- soorin2002
- 2 mesaje
- din 08 Apr 2016
- Corsa 2007 Z10XE
soorin2002
- Mesaje scrise: 2
- Masina: Corsa 2007 Z10XE
- Cont inregistrat: 08 Apr 2016
A mai intampinat cineva aceasta eroare C0551 ?
Am schimbat modulul ABS cu altul de la mana doua (are acelasi cod), am programat VIN-ul masinii cu OP-COM, resetat BCM,ECU...programat din nou, acelasi lucru > C0551.
DTC C0551 5A: Option Configuration Plausibility Failure
Read Info...
Identifier: 0x0580
VIN: W0L0SDL0876132696
Hardware number:65950402
System name: BOSCH ESP8.1
Part Number:13236013
Software version number: 6100118000000
Programming Date: 20070713
Hardware key number: *A:MFT-173
System description: BOSCH0300
Alpha code: AR
Manufacturing date: 20070621
Software Freeze Date: 26.09.2006
Total number of fault codes: 1
C0551 - <Unknown DTC>
(5A) - Present
pompa de ABS veche
ECU inited!
Read Info...
Identifier: 0x0580
Programming Date: 20070523
Hardware key number: *A:MFT-170
Alpha code: AR
Manufacturing date: 20070430
pompa de ABS noua
ECU inited!
Read Info...
Identifier: 0x0580
Alpha code: AR
- iulian1971
- 7,028 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- Mesaje scrise: 7,028
- soorin2002
- 2 mesaje
- din 08 Apr 2016
- Corsa 2007 Z10XE
soorin2002
- Mesaje scrise: 2
- iulian1971
- 7,028 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
janicahd
- Mesaje scrise: 34
- Masina: Astra OPC 2007 h
- Cont inregistrat: 20 Oct 2007
janicahd
- Mesaje scrise: 34
