- bazare
- 2,319 mesaje
- din 25 Nov 2008
- Astra 2002 y17dt
bazare
- Mesaje scrise: 2,319
- Masina: Astra 2002 y17dt
- Cont inregistrat: 25 Nov 2008
Cine ma poate ajuta cu un log facut cu op-comul de la un corsa c 1.3cdti? ma intereseaza mai multi parametrii sa compar cu alta masina care merge prost. Ms
Chiar nu se observa un tipar in aceasta zona, nu ati observat deloc ca in paginiile de aici, se incepe in acest mod ' Corsa - titlul si apoi o descriere ',sincer este asa de invizibila asezarea in pagina.
edit by StefanTolos
edit by StefanTolos
- bavarezu
- 524 mesaje
- din 22 Dec 2007
bavarezu
- Mesaje scrise: 524
- Cont inregistrat: 22 Dec 2007
- StefanTolos
- 4,224 mesaje
- din 23 Nov 2007
- Corsa 2018 B12XER
StefanTolos
- Mesaje scrise: 4,224
- Masina: Corsa 2018 B12XER
Selected model>,2004,Corsa-C,Engine,Z 13 DT
Measuring blocks information:
Battery Voltage,14.1 V
Ignition Status,On 12V
Main Relay,Active
Fuel Pump Relay,Active
APP Sensor 1 (Accelerator Pedal Position),0.98 V
APP Sensor 2 (Accelerator Pedal Position),0.47 V
Calculated Pedal Position,0 %
APP at Idle Position (Accelerator Pedal Position),Active
Desired Idle Speed,800 RPM
Engine Speed,805 RPM
Camshaft Speed,402 RPM
Idle Speed Offset,Inactive
Idle Speed Modified,NO
Normal Engine Operating Temperature,Inactive
Coolant Temperature,69 °C
Coolant Temperature,0.86 V
Fuel Temperature,45 °C
Intake Air Temperature,52 °C
Intake Air Temperature,1.39 V
Ambient Temperature,23 °C
Mass Air Flow Sensor,12 kg/h
Mass Air Flow Sensor,1.35 V
Barometric Pressure,97 kPa
Barometric Pressure,3.63 V
Boost Pressure,98 kPa
Boost Pressure,1.84 V
EGR Valve (Exhaust-Gas Recirculation),Active
EGR Pulse Ratio (Exhaust Gas Recirculation),41 %
Desired Common Rail Fuel Pressure,25.00 MPa
Common Rail Fuel Pressure,25.20 MPa
Rail Pressure Control Valve,16 %
Actual Injection Quantity,5 mm3
Actual Injection Start,1 °CA
A/C Information Switch (Air Conditioning),Inactive
A/C Pressure (Air Conditioning),800 kPa
A/C Pressure (Air Conditioning),1.22 V
A/C Relay (Air Conditioning),Inactive
A/C Cutoff Mode (Air Conditioning),System OK
Fan Relay 1,Inactive
Fan Relay 2,Inactive
Fan Relay 3,Inactive
Glow Time Relay,Inactive 12V
Diagnosis Glow Time Relay,Inactive
Brake Switch 1,Inactive
Brake Switch 2,Inactive
Clutch Switch,Inactive
Vehicle Speed,0 km/h
Vehicle Speed in Cruise Control Range,Inactive
Cruise Control Tip Switch,Not Programmed
Malfunction Indicator (MI),Off
Service Vehicle Soon (SVS) Indicator,Off
Glow Time Telltale,Off 12V
Oil Level,Normal
Engine Oil Level Status,Okay
Remaining Oil Life,91 %
Engine Oil Change Warning,Inactive
Immobiliser Function Programmed,Yes
Security Wait Time,Inactive
BCM: Vehicle-ID is programmed (Body Control Module),Yes
Instrument: Vehicle-ID is programmed,Yes
BCM: Status of Vehicle-ID (Body Control Module),Okay
Instrument: Status of Vehicle-ID,Okay
Modelul ales>,2006,Corsa-C,Motor,Z 13 DT
Valori reale:
Tensiune baterie,14.4 V
Stare aprindere,Conectat 12V
Releu principal,Activ
Releu pompã combustibil,Activ
Senzor 1 pedalã acceleraþie,0.96 V
Senzor 2 pedalã acceleraþie,0.47 V
Poziþie pedalã calculatã,0 %
Pedala de acceleraþie - poziþie ralanti,Activ
Turaþie prescrisã,800 RPM
Turaþie motor,798 RPM
Turaþia axei cu came,399 RPM
Deviaþie de ralanti,Inactiv
Turaþie ralanti - modificatã,NU
Temperaturã motor normalã,Inactiv
Temperaturã lichid rãcire,72 °C
Temperaturã lichid rãcire,0.80 V
Temperatura combustibil,24 °C
Temperatura aer admisie,18 °C
Temperatura aer admisie,2.80 V
Temperaturã ambiantã,3 °C
Senzor masã aer,21 kg/h
Senzor masã aer,1.63 V
Presiune barometricã,96 kPa
Presiune barometricã,3.55 V
Presiune turbo,95 kPa
Presiune turbo,1.78 V
Ventil AGR,Inactiv
Factor de umplere AGR,0 %
Presiune Rail prescrisã,25.00 MPa
Presiune Rail,25.20 MPa
Ventil control presiune Rail,76 %
Cantitate actualã injectatã,4 mm3
Inceput de injecþie real,1 grade
Comutator info climã,Inactiv
Presiune sistem climã,512 kPa
Presiune sistem climã,0.80 V
Releu climã,Inactiv
Clima în regim blocat,Sistem OK
Releu 1 ventilator,Inactiv
Releu 2 ventilator ,Inactiv
Releu ventilator 3,Inactiv
Releu preâncãlzire,12V inactiv
Diagnostic releu preâncãlzire,Inactiv
Contact 1 fârnã,Inactiv
Contact 2 frânã,Inactiv
Contact ambreiaj,Inactiv
Vitezã vehicul,0 km/h
Viteza în plaja sistemului de menþinere vitezã,- - -
Tasta de atingere pt.sistem menþinere vitezã,- - -
Indicator defecte(MI),Deconectat
Indicator servisare(SVS),Deconectat
Martor timp de preâncãlzire,Decon.12V
Nivel ulei,Normal
Stare nivel ulei,Okay
Timp pânã la schimb de ulei,128 %
Avertizare schimb ulei,Activ
Funcþia imobilizator programatã,Da
Timp de aºteptare de securitate,Inactiv
BCM- identificare vehicul programatã(modul caroserie),Da
Instrumet: ID vehicul programat,Da
BCM- stare identificare vehicul (modul caroserie),Okay
Instrument: stare ID vehicul,Okay
Main Relay,Active
Oil Level,Normal
Valori reale:
Ventil AGR,Inactiv
Releu climã,Inactiv
Nivel ulei,Normal
- bazare
- 2,319 mesaje
- din 25 Nov 2008
- Astra 2002 y17dt
bazare
RPM Boost kPa Rail pressure MPa
2.220 107 54.4
2.054 104 52.2
1.915 103 49.8
1.802 102 48.6
1.773 102 49.6
1.773 106 58.2
1.896 112 67.6
2.140 138 87.6
2.502 196 108.2
2.849 220 126.8
3.173 217 139.8
3.390 208 133.8
3.621 187 118.8
3.755 189 120
3.907 191 121
4.058 192 121
4.170 190 112.6
4.274 188 106.6
4.327 182 106.8
4.377 182 106
4.423 183 105.8
4.478 183 105.8
4.507 182 102.8
4.527 180 101.6
4.558 180 101.4
4.566 180 101.2
4.553 180 101
4.548 181 101
4.565 181 101
4.559 182 100.4
Am gasit intre timp ce ma interesa ... ms de info
2.220 107 54.4
2.054 104 52.2
1.915 103 49.8
1.802 102 48.6
1.773 102 49.6
1.773 106 58.2
1.896 112 67.6
2.140 138 87.6
2.502 196 108.2
2.849 220 126.8
3.173 217 139.8
3.390 208 133.8
3.621 187 118.8
3.755 189 120
3.907 191 121
4.058 192 121
4.170 190 112.6
4.274 188 106.6
4.327 182 106.8
4.377 182 106
4.423 183 105.8
4.478 183 105.8
4.507 182 102.8
4.527 180 101.6
4.558 180 101.4
4.566 180 101.2
4.553 180 101
4.548 181 101
4.565 181 101
4.559 182 100.4
- StefanTolos
- 4,224 mesaje
- din 23 Nov 2007
- Corsa 2018 B12XER
StefanTolos
- bazare
- 2,319 mesaje
- din 25 Nov 2008
- Astra 2002 y17dt
bazare
am ajuns la concluzia ca in acest ECU turbina nu e controlata direct de ECU, si de aici turbo-spikeurile care apar. O presiune de 2.2 - 2.3 bari este mult pentru acest turbo mic (softul logat este stock). Presiunea in rampa este OK. Softul de Marelli 1.3mjet in sine este ciudat si cu un management al presiunii in turbo dupa parerea mea deficitar. Oricum sunt inca in faza de studiu dar am fost intrigat de la bun inceput de aceste valori mari citite de MAP si vroiam sa fiu convins ca pe mai multe masini e aceeasi poveste.
- StefanTolos
- 4,224 mesaje
- din 23 Nov 2007
- Corsa 2018 B12XER
StefanTolos
Boost Pressure
Ignition ON Engine OFF All consumers turned off 75 ... 110 kPa 1.0 ... 2.0 V
Diagnostic tester display is nearly identical to outside-air pressure
Engine running at idle speed, operating temperature 75 ... 110 kPa 1.0 ... 2.0 V
Increase engine speed to 4000 rpm greater than 170 kPa greater than 3.0 V
Engine starting greater than 20 MPa
Engine running at idle speed, operating temperature All consumers turned off
Accelerator pedal not actuated 23 ... 27 MPa
Accelerator pedal briefly actuated to full load stop greater than 25 MPa
Dar valorile expuse par a fi destul de optime,presupun ca vrei sa modifici ceva in comanda turbinei.
- bazare
- 2,319 mesaje
- din 25 Nov 2008
- Astra 2002 y17dt
bazare
- StefanTolos
- 4,224 mesaje
- din 23 Nov 2007
- Corsa 2018 B12XER
StefanTolos
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Signum 2005 Z19DTH 190CP
- Timis
tonytm
- Mesaje scrise: 4,479
bazare a scris:Da conform datelor din ECU presiunea maxima la turbo ar trebui sa fie undeva la 178kPa. In realitate pe masinile logate presiunea citita este mult mai mare ajungand si la 220kPa, o valoare cam sus as zice eu. Acum sunt doua variante ... ori op-comul citeste prost ori chiar asa e.
220 kpa pe loc? Nu in sarcina?
- bazare
- 2,319 mesaje
- din 25 Nov 2008
- Astra 2002 y17dt
bazare
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
- bazare
- 2,319 mesaje
- din 25 Nov 2008
- Astra 2002 y17dt
bazare
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
1.9 CDTI face si 260 kpa in sarcina fara probleme. Iar circuitul de admisie aer e mult mai mare dimensionat. Adica poate face linistit acelasi boost dar sa livreze dublu cantitatea de aer.
Daca testul se face la 4000 rpm si zice sa ai 178 kpa pe loc, nu vad de ce ar fi o problema ca-n sarcina sa vezi 220.
Iar daca softul te limiteaza la 178 si tu-l tii in 220 pentru cateva zeci de secunde ar trebui sa dea erori de overboost.
