  3. Vectra C/Signum
  • rebotea
  • Mesaje scrise: 28
  • Masina: Vectra OPC 2003
  • Cont inregistrat: 14 Apr 2013
Hi i´m tryng to program my front foglight but ist´s not working. what i´m doing wrong?.. before i have fog light´s now o whant´s to have again and only work in test mode.
i use
OP-COM 100219a - PC based diagnostic tool
Thank you.
ml
  • catastefan
  • Mesaje scrise: 5,917
  • Masina: Corsa 2001 Z12XE
UEC change Front Fog Lamps from not present to present .
Well done.
  • rebotea
  • Mesaje scrise: 28
when i try to program it´s not acessed.. is there a opcom new version for this?
Thank´s
  • catastefan
rebotea a scris:.. before i have fog light´s now o whant´s to have again and only work in test mode.
You desactivated the fog light?
You change the UEC?
Wich firmware and software version is your Op-com?.
Stable firmware is 1.39 in combination with software 08.2010.
  • jgyprime
  • Mesaje scrise: 9,911
  • Masina: Vectra 2005 Z19DT
you need to change the UEC with one that was from a car with fog lights (they are not the same, the ones that came wih cars that did not have this funciton are missing some electronic parts and the fog lamps will not light).
then you need to program front fog lights in UEC, BCM and Instrument (if you have the LED, if not there is no problem but when you have fog lights on you will not see anything on the instrument).
also you will need to change the controls that command the outer lighting with one that has the button.
check this topic: https://www.clubopel.com/vie...76804&start=0
some of the pics are missing...
the topic was complete some time ago...
  • rebotea
  • Mesaje scrise: 28
yes i desactivated the fog light because i had acident and i think i changed in the UEC but now realy it´s not activation but in test mode avething work´s pressing the front fog light nothing work´s
here is all the data include opcom soft https://drive.google.com/fol...M&usp=sharing
  • jgyprime
You need to check if the bcm is prgrammed correctly.
  • DB77AAA
  • Mesaje scrise: 6,604
OPcom 2010 can only change froglight in not present(if UEC can suport that function). After that, not can change in present that function. I try that, after I deactivated froglight whit opcom. Not work whith OPcom. Whith OPcom 2012 and also not work whith tech 2.
I fix it whith OPcom 2012.
Do you have OPcom 120309a? If not, I can give you that version - work fine whith 2010 hardware.
  • rebotea
  • Mesaje scrise: 28
Hi i don´t have is the softwre compatible with OP-COM china clone. Because some people say some version craches the interfaçe. Thanks
  • jgyprime
DB77AAA a scris:OPcom 2010 can only change froglight in not present(if UEC can suport that function). After that, not can change in present that function. I try that, after I deactivated froglight whit opcom. Not work whith OPcom. Whith OPcom 2012 and also not work whith tech 2.
depends on the firmware present on the car.
I changed the front fog lamps on my car with the "China Clone" version and did not have problems.
on another vectra c, almost identical to mine (another engine (z18xe petrol), but still the same year, the same month) I did not manage to change front fog lamps to present in BCM. UEC changed front fog lamps to present without problems...
@rebotea
I would advise you to check BCM and UEC and see if front fog lamps is enabled on both of them.
if not you shoud enable them both.
if op-com throws error when accessing "variant config" on any of them you should try some other software or another proigramming interface.
op-com might not be able to correctly program front fog lamps on your car.
  • DB77AAA
Jgyprime, din ce inteleg eu, a avut UEC cu functie de proiectoare pe care lea deyactivat cu OPcom 2010. Probabil va reusi sa le reactiveye cu o versiune mai noua. Acelasi lucru l-am facut si eu pe fosta Vectra, la fel, cu OPcom 2010 deyactivat, nu au mai mers activate nici cu Tech 2, nici cu OPcom 2010. Pana la urma a mers cu OPcom 2012.
Rebotea, I send PM whith 2012 software.
  • jgyprime
Da, asa e, eu doar i-am zis sa verifice si in bcm sa vada daca e present functia.
Daca in bcm nu e present masina nu stie ca are buton in controale si deci il ignora.
Si dupa cum am zis eu pe masina mea am programat fara probleme si proiectoarele, si geamurile electrice spate, si cc...
Pe alte masini programam present functii, imi zicea ca s-a programat si cand intram din nou in modil aparea not present. Banui ca si la tine era ceva similar... si asta probabil din cauza ca op-com nu are tot ce ii trebuie pentru a programa acele functii...
Poti te rog sa imi trimiti si mie softul de op-com 2012? As vrea sa incerc sa-l decompilez sa vad ce iese din el...
  • rebotea
  • Mesaje scrise: 28
Thank´s work fine for me .
ML
  • flyer1sst
  • Mesaje scrise: 37
  • Masina: Vectra 2004 Z19DT
Vreau si eu OP-COM 2012 software tot pentru aceasta problema a proiectoarelor. Nu mai pot intra in REC si UEC. Recunosc ca m-a mancat in... Am incercat si cu TECH-2 si n-a mers.
Multumesc !
  • DB77AAA
Vezi PM
  • flyer1sst
  • Mesaje scrise: 37
Multumesc mult! A mers ! Le-am activat abia astazi pentru ca acum am facut rost de interfata. Problema e alta acum : nu mai merge senzorul de ploaie desi mergea inainte. Am umblat si in REC si in UEC; acum nu stiu ce sa ii mai fac. Mai bine intreb inainte !
Multumesc inca o data !
  • corsa.timis
  • Mesaje scrise: 490
  • Cont inregistrat: 29 Dec 2014
DB77AAA a scris:Vezi PM
Salut, am vazut subiectul din intamplare, dar daca tot sunt aici: poti sa-mi trimiti cumva si mie op-com 2012? Multumesc.
  • DB77AAA
Ai PM.
  • corsa.timis
Multumesc @DB77AAA, am primit-o de la colegul @catastefan.
Salut!
  3. Vectra C/Signum
