- emy_dilau
- 204 mesaje
- din 22 Sep 2007
- Vectra 1998 X16XEL
- Bacau
emy_dilau
- Mesaje scrise: 204
- Masina: Vectra 1998 X16XEL
- Cont inregistrat: 22 Sep 2007
speeeed23
- Mesaje scrise: 2
- Cont inregistrat: 17 Sep 2011
Va salut !
Am incercat sa instalez IGO 8.4.3 pe un goclever 3535 urmand pasii prezentati la inceputul topicului insa primesc urmatoarea eroare:"Fatal error"
Initialization error: no language file were found !
Va multumesc anticipat pentru ajutor
''sys file''
folders]
[folders]
;app="%SDCARD%/iGO8" ; change this if applicable
sdcardpath="\Storage Card"
;exe=""
;data="\Storage Card\iGO8" ;custom,save
content="\Storage Card\iGO8\CONTENT"
;textures="custom"
;models="custom"
;secondary_root="IPAQ\NAV"
[map]
3d_scale_carmodel=1
3dcarsizemin=1500
3dcarsizemax=3000
3dcarsizemul=5500
[3d]
show_guidance_strip=1
show_guidance_arrows=1
guidancearrow_first_size=0.8
guidancearrow_first_alpha=24
guidancearrow_second_size=0.6
guidancearrow_second_alpha=14
[3d_config]
disable_roadsign_navigation_mode=0
roadsign_lines_per_screen=20
[roundaboutcam]
enabled=0
centery=20
[gps]
port=2
baud=4800
[sound]
ding=0
Ultima modificare facuta de speeeed23 la Sam 17 Sep, 2011 2:03 am
''sys file''
folders]
[folders]
;exe=""
;textures="custom"
;models="custom"
[map]
3d_scale_carmodel=1
3dcarsizemin=1500
3dcarsizemax=3000
3dcarsizemul=5500
[3d]
[3d_config]
[roundaboutcam]
enabled=0
centery=20
[gps]
port=2
baud=4800
[sound]
ding=0
speeeed23
- Mesaje scrise: 2
''sys.file''
folders]
[folders]
;exe=""
;textures="custom"
;models="custom"
[map]
3d_scale_carmodel=1
3dcarsizemin=1500
3dcarsizemax=3000
3dcarsizemul=5500
[3d]
[3d_config]
[roundaboutcam]
enabled=0
centery=20
[gps]
port=2
baud=4800
[sound]
ding=0
folders]
[folders]
;exe=""
;textures="custom"
;models="custom"
[map]
3d_scale_carmodel=1
3dcarsizemin=1500
3dcarsizemax=3000
3dcarsizemul=5500
[3d]
[3d_config]
[roundaboutcam]
enabled=0
centery=20
[gps]
port=2
baud=4800
[sound]
ding=0
- emy_dilau
- 204 mesaje
- din 22 Sep 2007
- Bacau
emy_dilau
- valeriu_48
- 285 mesaje
- din 27 Jan 2010
- Astra 2001 y 17 dti
valeriu_48
- Mesaje scrise: 285
- Masina: Astra 2001 y 17 dti
- Cont inregistrat: 27 Jan 2010
Mi-am cumparat un NorthCross E515, dar avea numai harta Romaniei, Mireo black edition. Datorita topicului am reusit sa imi pun iGO primo, cu hartile din 2011 si cu modificarile in sys aferente. Maine o sa verific si camerele fixe radar, dar mai mult ca sigur vor functiona si ele~ Multumesc emy_dilau si parvu_daniel! Recomand!
Amatori, daca urmati pasii, nu aveti cum sa gresiti.
c.apostol
- Mesaje scrise: 2
- Masina: Omega 2000
- Cont inregistrat: 16 Nov 2011
Am si eu un GPS NorthCross Escape 4345, am vrut sa pun IGO 8 si nu am reusit. Nu se conecteaza la sateliti. Te rog frumos daca vrei si daca poti sa-mi trimiti si mie sys cu care tie iti functioneaza. Sau daca te pot prinde pe mess... eu am id apostolcristi. Multumesc
cypryan112 a scris:Am un NorthCross 4345 si am urmat pasii de mai sus si imi da si mie eroarea cu ,,no language files were found". L-am instalat pe card ca el nu are destula memorie si am schimbat sys.txt cu adresa cardului. Dimensiunile ecranului sunt identice...deci nu am schimbat decat adresa. Vreo idee ceva? Multumesc anticipat
Iata ce scrie in SYS.txt
[folders]
content="NorthCross eSCAPE 4345\SDMMC\MobileNavigator\CONTENT"
NORTH CROSS ES 4345 [debug] smart_2d=1 slowsim=1 loop_sim=1 [tmc] port=0 speed=38400 [interface] mio=1 landscape=0 width=480 height=272 base="mio/480_272/" basel="mio/480_272/" [speedcam] usemio=-12,90,37,27
[folders]
- emy_dilau
- 204 mesaje
- din 22 Sep 2007
- Bacau
emy_dilau
c.apostol
- Mesaje scrise: 2
emy_dilau a scris:Daca nu se conecteaza la sateliti de ce va chinuiti neaparat cu SYS.TXT..
Iesiti afara 5-10 minute,duceti-va in meniu la Setari\GPS\Autodetectare ..si in 90% din cazuri aparatul isi va face singur setarile si ve-ti avea semnal satelit.
Am iesit. Degeaba. Se pare ca este o alta problema. Cu programul original (Cardinale) functioneaza totul corect, se conecteaza.... Dar as vrea sa pun IGO. Cu IGO pe card, ruleaza programul, dar nu se conecteaza la sateliti. Normal ca afara. Am intrat in configurare GPS unde imi da mesajul "Modulul GPS nu a fost gasit!"; este bifa pusa pe GPS activat. Si asta, repet, in conditiile in care functioneaza cu Cardinale. Chiar si pe autodetectare, chiar si cu acel baud (posibil sa scriu gresit) stabilit la o valoare gasita cu un programel... tot la fel e mesajul. M-am gandit ca poate acest model nu functioneaza cu IGO, dar am vazut ca la altii functioneaza. Daca ma poate ajuta cineva si pe mine... va rog... id-ul meu de mess este apostolcristi. Va multumesc
- AlaMicSiNegru
- 1 mesaje
- din 28 Nov 2011
AlaMicSiNegru
- Mesaje scrise: 1
- Cont inregistrat: 28 Nov 2011
Salutare,
Din pacate am probleme in a instala pe North Cross ES515 igo8
Desi nu sunt novice, totusi nu reusesc sa-l fac sa porneasca igo...
am intrat, am redenumit, am creat, am schimbat cand cu slash cand cu backslash cu unul cu doua backslash-uri... nimic. Nici diferentiere %SDCARD%, \ResidentFlash \dataFlash... NIMIC (
Am incercat si firmware update si nimic... adica am downloadat 515_A5.rar de la North Cross, dar nimic... pe site-uri nimic, pe northcross.ch nimic...
Deci, indiferent de setarile din sys.txt, imi apare fereastra de "config.navi" (adica sa introduc calea catre executabil). Nu pot sa modific, desi am si un microSD introbagat in device... nu stiu de unde sa-l apuc.
Ma poate ajuta cineva?
Multumesc anticipat
Multumesc anticipat
pirvu_daniel a scris:Eu am reusit sa instalez IGO ultima versiune in mai putin de o ora pe North Cross ES 515. Este un aparat extraordinar, slim, procesor puternic, memorie interna suficienta pentru a instala IGO in ea, suporta fisiere avi , rezolutie extraordinara etc etc. Cam astia ar fii pasii de urmat.
1. Pe CD-ul cu care vine aparatul instalati Microsoft Sync sau Windows Mobile 6.1. Eu am Windows 7 Ultimate si nu am avut nevoie de acest lucru avand deja Windows Mobile 6.1.
2. Aparatul vine cu cablu USB cu care se conecteaza la calculator.
3. Se cumpara ultima versiune de IGO(nu incurajam pirateria). Eu am folosit iGO 8.3.4.117940 with 2009.12 Europe Maps, Buildings, POI.
4. In My Computer in Mobile Devices se intra in Resident Flash unde se creeaza directorul blackedition.
5. In directorul blackedition se copiaza tot continutul IGO-ului. Aparatul are suficienta memorie pentru a putea copia si contentul IGO-ului. Nu am incercat sa folosesc microSD-ul datorita vitezei mai mari de acces la memoria proprie.
6. Se redumeste IGO.exe in blackedition.exe.
7. Pe masura ce apar harti mai noi, POI-uri etc. se pun prin simpla inlocuire a celor vechi in fisierul Content.
8. Cel mai greu a fost de modificat systext-ul. Dupa numeroase modificari el arata asa:
[folders]
content="\ResidentFlash\blackedition\CONTENT"
NORTH CROSS ES 515 [debug] smart_2d=1 slowsim=1 loop_sim=1 [tmc] port=0 speed=38400 [interface] mio=1 landscape=0 width=480 height=272 base="mio/480_272/" basel="mio/480_272/" [speedcam] usemio=-12,90,37,27
9. Daca aveti alt model de North Cross nu aveti decat sa modificati rezolutia conform cu a aparatului Dvs. la width, height, base.
Succes.
[folders]
Succes.
- emy_dilau
- 204 mesaje
- din 22 Sep 2007
- Bacau
emy_dilau
marieryro
- Mesaje scrise: 10
- Masina: Corsa 2007 Z13DTI
- Cont inregistrat: 08 Dec 2010
[folders]
Succes.
[folders]
Succes.
Nu reusesc sa gasesc sa modific systextul adica content="\ResidentFlash\blackedition\CONTENT" . Intru in My device\ResidentFlash si acolo nu este nici un fisier blackedition. Ce program sa folosesc sa pot vedea acest fisier? Eu folosesc CECMD pus pe aparat. vreau de fapt sa modific port-ul si speed . Sper ca ma poate ajuta cineva.
- emy_dilau
- 204 mesaje
- din 22 Sep 2007
- Bacau
emy_dilau
E vorba de fisierul SYS.TXT din folderul Igo .
Igo e kitul de soft pe care vrei tu sa il pui...
CECMD nu are nici o treaba cu ce vrei tu...sau de fapt ce vrei cu el..cum adica sa modifici portul si speed?
Tu ai copiat un kit de Igo?
NU cred ca ai inteles multe din tutorialul de mai sus.
Acest tutorial explica instalarea unui alt soft(in speta Igo) pe aparatul Northcross.
zeusz4u
- Mesaje scrise: 2
- Cont inregistrat: 08 Dec 2011
Buna ziua toti,
Saptamana asta mi-am cumparat si eu un GPS NorthCross ES 515, fara soft si fara harti.
Am reusit (multumiri lui Daniel) sa pornesc iGO 8 pe acest GPS (am avut niste dificultati la inceput, dar in sfarsit am resuit sa-l fac sa mearga).
Mi-am pus si niste harti cu europa de est, dar se pare ca am o alta problema acuma.
Softul l-am copiat in memoria interna, si de acolo ruleaza, iar in sys.txt am pus exact ce ai postat la primul post.
iGO porneste, dar din pacate, satelitul este taiat in map. M-am uitat si "Enable GPS" ii bifat, dar imi apare un mesaje de eroare (poate nu-i 100% la fel, nu pot verifica acuma, dar am vazut ca si altii au avut aceeasi problema): "GPS receiver could not be recognized". Se pare ca iGO nu-l poate controla/recunoaste.
Cum as putea sa rezolv acest lucru? Butonul de configurare auto, si respectiv portul sunt inactive. doar Enable GPS pot sa schimb, dar ii deja activat.
Are cineva vreo idee?
zeusz4u
- Mesaje scrise: 2
- emy_dilau
- 204 mesaje
- din 22 Sep 2007
- Bacau
emy_dilau
elpopa
- Mesaje scrise: 5
- Masina: Astra 2000 Y20DTH
- Cont inregistrat: 11 Jun 2010
In speranta ca toti stiti deja sa puneti IGO sau Primo pe ES515 va intreb si eu 2 lucruri:
Am primo 2 pe es515
1. De ce imi apare in crash.txt ca primo.map not found . ma gandesc ca pt ca nu am primo.map... as putea pune ceva acolo?
2. Nu pot modifica backlight din Primo1.2 sau 2. Aveti vreun fisier de configurare pt es515 ca alea care sunt in data.zip/config/devices/*.ini
Ma gandesc ca doar valoarea parametrului backlight_methods imi lipseste
Mersi
Se pare ca la pct-ul 2 mi-am raspuns. Pentru cei care aveti probleme la backlight / brigthness pe Northcross ES515 (adica nu il puteti modifica din IGO / Primo) faceti una din 2.
a. Scrieti liniile urmatoare in sys.txt (parametrul ala 61 mi-a dat batai de cap)
[power]
backlight_manage_values = 1
backlight_manage_keys = 1
backlight_min = 1
backlight_max = 5
backlight_reverse = 0
backlight_methods=61
backlight_events=1
backlight_key_bright_BA1 ="BacklightCurrentLevel"
backlight_key_bright_AC1 ="BacklightCurrentLevel"
backlight_key_timeout_BA = "BatteryTimeout"
backlight_key_timeout_AC = "ACTimeout"
backlight_key_on_BA = "UseBattery"
backlight_key_on_AC = "UseExt"
2. Scrieti in sys.txt
[device]
type="ES515"
adaugati in Primo\Data.zip\config\devices fisierul din link ES515.ini
Astept suport pt punctul 1.
Am primo 2 pe es515
Mersi
[power]
backlight_min = 1
backlight_max = 5
backlight_events=1
[device]
type="ES515"
- ahappyuser
- 6,669 mesaje
- din 05 Apr 2010
- Astra 2005 Z17DTH
ahappyuser
- Mesaje scrise: 6,669
- Masina: Astra 2005 Z17DTH
Pentru toti cei ce aveti intrebari, vorbiti cu colegul @emy_dilau si o sa va ajute. Am un sentiment 'al meu' ca stie ... multe in domeniul PDA + GPS.
Eu am mers chiar un pic mai departe, am instalat pe ES515 software-ul Becker Transit 50 cu harti Navteq sau TeleAtlas/TopMap si mi se pare ceva mai deosebit... Hei... e vorba de software-ul care ruleaza pe PDA-urile Becker .... care e chiar mai ok decat iGO Primo.
Singura functionalitate, fata de Primo v2.0, la care i-am simtit lipsa a fost simularea unui traseu prestabilit.
- emy_dilau
- 204 mesaje
- din 22 Sep 2007
- Bacau
emy_dilau
elpopa a scris:In speranta ca toti stiti deja sa puneti IGO sau Primo pe ES515 va intreb si eu 2 lucruri:
Acea eroare e generica.Daca stii engleza:
Crash.txt is useful when programmers look for malfunction in locked NavNGo products. When the product (iGO or Primo) is unlocked, a crash text is created on failure, but the needed info is useless in most cases (changed program). Map, as referred by crash text, is the name of a special folder made only by locked iGO/Primo. When crashing, that map folder can not be found, thus in every chrash text made by an unlocked program appears "map not found". Also in crash text is a list of all installed fbl files (country maps), which is confusing in combination.
Important e daca ai probleme in functionare?
- emy_dilau
- 204 mesaje
- din 22 Sep 2007
- Bacau
emy_dilau
AlaMicSiNegru a scris:Salutare,
Multumesc anticipat
Multumesc anticipat
Tu macar realizezi ca e haos in ce ai scris mai sus?Macar ai citit pasii atent?
Ce treaba are firmware-ul(care iti poate busi aparatul instalat incorect),ce treaba are sys.txt cu config navi?
Iti recomand sa recitesti toate discutia...
- ovidiuvuia
- 222 mesaje
- din 21 Sep 2008
- Caras-Severin
ovidiuvuia
- Mesaje scrise: 222
- Cont inregistrat: 21 Sep 2008
