cristichd
- Mesaje scrise: 63
- Masina: Astra 2001 Z16XE
- Cont inregistrat: 11 Jul 2010
- mishu_b
- 1,669 mesaje
- din 16 Jul 2007
- Astra 2000 Y20DTH
mishu_b
- Mesaje scrise: 1,669
- Masina: Astra 2000 Y20DTH
- Cont inregistrat: 16 Jul 2007
daca PICul e gol nu mai poti face scriere de fw prin USB.
ai nevoie de un BootLoader http://www.microchip.com/st...mp;redirects=icd3 si de fw (.hex) .
hex-ul il gasesti aici in forum ...
bafta
bafta
- ravenadrian
- 10 mesaje
- din 30 Oct 2010
- Astra 2004 Z17DTL
- Bacau
ravenadrian
- Mesaje scrise: 10
- Masina: Astra 2004 Z17DTL
- Cont inregistrat: 30 Oct 2010
- ravenadrian
- 10 mesaje
- din 30 Oct 2010
- Astra 2004 Z17DTL
- Bacau
ravenadrian
- Mesaje scrise: 10
nu folositi vatiantele de soft OP-COM in romana.
https://www.clubopel.com/lin...oducts/opcom.aspx
daca aveti antivirusul cu update la zi, o sa gaseasca in executabil un trojan.
asa ca aveti grija, NU FACETI CA MINE!
- pirvu_daniel
- 4,581 mesaje
- din 22 Feb 2008
- Dolj
pirvu_daniel
- Mesaje scrise: 4,581
AmaruL
- Mesaje scrise: 15
- Cont inregistrat: 12 Jul 2010
buna ziua am luat si eu prog OPComFUT si am dat la Firmware - Check Version/ID si uitati mai jos ce apare
"Number of interfaces: 1
Description: OP-COM USB V2
FTDI USB Serial: FTPSNO56
FTDI-ChipID ChipID: 0x1679BFC5
FTDI-ChipID Location ID: 0x15
O***M Serial-Number (calculated): JI3KY3DU
O***M FW UPdate Code (calculated): AKHNM6AV
Interface opened. Handle: 10108176
Baudrate 500kBit/s
Dataformat 8N1
Flowcontrol NONE
SetChars
Timeout 5 seconds
Set DTR and RTS Low = PIC Reset
DTR low
RTS low
Wait 1 second for reset
Set RTS High = PIC running
RTS high
Wait 1.5 second, so bootloader can start FW...
RX Buffer clear... OK
FW Versions- and Interface ID- request send.
Timeout - is your PIC empty? No Firmware?
Set RTS to LOW = PIC Reset
RTS low
Communication closed. Handle: 10108176"
Ce este de facut?
Multumesc
PS: Sunt din buc.
Baudrate 500kBit/s
Dataformat 8N1
Flowcontrol NONE
SetChars
Timeout 5 seconds
DTR low
RTS low
RTS high
RTS low
Ce este de facut?
Multumesc
PS: Sunt din buc.
- ravenadrian
- 10 mesaje
- din 30 Oct 2010
- Astra 2004 Z17DTL
- Bacau
ravenadrian
- Mesaje scrise: 10
- DB77AAA
- 6,715 mesaje
- din 19 Jan 2007
- Vectra 2005 Z19DTH 200CP
- Dambovita
DB77AAA
- Mesaje scrise: 6,715
AmaruL
- Mesaje scrise: 15
Florinkim
- Mesaje scrise: 10
- Cont inregistrat: 05 Dec 2010
Salutare, am si eu o intrebare, am cumparat o interfata de opel firmware 1.39, am pus opcom v908, a functionat, dar pe can nu vedea motorul, restul da, astazi am pus vcds si in timp ce se instala drivari imi vede interfata de opel ca ross tech, si nu opel v2 usb. Am reinstalat win si degeaba cand am pus interfata tot Ross Tech. Se mai poate remedia sau trebuie sa iau alta interfata.
- StefanTolos
- 4,224 mesaje
- din 23 Nov 2007
- Corsa 2018 B12XER
StefanTolos
- Mesaje scrise: 4,224
- Masina: Corsa 2018 B12XER
Florinkim
- Mesaje scrise: 10
- mishu_b
- 1,669 mesaje
- din 16 Jul 2007
- Astra 2000 Y20DTH
mishu_b
Florinkim
- Mesaje scrise: 10
Nu , am folosit softul care a fost cu interfata OP-Com 90...b, dupa care am incercat sa pun VCDS ultima versiune si am uitat ca am interfata in usb, si vad ca imi aparte langa ceas interfata Ross Tech instalation, si am incercat sa pun la alt laptop si tot de VW o vede. Am MPROG V2.8 dar nu stiu sa lucrez cu el daca imi puteti da un tutorial, va sunt recunoscator. Oricum interfata o luasem sa mearga pe opel mai noi dar nu vede Can la motoare.
- DB77AAA
- 6,715 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
Florinkim
- Mesaje scrise: 10
Da intradevar asa este, Op-com nu o mai vede de opel, vede Ross Tech de VW, pentru VCDS de VW foloseam interfata de BMW, care este din gama K-line si ISO, altfel o vedea VCDS. Am cumparat interfata de opel pentru ca este singurul soft care ard interfata de BMW daca este pus pe o masina mai veche, modele sub 2002. In situatia asta sunt crizat la culme, am reinstalat win pe laptop si am facut administrator separat pentru opel sa nu mai fac o alta gafa, vreau sa stiu cum naibi remediez asta: in programul de firmware imi spune ca este functionala, are toate codurile ok, dar la description apare Ross Tech hex-usb.
- DB77AAA
- 6,715 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
Florinkim
- Mesaje scrise: 10
- DB77AAA
- 6,715 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
Florinkim
- Mesaje scrise: 10
