  • SSS_OEM
  • Mesaje scrise: 9
  • Cont inregistrat: 01 Nov 2012
Salutari,
Am cumparat un Astra H GTC 2006 cu motor 1.8i de 104 kw , 18xer cred ca este, si nu gasesc seria motor, ma poate ajuta cineva cu niste informatii?
  • jE
  • Mesaje scrise: 8,408
in talon/brief ai incercat?
poate daca detaliezi scopul demersului, te putem ajuta mai bine
  • SSS_OEM
  • Mesaje scrise: 9
Am cumparat masina de ceva vreme si nici nu m-a interesat seria motor ptr ca are inca Tüv si seria de sasiu corespunde... intamplator am citit ca niste colegi au avut probleme la rar in romania ptr ca aveau motoare cu seria goala, ca la motociclete ex.
Pe mine ma intereseaza sa aflu daca masina asta are sau nu are serie la motor si daca da unde se afla seria ptr ca eu nu am reusit sa o gasesc
Dupa vin Decoder arata asa:
VIN: W0L0AHL0865218290
Model: Astra h
Body type: 3-door hatchback
Made: 2006-06-30
Model for year: 2006
Made for: Germany (steering wheel on the left)
Factory: Antwerp, Belgium
Engine: Z18XER (petrol, 1.8 - 140 HP)
Colour: Magma Red, paint code: 79U
Engine number: 20HM5955
Serial number: 218290
1st registr. No.: DON-HK 222
Source: http://astra-3.pl/vin.php
Code=
Description
*** General information: ***
79U = EXTERIOR PAINT,SEE MODEL CATALOGUE FOREWORD PAINT CHART
BRE = IDENTIFICATION BREAKING POINT 2006 1/2 M.Y
CT3 = FOR GERMANY
FZM = LOW COST STRUCTURE FRONT ZONE MODULE
NC0 = EQUIPMENT,EUROPEAN UNION
Z1F = KM/H SPEEDOMETER
*** Drive (engine, transmission): ***
2H0 = C18SEL[2H0],Z18XER[2H0],A18XER[2H0] PETROL ENGINE
FX1 = AXLE FINAL DRIVE 3.94
M25 = MANUAL TRANSMISSION,5 SPEED,F17 TYPE
MM3 = USED WITH MANUAL TRANSMISSION
NT4 = EMISSION,EEC 05
*** Suspension and wheels: ***
6Y4 = SPARE WHEEL AND TYRE,DELETE
FE4 = SPECIAL RIDE AND HANDLING SYSTEM (IDS+)
G62 = 5 BOLT WHEEL FIXING
P38 = WHEEL,ROAD,ALUMINIUM,5 SPOKES,71/2JX18
QNA = TYRES,225/40 R 18-92W
WTR = TEMPORARY TYRE REPAIR
XJ2 = LOWERED SPORTS CHASSIS
ZQ8 = SUSPENSION SPORTS (INCLUDING: ESP, IDS, SPORT MODE SWITCH, SPORTS CHASSIS)
*** Glass and mirrors: ***
DDG = MIRRORS ELEC CONTROLLED WITH HEATING, MANUALLY FOLDING
DDU = EXTERIOR MIRRORS ELECTRIC CONTROLLED
DH6 = VISOR,SUN,WITH ILLUMINATED MIRROR,RH-LH
DP6 = MIRROR HOUSING, PAINTED
*** Lighting: ***
C95 = LAMP,ASSY,ROOF,WITH DUAL READING LAMP
CE4 = HEADLAMP WASHER
T96 = FRONT FOGLAMP
TR0 = LAMP INTERIOR,ROOF,REAR,COURTESY AND DUAL READING
TT2 = HEADLAMPS DIRECTIONAL,HIGH INTENSITY DISCHARGE,LOW BEAM XENON, HIGH BEAM XENON/HALOGEN
*** Bodycar: ***
B70 = PLATE DOOR SILL COVER
B86 = MOULDING BODYSIDE COLOUR
BD8 = MOULDING,ASSY.,ROOF,BODY COLOURED
BW7 = ORNAMENTATION EXTERIOR PILLAR APPLIQUE
D75 = HANDLE,ASSY.,OUTSIDE
TPV = GRILLE RADIATOR,BLACK,WITH CHROME BAR
VG9 = PROTECTION WAX
VQ9 = REMOVABLE TRAILER COUPLING
W7P = NAMEPLATE,SPORT
*** Interior: ***
2J1 = COVER,FLOOR INNER,STANDARD
80I = INTERIOR-BLACK
80X = BODY INTERIOR TRIM-BLACK
80Y = DOOR PANEL TRIM,BLACK
B4W = ORNAMENTATION INTERIOR, HEADLINER, CHAROAL
BLN = MOULDING DOOR INTERIOR,MAZE CHROME
BLP = INSTRUMENT PANEL MOULDING,MAZE CHROME
BS9 = SEAL PRIMARY, DOORS, LOWER
D18 = INSTRUMENT CLUSTER,BLACK,CHROME RINGS
DGZ = TRAY INSTRUMENT PANEL COMPARTMENT DIVIDER
DT4 = ASHTRAY AND CIGARETTE LIGHTER (SMOKERS PACK)
JF5 = USED WITH SPORT ALLOY PEDAL
LHD = LEFT HAND DRIVE
N35 = STEERING WHEEL,SPORT,LEATHER
PHQ = TRIM CLOTH, ALPHA SILVER/ELBA
T9M = ELBA TRIM
VK8 = HOLDER,EYE GLASSES
VU2 = PANEL CENTRE INSTRUMENT,MATT CHROME
*** Safety: ***
A88 = HEAD RESTRAINT,FRONT SEAT,ACTIVE
AJ0 = HEAD RESTRAINT,REAR,CLOTH,TWO
AY0 = AIR BAG,ROOF,FRONT
FX3 = ELECTRONIC STABILITY PROGRAM
JL9 = ABS
U07 = HORN,FANFARE
UD7 =
*** Multimedia: ***
TRP = FRAME,RADIO
UAH = INFOTAINMENT DISPLAY,GRAPHIC INFO DISPLAY (GID),VAR2
URA = RADIO CONTROL SWITCH
UW6 = SPEAKER,6
W1Y = FOR STEERING WHEEL RADIO OPERATION
WBE = EQUIPMENT RECEIVING UNIT,RADIO
*** Heating and air conditioning: ***
BA9 = COOL BOX
C68 = FOR ELECTRONIC AIR CONDITIONING
KCL = HEATER DUCT,REAR PASSENGER 2ND POSITION
UEC = SENSOR INDICATOR AUTOMATIC AIR RECIRCULATION
*** Equipment and comfort: ***
AE4 = FOR SPORT SEATS
AH3 = FRONT SEAT,DRIVER,MANUAL ADJUSTING
AHA = WITH ADJUSTABLE LUMBAR SUPPORT
AY5 = HEAD RESTRAINT,REAR,CLOTH,CENTER
ECA = FOLDABLE KEY
K34 = CRUISE CONTROL
NS1 = FOR REDUCED RACK TRAVEL
UJC = SWITCH SPORT MODE
*** Electrical system: ***
K60 = ALTERNATOR,100AMP
TN6 = BATTERY,55AH
UEQ = SWITCH BATTERY SHUTDOWN
  • tirnaveni
  • Mesaje scrise: 551
  • Masina: Astra 2008 Z17dth
  • Cont inregistrat: 25 Feb 2009
Nu o sa ai provleme eu la mine la satra h am trecut in carte fara serie .
  • SSS_OEM
  • Mesaje scrise: 9
Masina are 117.000km, am schimbat uleiul cu 5w30 si am demontat in service sitele de la electrovalvele ptr axe cu came....
La rece se aude inca cateva secunde zgomot de diesel..... pana urca uleiul
Cand accelerez la rece nu se aude nimic suspect, cand fac frana de motor intre 2000-800rpm se aude un cloncanit de supape.....
La cald se aude ciudat pana trece de 2000rpm, adica se aude ca un fel de diesel
Tinand cont ca dupa demontarea sitelor de la electrovalve nu s-a remediat problema trebuiesc inlocuite pinioanele de la axe cu came?
  • SSS_OEM
  • Mesaje scrise: 9
Multumesc ptr ajutor, am rezolvat
