  3. Motoare Benzina
  • petricavlad37
  • Mesaje scrise: 553
  • Masina: Meriva 2009 x16xep
  • Cont inregistrat: 17 Oct 2010
sal. Ptr X16XEL
  • Arruzzo
  • Mesaje scrise: 10
  • Masina: Astra 2000 X16XEL
  • Cont inregistrat: 09 Oct 2013
Multumesc frumos petricavlad!
  • Arruzzo
  • Mesaje scrise: 10
Intarzierile la cilndrii 2 si 3 sunt ok? La mine arata zero la toti 4.
  • petricavlad37
Uneori este doar la pistonul 3este o întârziere și de 8 grade,dar este ok și așa.
  • cipry
  • Mesaje scrise: 68
  • Masina: Astra 2001 z14xe
  • Cont inregistrat: 06 Sep 2008
salutare,pun si eu parametrii motorului meu Z14XE ,are momente cand nu trage in sarcina.clapeta,valva egr curatate,bujii cu 2 elementi GM noi.poate vedeti ceva suspect ca sa stiu de unde sa incep cu reparatiile .
-vad ca apar si 2 misfire ,de la ce ar putea fi?
Identifier: 1591
CalibrationDate: P0201A05
Measuring blocks information:
Battery Voltage,14.0 V
Main Relay,Active
Fuel Pump Relay,Active
APP Sensor 1 (Accelerator Pedal Position),0.96 V
APP Sensor 2 (Accelerator Pedal Position),0.47 V
Calculated Pedal Position,0 %
APP at Idle Position (Accelerator Pedal Position),Active
TP Sensor 1 (Throttle Position),0.45 V
TP Sensor 2 (Throttle Position),4.55 V
Calculated Throttle Position,4 %
Throttle Position,Idle
Engine Speed,802 RPM
MAP Sensor (Manifold Absolute Pressure),1.09 V
MAP Sensor (Manifold Absolute Pressure),30 kPa
Coolant Temperature,1.23 V
Coolant Temperature,89 °C
Intake Air Temperature,2.82 V
Intake Air Temperature,38 °C
Tank Sensor,6.49 V
Tank Sensor,6 L
A/C Information Switch (Air Conditioning),Not Programmed
A/C Pressure (Air Conditioning),0 kPa
Brake Switch 1,Inactive
Brake Switch 2,Inactive
Clutch Switch,Not Programmed
Vehicle Speed,0 km/h
Cruise Control Tip Switch,Not Programmed
Cruise Control,Not Programmed
Vehicle Speed in Cruise Control Range,Not Programmed
EGR Valve (Exhaust-Gas Recirculation),Inactive
EGR Position Command (Exhaust- Gas Recirculation),0 %
EGR Position Feedback (Exhaust Gas Recirculation),1.31 V
Fuel Tank Ventilation Valve,0 %
Knock Control,Inactive
B1S1 O2 Sensor Heater (Bank 1 Sensor 1),Active
B1S1 O2 Sensor (Bank 1 Sensor 1),69 mV
B1S1 Air/Fuel Ratio (Bank 1 Sensor 1),Lean
B1S2 O2 Sensor Heater (Bank 1 Sensor 2),Active
B1S2 O2 Sensor (Bank 1 Sensor 2),733 mV
B1S2 Air/Fuel Ratio (Bank 1 Sensor 2),Lean
O2 Sensor Loop,Closed
B1 Long Term Fuel Trim (Bank 1),11 %
B1 Short Term Fuel Trim (Bank 1),1 %
A/C Relay (Air Conditioning),Not Programmed
A/C Cutoff Mode (Air Conditioning),System OK
Fan Relay 1,Inactive
Fan Relay 2,Inactive
Fan Relay 3,Not Programmed
Malfunction Indicator (MI),Off
Service Vehicle Soon (SVS) Indicator,Off
Desired Idle Speed,787 RPM
Idle Speed Offset,Inactive
Ignition Dwell Angle,2.1 ms
Injector Time,2.2 ms
Ignition Spark Angle,4.2 °CA
Knock Retard Cylinder 1,0 °CA
Knock Retard Cylinder 2,0 °CA
Knock Retard Cylinder 3,0 °CA
Knock Retard Cylinder 4,0 °CA
Ignition Status,On 12V
ETC Limp Home Mode (Electronic Throttle Control),Inactive
Total Misfire,2
Dec. Fuel Cutoff (Deceleration),Active
Fuel Tank Ventilation Valve,Inactive
  • Marius Popescu
  • Mesaje scrise: 700
  • Masina: Astra 2001 z16se
  • Cont inregistrat: 27 Jun 2012
Mi se par ciudate (mici) timpul de injectie si avansul la aprindere .E mai util sa faci un log in timpul mersului , opcom stie sa verse valorile intr-un fisier.csv .
Bafta!
Acum vazui ca era activ dec. Fuel cut off si e normal ca t inj sa fie mic.
  • cipry
  • Mesaje scrise: 68
deci parametrii acestia (cu masina la relanti) ar fi ok?
  • Marius Popescu
Eu nu ma prind de nimic . Si nici nu cred ca se poate prinde cineva de defect , pt ca astea sunt niste valori luate in decelerare . In plus este o singura achizitie de date la un moment dat si nu se poate vedea evolutia lor .
  • cipry
  • Mesaje scrise: 68
Am inteles,multumesc pt raspuns.Am sa fac o programare la un service sa ii faca o verificare si sa ii rezolv si scurgerea de ulei ,tot picura pe undeva probabil pe la baia de ulei.
  • boggy84
  • Mesaje scrise: 10
  • Masina: Vectra 1998 Y20DTH
  • Cont inregistrat: 11 Sep 2012
Selected model>,2001 (1),Vectra-B,Engine,Z 16 XE
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0JBF3517022646
RepairShopCodeOrTesterSerialNumber: S000310256
ProgrammingDate: 20040109
systemSupplierECUHardwareNumber: DEL 0115351289
vehicleManufacturerECUHardwareNumber 09353479 BF
systemSupplierECUSoftwareNumber: DPAA
systemSupplierECUSoftwareVersionNumber: 0004
exhaustRegulationOrTypeApprovalNumber: D01005
systemNameOrEngineType: Z16XE
Identifier: 1583
CalibrationDate: P0201A09
Battery Voltage,14.1 V
Main Relay,Active
TP Sensor 1 (Throttle Position),0.94 V
TP Sensor 2 (Throttle Position),4.04 V
Calculated Throttle Position,16 %
Engine Speed,821 RPM
MAP Sensor (Manifold Absolute Pressure),1.27 V
MAP Sensor (Manifold Absolute Pressure),34 kPa
Coolant Temperature,3.43 V
Coolant Temperature,53 °C
Intake Air Temperature,4.00 V
Intake Air Temperature,14 °C
Tank Sensor,6.61 V
Tank Sensor,11 L
A/C Information Switch (Air Conditioning),Inactive
Brake Switch 2,Active
Clutch Switch,Inactive
Vehicle Speed in Cruise Control Range,Inactive
EGR Position Feedback (Exhaust Gas Recirculation),2.08 V
B1S1 O2 Sensor (Bank 1 Sensor 1),785 mV
B1S1 Air/Fuel Ratio (Bank 1 Sensor 1),Rich
B1S2 O2 Sensor (Bank 1 Sensor 2),0 mV
B1 Long Term Fuel Trim (Bank 1),30 %
B1 Short Term Fuel Trim (Bank 1),6 %
A/C Relay (Air Conditioning),Inactive
Desired Idle Speed,837 RPM
Idle Speed Offset,Cold Start
Ignition Dwell Angle,1.9 ms
Injector Time,36 ms
Ignition Spark Angle,6.2 °CA
Total Misfire,0
Immobiliser Function Programmed,Yes
  • Debonav
  • Mesaje scrise: 7
  • Masina: Astra 2001 Z16SE
  • Cont inregistrat: 03 Apr 2021
am si eu un csv atasat. ce ziceti?
  • Acidutzu
  • Mesaje scrise: 365
  • Masina: Astra 2004 Z16XEP
  • Cont inregistrat: 22 Apr 2015
Eu zic ca NU il ai atasat.
  3. Motoare Benzina
