alecss- Mesaje scrise: 8
- Masina: Astra 1993
- Cont inregistrat: 03 Mai 2008
- murzick
- 1,007 mesaje
- din 10 Dec 2006
- Vectra 2001 Z18XE
murzick
- Mesaje scrise: 1,007
- Masina: Vectra 2001 Z18XE
- cashu21
- 231 mesaje
- din 24 Jan 2008
- Astra 2005 1.7 dtl
cashu21
- Mesaje scrise: 231
- Masina: Astra 2005 1.7 dtl
- Cont inregistrat: 24 Jan 2008
v_negus
- Mesaje scrise: 2
- Masina: Agila 2001
- Cont inregistrat: 26 Apr 2008
https://www.clubopel.com/lin.....hp?fileid=21496
https://www.clubopel.com/lin.....php?fileid=5544
This program's function is limited for 90 days.
Please type in the followings: Start button/Run/regedit/HKEY_CURRENT_USER/VBandVBA program settings/Code/datum(2005.12.31)and Pocet(max:100 starting-reset=0)
Description:
Available for most Blaupunkt Car radio's with fixed code numbers (cover models up to 2000)
BP part number:7 642 702 790 Serial number:BP2702Y1934286
BPX702X1934286 CODE: 7059
Note: OEM coded models - OPEL, NISSAN, BMW, Citroen, Renault , Mercedes (cover models up to 2000)
Attention: Opel radio like Car 300 Blaupunkt code like this:
Partnumber: 7 645 852 320 Serial number: GM1300S4210182
BPX852X4210182 CODE: 1097
Attention: The calculator don't support AUDI, Volkswagen OEM models
Attention: Calculate code number for OEM AUDI AUZ1Z4 (equivalence BP number BP4894) by next form:
405XXXXXXX, where first 3 digits 405 instead 894, last 7 digits factory number.
BPX894X4210182 CODE: 1616
Step 1 - Read Serial Number
Step 2 - Enter Serial Number
Step 3 - Get Code number
SUCCESE TUTUROR!
Description:
SUCCESE TUTUROR!
valll
- Mesaje scrise: 4
- Masina: Corsa 2001 Z10XE
petrecila a scris:@vallsecventa corecta este aceasta:
-pui contact (se va aprinde safe pe display)
-opresti radioul din butonul mare
-apesi AS si tii apasat
-pornesti radioul din butonul mare (nu slabesti AS)
-slabesti AS dupa confirmare "beep"
-trebuie sa apara "CODE" si dupa 3 sec 10----
De aici incolo stii. Vezi ca am scris la Agila.
Multumesc frumos pt raspuns.
Am incercat de zeci de ori si in toate modalitatile si tot nu reusesc, apare SAFE.
Ce solutie ar mai putea fi?
- murzick
- 1,007 mesaje
- din 10 Dec 2006
- Vectra 2001 Z18XE
murzick
valll
- Mesaje scrise: 4
Sunt de acord ca asa scrie manualul, dar nu este asa pentru ca din cate incercari am facut nu am reusit sa vad niciodata "CODE" pe ecranul acela. Tind sa cred ca butonul AS nu functioneaza.
Ce sa mai fac?
Existra vreo varianta sa introduc codul acela prin internediul softului de diagnosticare, adica sa merg la un service?
Ce sa mai fac?
- petrecila
- 1,096 mesaje
- din 25 Apr 2007
- Bacau
petrecila
- Mesaje scrise: 1,096
- Cont inregistrat: 25 Apr 2007
@valll spui ca ai incercat in toate modalitatile si nu ai reusit. Din pacate modalitatea este una singura, cea descrisa. Atat timp cat respecti cu strictete pasii ar trebui sa mearga. Spun asta, ca ai spus orice, numai ca ai eliberat AS dupa confirmare "beep" nu. Acest lucru este esential si nu ai sa obtii CODE pe display in veci. Ori daca scapi AS inainte de confirmare nu merge.
valll
- Mesaje scrise: 4
- petrecila
- 1,096 mesaje
- din 25 Apr 2007
- Bacau
petrecila
In urma discutiei la tf. cu @valll in aceasta seara, am fost surprins sa constat o situatie noua: omul stie codul, stie secventa de incarcare dar aparatul nu raspunde comenzilor. Aici se pare ca poate exista intr-adevar situatia stupida ca AS sa nu faca contact (eu personal sunt un pic sceptic). Problema care mi-o pun si care o pun si forumului este daca aparatul tine minte toate posibilele incercari nereusite in timp (situatie pe care nu am vazt-o scrisa in manual). Este vorba de Blaupunkt CAR 2003. A mai patit cineva? Cine stie unde gasim schema electrica a acestui radio?
Alex_xxl- Mesaje scrise: 9
- Masina: Astra 2005 Z17DTH
- Cont inregistrat: 30 Apr 2008
Razvan8
- Mesaje scrise: 1
- Cont inregistrat: 19 Mai 2008
virginel
- Mesaje scrise: 2
- Masina: Astra 2002
- Cont inregistrat: 22 Mai 2008
- Petrus
- 111 mesaje
- din 16 Mar 2007
- Astra 2000 Y20DTH
- Calarasi
Petrus
- Mesaje scrise: 111
- Masina: Astra 2000 Y20DTH
- Cont inregistrat: 16 Mar 2007
- lucian200ro
- 2 mesaje
- din 13 Mai 2008
- Astra 2001
lucian200ro
- Mesaje scrise: 2
- Masina: Astra 2001
- Cont inregistrat: 13 Mai 2008
[quote="Corneliu Panait"]Mai omule, opresti masina in parcare si scoti cheile din contact. Apoi apesi butonul de volum si pornesti casetofonul. il lasi asa toata noptea si dimineata o sa ai liniutele pentru cod. Crede-ma pe cuvant!!![/quot
salut..fratzilor asa am patzit si eu..tot de vreo saptamana astept sa-si revina,dar problema e ca noaptea cand il las deschis se opreste dupa 15-20 de minutecastetofonu cred ca are un safe ceva!
relu1406
- Mesaje scrise: 86
- Masina: Vectra 2003 Y20DTH
- Cont inregistrat: 17 Sep 2006
VECTRA C -2003 cd este CDR 2005 VDO (SIEMENS)
Mi-a aparut pe partea de sus a displayului MESSAGE, acolo unde era de obicei afisat postul de radio sau data cind cd era inchis. Nu raspunde la nici o comanda nici de oprire, volum,sau altele nimic. Ramine ecranul computerului aprins chiar daca incui masina. Inainte scoteam cheia din contact si se oprea. Am scos borna, introdus codul, l-a acceptat,a aratat ca isi cauta si memo posturile si apoi tot MESSAGE. am cautat, dar in afara de unul care avea aceeasi prbl., fara rezolvare nu am gasit.
