  3. Vectra B
  • gabriel88_vl
  • Mesaje scrise: 152
  • Masina: Agila 2004 z12xe
  • Cont inregistrat: 21 Sep 2008
Eu am Aral High Tronic SAE 5W-40 si am vectra B pe benzina. Sa inteleg ca am facut o prostie si am bagat ulei de disel ? are vreo 6000 km de cand l-am bagat si a aparut o bataie la motor in zona distributiei nu stiu de unde. Are legatura cu asta? Care pot fi consecintele ca am bagat ulei de disel ? Avea tot ulei deasta si inainte si cand l-am schimbat am bagat la fel ca am zis ca e bun dar nu stiam ca e de disel 😢
  • deleted-3101
  • Mesaje scrise: 348
  • Cont inregistrat: 01 Sep 2006
"Aral High Tronic 5W-40
High-end, high-performance motor oil with
Aral Synth-Technology.
• Saves fuel and prevents the environment
• Most reliable lubrication even at high
temperatures
• Very good protection against wear
• Very fast lubrication of entire engine at
cold starts
Performance reserves are maintained, especially
under demanding driving conditions, even when
used with extended oil change intervals and in
engines with very low oil consumption. Suitable
for almost all four-stroke gasoline
and diesel
engines (incl. turbo-charged engines).
Specifications/Certifications:
• ACEA A3, B3, B4
• API SJ/CF
• VW Norm 502 00 and 505 00 (01/97)
• MB Service Bulletin 229.3
• Porsche
• BMW (Longlife Oil List)
• Opel GM-LL-B-025
Faptul ca are certificarea GM pentru diesel, nu inseamna ca uleiul este numai pentru diesel.
  • gabriel88_vl
Poi da stiam dar ce efecte negative sunt daca are specificatia GM pe disel ? Adica daca era bun pt opel benzinare puneau si GM de benzina. Asta intreb ca am zis mai sus ca a inceput un tacanit de disel si nu e de la distributie.
  • gabriel88_vl
iso a scris:Desi am schimbat generatia de Astra , acum am Z14XEP care seamana foarte bine cu Z12XE , consumabile sint aceleasi - manopera de intretinere aceeasi .
Ma pregatesc pentru revizia de 15.oookm(desi mai am 4.500km) si am sa ma orientez spre noul Castrol EDGE 0w30 - API:SM/CF , filtru de ulei de la FRAM fara supapa suplimentara de bypass sau in caz ca nu gasesc merg pe varianta de filtu de la Purolator . Nu recomand filtre de la Mahle , Mann , Champion deoarece au supapa suplimentara de bypass care nu lasa bypassul "original" sa'si faca treaba .
P.S. Dane pune si Z14XEP in titlu sa vada mai rapid cei interesati .
Dar la o vectra B din 1996 ( cea din semnatura ) ce filtru de ulei e recomandat? CU sau FARA supapa suplimentara de bypass ?
  • aurick86
  • Mesaje scrise: 16
  • Masina: Vectra 1997
  • Cont inregistrat: 15 Oct 2008
eu cred ca ai facut o prostie fenomenala si nu e doar parerea mea
nu stiu daca am voie cu link-uri .. ?!?! (rog sa ma anuntzati daca nu am voie)
oricum uite ce scrie aici : The Engine Oil Bible
asta e partea importanta : "to ensure that you do not over clean your engine and lose compression for example. Generally speaking, an SAE 15W/40 diesel engine oil for about 500 miles"
daca zici ca ai facut deja 6000 km.. cred ca e nasol...
sa anunti ce ai rezolvat
  • gabriel88_vl
Am bagat Mobil1 0W40 si nu e nici o diferenta. Mecanicul mia zis ca nu e de la ulei. A inceput sa tacane imediat dupa ce am schimbat kitul de distributie si mecanicul a zis ca e de la cureaua de distributie(cica e prea dura). O mai las vreo 10.000km si daca nu se lasa o sa incerc cu cea veche si apoi daca asta e problema pun alta noua de la alta firma. Curea Contitech am acuma.
Vechiul ulei Aral High Tronic SAE 5W-40 nu este de disel neaparat doar ca nu avea specificatia benzina la opel.
Pentru sezonul cald(vara) ce ulei sa bag cu specificatie de opel benzina? Vara as vrea mai gros ceva dar nu este nici unul cu specificatie opel benzina si o sa vad daca il papa pe asta de acuma ca daca nu il papa merg cu el si vara.
  • gabriel88_vl
Chiar de la curea sa fie ?
  • gxg_tm
  • Mesaje scrise: 1,162
  • Masina: Agila 2002 ARY
  • Cont inregistrat: 07 Jan 2008
Salut , am un amic ce a cumparat o Vectra B1 din 1996 cu motor X18XE sau X18XE1 , nu sunt sigur , si vrem sa ii facem schimbul de ulei ! Care dintre voi stiti cat ulei se pune la acest motor ? Si daca se poate si cati litrii de antigel ! Multumesc anticipat !
  • crazy
  • Mesaje scrise: 61
  • Masina: Vectra 1998 x18xe
  • Cont inregistrat: 24 Jun 2010
Salut,eu am motor de X18XE si am bagat ulei GM5W40-uleiul standard pentru acest model asa stiu eu.Merge vreo 4-5 Litri(nu stiu exact,cred ca e 4 daca nu ma insel),antigelul am bagat albastru si am bagat tot 5 Litri din care tot a intrat in motor.Eu inainte de a baga antigel am curatat circuitul cu o solutie de curatat radiatoare care se gaseste si la OMV cu care am umblat pina sa incalzit motorul cu caloriferul pornit sa se curete tot circuitul,dupa care l-am golit si dupa aceea am bagat napoi antigel curat.Eu te sfatuiesc sa il cureti daca tot schimbi antigelul sa nu ai probleme dupa aceea.
Ultima modificare făcută de crazy la Lun 01 Nov, 2010 11:00 pm
  • gxg_tm
Ok , multumesc , ulterior am aflat ca ulei ar intra 4,25 litrii , de antigel nu eram sigur !
  • crazy
  • Mesaje scrise: 61
la mine a mers 5 litri ca daca mai pornesti motorul se mai aeriseste si trebuie sa mai bagi pina la liniuta de pe vas.
  • genutzu
  • Mesaje scrise: 164
  • Masina: Vectra 1996 x16xel
  • Cont inregistrat: 09 Nov 2010
pana la urma ce ulei e ok pt vectra b si cati litri intra?
  • secarianu
  • Mesaje scrise: 885
  • Masina: Omega 2001 Y22DTH
Nu vreau sa fiu nepoliticos, totusi aici este sectiunea de OMEGA 😊 derutam ceilalti detinatori 😉
  • gxg_tm
Eu acum am vazut 😳 , poate vede vre-un moderator sa mute discutia la vectra !
  • secarianu
am trimis si avertizare moderatorilor, insa nu au luat nicio actiune , poate or fi si ei in concediu 😊
  3. Vectra B
