  2. Opel Zafira
  3. Zafira B
  • aniello
  • Masina: Zafira 2006 Z19DTH
  • Cont inregistrat: 07 Mai 2017
Good day, I'm new to the pear I read that there are people opel writing on, I wanted to ask for a opel zafira b with keyless go, i try to make a diagnosis but i do not read the line canb cockpit, i can only query motor, New, I thought she was locking everything up, there are all the alimitations, I've downloaded a schema but the part about the cim is not there, now I came to the rear module, where there are also the fuses, there are 4 cables Green, the first two should be the data line, but only on one there are data, though 1,3 volt voltage,
Opel I think works between 3 and 5volt, checked the continuity and there are no problems, I press when I press start stop button you feel the relay 'activate in the rear module, however the picture does not light up,
Someone has some more info, what if there were manual links to it
Thanks so much
  • Mesaje scrise: 7,022
Hi.
What are you using for diagnostic ?
  • aniello
Hello friend i use
Brembi
Bosch
Axone
This is the problem why you can only acces the engine.
You have to use Tech 2, MDI, Opcom or Vauxcom if you want to acces all the electronic modules.
  • aniello
For our info opcom of vauxcom
What is for miglior use?
Thanks
There are both ok if you buy quality interface not cheap China.
Try here:
http://www.ebay.it/itm/OPCO...:X~EAAOSwax5YzR-e
  • aniello
thanks
error with my strument brembi
u2139
u2141
u2116
b1375
Houston we have some problems:
U2116 CAN-Bus No Communication with IPC (Instrument)
U2139 CAN-Bus No Communication with CIM (Steering Column Module)
U2141 CAN-Bus No Communication with REC (Rear Electrical Centre)
B1375 Switched System Voltage (Ignition ON) Not Plausible with CAN Signal
If you have CAR-PASS try to reprogram IPC, CIM, REC. You`ll need a Opcom.
  • aniello
Hello Dear friend I bought op-com, and as you have indicated you can now enter the various control units, and at the end, communicate, reset and write everything, except key encryption, mistake me, bankruptcy, can you help me? I could also use teamview , Could you control it?
thank you so much
  2. Opel Zafira
  3. Zafira B
