  2. Opel Corsa
  3. Corsa D
  • costel opel
  • Mesaje scrise: 20
  • Masina: Astra 2000
Salut ,,nu am mai accesat de mult acest site dar vin cu o veste buna pentru posesori de corsa d Cititi va rog Este vb schimbare gratuita a coloanei de volan electrica ... incercati la orice dealer .. nr de buletin service 2031150 ...
  • danikon
  • Mesaje scrise: 432
  • Masina: Corsa 2008 z13tdj
  • Cont inregistrat: 23 Mar 2009
Salut
Se poate sa detaliezi te rog despre acest buletin ?
Unde ce si cum
Multumesc
  • costel opel
  • Mesaje scrise: 20
costel opel a scris:Salut ,,nu am mai accesat de mult acest site dar vin cu o veste buna pentru posesori de corsa d Cititi va rog Este vb schimbare gratuita a coloanei de volan electrica ... incercati la orice dealer .. nr de buletin service 2031150 ...
#2031150: Special Coverage Bulletin - Corsa-D Power Steering - (2016-09-09)
Models: MY 2007-2014 – Opel/Vauxhall Corsa-D
ConditionSome MY 2007-2014 Opel/Vauxhall Corsa-D might have a loss of power steering support and illuminating of the power steering control lamp in the instrument cluster.
Special Coverage AdjustmentThis special coverage covers the condition described above for a period of 10 years or 160.000 kilometers / 100.000 miles, whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership, free of charge.
Vehicles InvolvedAll involved vehicles are identified by Vehicle Identification Number on the Applicable Warranties section in GM Global Warranty Management system. Dealership service personnel should always check this site to confirm vehicle involvement prior to beginning any required inspections and/or repairs. It is important to routinely use this tool to verify eligibility because not all similar vehicles may be involved regardless of description or option content.
CorrectionIn case of customer complaint, replace the EPS steering column according to following service procedure.
Service Procedure 1. Replace the EPS steering column.
– see working procedure "EPS Steering Column, Remove and Install / Replace", group "M Steering / EPS Electrical Power Steering", Service Instruction Corsa-D. (Document Number 01601078)
Parts InformationSelect necessary parts from electronic parts catalogue.
Warranty Transaction InformationSubmit a transaction using the appropriate table below. All transactions should be submitted as a ZREG transaction type, with “Special Coverage” flag.
Labour Code
Description
Labour Time
9900383
Steering Column Replacement
1.2
Labour Code
Description
Labour Time
9900383
1.2
Bulletin Version
1
Bulletin Version
1
  • danikon
AI facut aceasta operatie?
Ai avut probleme cu coloana de directie? in acest sens ?
La mine se aude in troncanit in partea de jos spre caseta
  2. Opel Corsa
  3. Corsa D
