  • kata-san
  • Mesaje scrise: 38
  • Cont inregistrat: 21 Jul 2005
Fratilor, este un nene care vinde o vectra din 97, cu motor de 1,8 si zice ca are 140 CP....nu precizeaza tipul de motor....
A existat vreo versiune de motor 1,8 cu puterea asta sau e vorba doar de un chiptuning? si daca e tunat motorul, stie cineva daca sunt probleme de fiabilitate? nu de alta, dar de la 115 CP la 140 CP e totusi ceva..... 😕
Ultima modificare făcută de kata-san la Mar 08 Nov, 2005 9:14 pm, modificat de 2 ori în total
  • VIPER
  • Mesaje scrise: 306
  • Cont inregistrat: 22 Sep 2004
Exista/a existat un 1.8 16V Ecotec-4 140CP.
Engine Specification
Engine, location: Front, transverse in front of axle, 7º 50' forward inclined
Cooling system: Liquid, sealed circuit
Cylinders, number: 4
Bore (mm) 80.5
Stroke (mm): 88.2
Displacement (cc): 1796
Compression ratio: 10.5: 1
Engine, type: In line; 5 main bearings
Cylinder block/ head, material: Cast iron/ aluminium
Camshaft (s), location: 2 overhead (DOHC), driven by toothed belt
Valve train: Hydraulic bucket tappets
Valve, arrangement: v; 4 per cylinder
Valve, adjustment: Automatic - hydraulic
Fuel system: Sequential multi point fuel injection
Ignition system: Electronic ignition map, ignition coil direct to spark plug
Fuel pump: Electric, in tank
Emission control system: 3 - way cat. conv. with 2 oxygen sensors
Output (kW/hp CEE at 1/min): 103/ 140 at 6300
Specific power (kW/l; hp/l): 57.3; 78.0
Max. torque (Nm at 1/ min): 175 at 3800
Specific torque (Nm/litre): 97.4
Mean effective pressure at max. power/ max. torque (kPa): 1092.4/ 1225.0
Average piston speed (m/ s): 18.5
Engine oil, capacity (l): 4.5
Cooling capacity (l): 5.9
Battery 12 V, capacity (Ah): 55
Alternator 14.2 V, capacity (W): 1420
Max. service interval: 20,000 miles or 1 year
Emission compliance: Euro 4
Engine mass (kg): tba
Charger system: n/a
Max. boost pressure (bar): n/a
Din pacate nu-i stiu codul...
  • zafirul
  • Mesaje scrise: 1,442
  • Masina: Zafira 2001 Z18XE
  • Cont inregistrat: 22 Apr 2004
nene viper,
pe zafira B (sa-i zicem asa...) exista motorizarea 1.8 140 CP.
citind ce-ai scris tu ca e euro4 si tinind cont de
a) 1.8 ecotec 16 valve z18xe- adeka motoru meu e euro 4
b) nenea voinea (de pe vw forum ) care face chiptuning poate duce motoru' de la pct. a la 139 CP
c) kata-san zice de o vectra din 97 😶
atunci eu as trage concluzia ca motorul respectiv e oareshcum tunat.... 😂 😂 😂
ar mai fi totusi o mica ciudatenie- eu am acum 170Nm; daca-as face chip tuning s-ar duce la 140CP (ma rog, aia 139 si ceva) dar cuplul ar urca -cel putin teoretic- la 186Nm. ma mira atunci datele pe care le-ai pus.. doar 175??..
  • LEXXX
  • Mesaje scrise: 1,019
  • Masina: Astra 2004 Z18XE
  • Cont inregistrat: 25 Jan 2005
Scuze ca ma bag Viper, dar motorul asta pe care l-ai prezentat aici a aparut anul asta, nicidecum in 1997. Sunt sigur ca nu a existat nici un motor care sa fi iesit din fabricile Opel cu specificatiile astea in 1997. Uite si un link: http://www.auto-report.net/...new-opel-1.8.html
  • VIPER
Va cred, eu nu am zis ca asta ar fi motorul in discutie... Asta am gasit la 1.8 140CP...
  • Bestie
  • Mesaje scrise: 69
  • Cont inregistrat: 06 Aug 2004
Este o vectra B argintie, cu niste jante CMS pe 17, ...folii, tobe Remus, si....pe spate unde ar fi trebuit sa scrie tipul motorului, scrie VTR COMPETITION. ?
Daca da, o stiu eu. Are un 1.8 16v, si are ~140 cp. Nu au fost masurati dar asa stiu de la fostul proprietar. Care a dat-o cam acum 2 luni. Voi unde ati vazut-o? Unde este anuntul cu ea?
  • kata-san
  • Mesaje scrise: 38
oameni buni, respectiva este intr-adevar o vectra argintie cu jante...., dar nush'de care...e anuntul pe autovit are poze, masina e din constanta... daca stie cineva ceva de ea, astept un sfat ca as cumpara-o... merci!
  • Bestie
  • Mesaje scrise: 69
da-mi si mie link-ul te rog, ca eu n-am gasit-o pe autovit. Si daca e aia, te pot pune in legatura cu fostul propietar, care-ti poate spune mai multe despre motor si despre masina , daca vorbim despre aceiasi masina....
  • kata-san
  • Mesaje scrise: 38
Vad ca anuntul a disparut...banuiesc ca i-a expirat valabilitatea...oricum, ti-l reproduc, caci i-am dat un print
"opel vectra berlina 2,0 I 140 CP argintiu,
rulaj 116.000 Km (yeah right), ..pe scurt toate dotarile + controlul tractiunii+ folie omologata+ jante si pneuri noi, tinuta in garaj...etc stare exceptionala, bla, bla..... domnul este din Constanta si se recomanda Simion, are adresa de mail "siticonstruct" ...s-ar putea sa fie pe firma masina....
Bestie, crezi ca e cea la care te referi tu?
  • kata-san
  • Mesaje scrise: 38
Oricum, cred ca ma duc sa o vad si va tin la curent apropos de motor.....
by the way, merci tuturor pentru posturi
  • kata-san
  • Mesaje scrise: 38
  • Bestie
  • Mesaje scrise: 69
anyway, stiam eu o vectra de 1.8 16v care avea ~ 140 cp. FARA chip. 😉
  • maiandrei
  • Mesaje scrise: 4,711
kata-san a scris:opel vectra berlina 2,0 I 140 CP argintiu
Pai ziceai ca e de 1.8
Zafirule, esti sigur ca Voinea iti poate da 23 CP in plus? 116-139... inseamna 20% in plus, la un motor normal aspirat ceea ce ar fi mijto, dar cam greu de crezut... de obicei se castiga 10%
  • LEXXX
in stage 2 se obtine mai mult de 10%, 139 de cai e plauzibil la motorul asta.
  • zafirul
maiandrei
am din fabrica 125... 😂 😂
cresterea la benzinare -se spune- e 10-12%
si atunci ma incadrez in procente...
ai mai postat tu pe undeva chestia asta, vezi ca au existat 2 modele de motoare de 1.8 (cel putin la zafira) unul de 116 si altul de 125...
mi se pare ca mai recent l-au cam "degradat" si l-au facut 122 pe asta din urma; asa am vazut pe niste oferte de vectra C si parca si zafira
(insa nu zafira B; facelift -cum a zis viper 👽)
  • Bestie
  • Mesaje scrise: 69
ce-l de care vb eu era cel de 125 cp, asa ca a fost dus in 140 destul de usor...vizibil (la motor) era doar admisia si evacuarea schimbata, dar mai avea si modificari in motor, dar pe care nu am reusit sa le aflu, pana sa o vanda... Am inteles ca masina era destul de capabila, de exemplu avea 4700 rpm la 200 kmh cu aerul conditionat dat drumul, si am inteles ca ii mergea pana undeva aproape de 6000 rpm
  • LEXXX
Daca nu ma insel e vorba de Z18XEL (116cp) si Z18XE (125cp), prezente de altfel si pe Astra si pe Vectra B iar Z18XE portat si pe Vectra C. XEL a fost primul aparut pe piata dintre acestea doua, in 2000 a aparut Z18XE, motoarele coexistand in oferta Opel pana prin 2002. Daca ma insel va rog corectati-ma.
  • Bestie
  • Mesaje scrise: 69
in 97 exista Z18XE. Si exista chiar si pe Astra F!!!
  • G_e_O
  • Cont inregistrat: 21 Sep 2005
Poate e putin abatut de la tema dar nu am unde posta asha ca vreau sa pun oo intrebare!
Ce prezinta motorul de pe Vectra 2000T cel de 204HP ! nu prea gasesc date tehnice despre el dar sunt curios sa aflu mai multe!
  • Bestie
  • Mesaje scrise: 69
Presuspun ca vorba de C20LET, nu? Adica cel de pe Vectra A, Calibra.... am dreptate? Pt la Vectra C de exemplu 2000 Turbo are doar 175 cp 😭
