  3. Vectra C/Signum
  • alex_paval
  • Mesaje scrise: 619
  • Masina: Signum 2005 Z19DTH
Buna seara dragi colegi ! Am achizitionat un Opel Signum 2005, 1.9 cdti, 150hp remapat la 190hp, totul a fost perfect la ea inafara de airbag. De cand am cumparat-o avea pictograma airbagului aprinsa mereu pe mini display ( nu martorul de airbag).Din discutiile cu fostul proprietar, mi-a spus ca anul trecut cand au fost ploile alea foarte mari, s-a infilitrat in masina multa apa. Din spusele lui, apa nu a ajuns la calculatorul de airbag. Si de-atunci a avut probleme cu airbagul. Am pus pe tester masina si mi-a dat erorile astea :
"OP-COM 100219a - PC based diagnostic tool
OP-COM - CAN Communication Window> 2005 (5)|Vectra-C / Signum|Body|SDM (Airbag)
Read Info...
Identifier: 0x0101
VIN: W0L0ZCF4851057956
Part Number:13170589
Software version number: 0C0C3303
Alpha code: DX
Total number of fault codes: 21
B0014 - Driver Side Airbag Squib Circuit Low Voltage
(02) - Not present
B0015 - Driver Pretensioner Circuit Low Voltage
(02) - Not present
B0016 - Driver Curtain Airbag Squib Circuit High Voltage
(01) - Not present
B0019 - Passenger Airbag Squib Circuit (Stage 1) High Voltage
(01) - Not present
B0021 - Passenger Side Airbag Squib Circuit High Resistance
(0D) - Not present
B0021 - Passenger Side Airbag Squib Circuit Low Resistance
(0E) - Not present
B0021 - Passenger Side Airbag Squib Circuit Low Voltage
(02) - Not present
B0021 - Passenger Side Airbag Squib Circuit High Voltage
(01) - Not present
B0022 - Passenger Pretensioner Circuit High Resistance
(0D) - Not present
B0022 - Passenger Pretensioner Circuit Low Resistance
(0E) - Not present
B0022 - Passenger Pretensioner Circuit Low Voltage
(02) - Not present
B0023 - Passenger Curtain Airbag Squib Circuit Low Voltage
(02) - Not present
B0023 - Passenger Curtain Airbag Squib Circuit High Voltage
(01) - Not present
B0032 - Rear Pretensioner Driver Side Circuit Low Voltage
(02) - Not present
B0051 - Squib Circuits Activated (Crash)
(00) - Present
B0670 - Airbag Telltale Circuit Malfunction
(00) - Present
B1000 - Replace Electronic Control Unit (ECU)
(39) - Present
B1000 - Trouble Code Memory Full
(4C) - Present
U2100 - No Communication with CAN-Bus (Low Speed)
(00) - Not present
U2139 - Invalid Data from CIM (Steering Column Module)
(00) - Not present
(7F) - Not present "
Am banuit ca sunt probleme la calculatorul de airbag si m-am dus cu el sa-l rescrie, astazi am reusit sa-l montez inapoi si tot aceste erori am. Acum banuiesc ca undeva exista o problema intr-o mufa, pentru ca nu functioneaza nici martorul de airbag (B0670). Ceasurile nu au niciun fel de problema, am refacut lipiturile pentru ca imi cadeau ceasurile, am verificat si becul de airbag impreuna cu rezistenta si nu sunt probleme. Rugamintea mea la voi este sa-mi dati niste informatii, in ce mufa sa umblu sa vad daca este vreun contact oxidat, ceva.... Din cate vad imi da ca nu comunica cu cimul si low can, de-aici si lipsa aprinderii martorului de airbag... Multumesc anticipat celor care ma vor ajuta.
  • alex_paval
Buna ziua dragi colegi! Am rezolvat problema cu aceste erori si cu ecu airbag. Solutia a fost sa cumpar un ecu airbag SH de pe o masina nelovita(sa nu contina crash data), m'am uitat dupa alpha code sa se potriveasca si codul GM. Nu a necesitat nicio programare, practic a fost "plug'n play". Dupa ce am montat ecu airbag, mi'au ramas 3 erori : b0670 cel cu martorul defect, si 2 erori de joasa rezistenta pe cartusele pirotehnice pt pasagerii spate. Am facut o cercetare si se pare ca acest calculator nu are programate cartusele pt pasageri spate,asa ca le'am deconectat si au disparut acele 2 erori. Iar cu martorul de airbag a fost lipsa siguranta F26 din panoul lateral de sigurante de la sofer. Acum mi se aprinde normal airbagul si se stinge, si mai nou vad ca si martorul motor se aprinde la contact. Sper sa ajute pe cineva !
  3. Vectra C/Signum
