 °C
Tank Sensor,5.79 V
Tank Sensor,9 L
A/C Information Switch (Air Conditioning),Inactive
A/C Pressure (Air Conditioning),740 kPa
Brake Switch 1,Inactive
Brake Switch 2,Inactive
Clutch Switch,Active
Vehicle Speed,0 km/h
Cruise Control Tip Switch,Inactive
Cruise Control,Inactive
Vehicle Speed in Cruise Control Range,Active
EGR Valve (Exhaust-Gas Recirculation),Inactive
EGR Position Command (Exhaust- Gas Recirculation),0 %
EGR Position Feedback (Exhaust Gas Recirculation),1.59 V
Fuel Tank Ventilation Valve,0 %
Knock Control,Inactive
B1S1 O2 Sensor Heater (Bank 1 Sensor 1),Active
B1S1 O2 Sensor (Bank 1 Sensor 1),312 mV
B1S1 Air/Fuel Ratio (Bank 1 Sensor 1),Rich
B1S2 O2 Sensor Heater (Bank 1 Sensor 2),Active
B1S2 O2 Sensor (Bank 1 Sensor 2),828 mV
B1S2 Air/Fuel Ratio (Bank 1 Sensor 2),Lean
O2 Sensor Loop,Open
B1 Long Term Fuel Trim (Bank 1),2 %
B1 Short Term Fuel Trim (Bank 1),0 %
A/C Relay (Air Conditioning),Inactive
A/C Cutoff Mode (Air Conditioning),System OK
Malfunction Indicator (MI),Off
Service Vehicle Soon (SVS) Indicator,Off
Desired Idle Speed,825 RPM
Idle Speed Offset,Cold Start
Ignition Dwell Angle,1.9 ms
Injector Time,31 ms
Ignition Spark Angle,5.2 °CA
Knock Retard Cylinder 1,0 °CA
Knock Retard Cylinder 2,0 °CA
Knock Retard Cylinder 3,0 °CA
Knock Retard Cylinder 4,0 °CA
Ignition Status,On 12V
ETC Limp Home Mode (Electronic Throttle Control),Inactive
Total Misfire,0
Dec. Fuel Cutoff (Deceleration),Active
Fuel Tank Ventilation Valve,Inactive
Immobiliser Function Programmed,Yes
Security Wait Time,Inactive
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Identifier: 1594
Main Relay,Active
Tank Sensor,5.79 V
Tank Sensor,9 L
O2 Sensor Loop,Open
Injector Time,31 ms
Total Misfire,0
- 29 mesaje
- din 20 Mai 2011
- Astra 2001
Din pacate....dupa atata amar de timp....nu am reusit sa rezolv problema cu tempomatul. Nu imi pot da seama ce are. Este ciudat. Merge doar cand vrea. Am observat totusi ceva : Pornesc masina si merg cu ea cateva sute de metri , timp in care incerc butonul de la tempomat . Dupa cateva sute de metri de mers tempomatul porneste si functioneaza cat nu opresc motorul masinii. Am oprit masina pe dreapta , am asteptat 2 min , dupa care pornesc motorul si simptomele revin. Dupa cateva sute de metri tempomatul porneste. Parca ar fi o piesa defecta care necesita sa se incalzeasca putin , dupa care isi face treaba si pilotul intra in functiune. Gasisem in switch-ul de ambreiaj un transistor de pe placuta electronica care era spart. L-am schimbat si la fel face pilotul. Are aceleasi simptome . Daca e cineva din Iasi care cunoaste electrica de pe Opel cer ajutorul . Nu mai stiu ce sa fac. Din ce stiu eu este un moderator pe nume Dancuciureanu care se pricepe la Opel-uri si dupa nickname sta in acelasi cartier cu mine.
warlock23
- Mesaje scrise: 1
- Cont inregistrat: 03 Jun 2010
