- ianc sergiu
- 434 mesaje
- din 08 Feb 2010
- Vectra 2004 z19dth
- Hunedoara
ianc sergiu
- Mesaje scrise: 434
- Masina: Vectra 2004 z19dth
- Cont inregistrat: 08 Feb 2010
- stefanb_80
- 44 mesaje
- din 24 Jan 2006
- Zafira 2003 y20dth
- Hunedoara
stefanb_80
- Mesaje scrise: 44
- Masina: Zafira 2003 y20dth
- Cont inregistrat: 24 Jan 2006
- ianc sergiu
- 434 mesaje
- din 08 Feb 2010
- Hunedoara
ianc sergiu
- ianc sergiu
- 434 mesaje
- din 08 Feb 2010
- Hunedoara
ianc sergiu
Swirl flap control
The adjustable swirl flaps are located in the tangential channels of the intake system and are opened and
closed according to the operating status of the engine. The swirl flaps are closed under the following
conditions:
# at low engine speeds and low injection volumes (map-controlled)
The swirl flaps generally remain open when
# the coolant temperature < 15°C OR
# the intake air temperature < 15°C
Function
The pressure converter connects the vacuum unit with the vacuum supply by means of hoses. When
activated by the DDE control unit, the changeover valve switches vacuum to the vacuum unit. The vacuum
unit actuates the control rod and the swirl flaps close. The control rod is up against the rear stop when the
swirl flaps are open.
Troubleshooting
If a fault is detected in the control of the pressure converter, the following faults may be detected:
# 4130, Activation short circuit to B+
# 4141, Activation short circuit to B-
# 4152, Activation circuit break
# 4153, Excess temperature output stage
Effects of faults
If the swirl flaps stick in open position: Deterioration in exhaust gas characteristics in lower speed ranges
otherwise no effect.
If the swirl flaps stick in closed position: Power loss of approx. 10% at higher engine speeds.
- raku21
- 519 mesaje
- din 30 Mar 2008
- Astra 2000 Y20DTH
raku21
- Mesaje scrise: 519
- Masina: Astra 2000 Y20DTH
- Cont inregistrat: 30 Mar 2008
- ianc sergiu
- 434 mesaje
- din 08 Feb 2010
- Hunedoara
ianc sergiu
- raku21
- 519 mesaje
- din 30 Mar 2008
- Astra 2000 Y20DTH
raku21
- ianc sergiu
- 434 mesaje
- din 08 Feb 2010
- Hunedoara
ianc sergiu
- raku21
- 519 mesaje
- din 30 Mar 2008
- Astra 2000 Y20DTH
raku21
- ianc sergiu
- 434 mesaje
- din 08 Feb 2010
- Hunedoara
ianc sergiu
- raku21
- 519 mesaje
- din 30 Mar 2008
- Astra 2000 Y20DTH
raku21
- ianc sergiu
- 434 mesaje
- din 08 Feb 2010
- Hunedoara
ianc sergiu
- raku21
- 519 mesaje
- din 30 Mar 2008
- Astra 2000 Y20DTH
raku21
