Mie 26 Mar, 2014 7:12 pm
Am facut azi diagnoza la Opel de 2 ori si am vazut ceva suspect. Clutch switch este active tot timpul indiferent daca apas pedala de ambreiaj sau nu. Chiar si atunci cand imi functioneaza pilotul nu se schimba...ramane pe active. Am verificat cu opcom-ul. La prima diagnoza la brake switch 1 si 2 mi-a dat valori diferite. La prima diagnoza brake switch 1 era inactive si brake switch 2 era inactive , dar cand apasam pedala de ambreiaj aparea active(doar brake switch 2) . La a doua diagnoza facuta brake switch 1 arata active si brake switch 2 arata inactive - amandoua fara pedala apasata. Cand apasam pedala brake switch 2 devenea active. Voi pune datele celor doua diagnoze.
OP-COM 100219a - PC based diagnostic tool
Date and time>,26/03/2014. 12:1522
Workshop information:
hkj
Selected model>,2001,Astra-G,Engine,Z 16 XE
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0TGF4815075384
RepairShopCodeOrTesterSerialNumber: S001015423
ProgrammingDate: 20100401
systemSupplierECUHardwareNumber: DEL 0115351289
vehicleManufacturerECUHardwareNumber 09353489 BE
systemSupplierECUSoftwareNumber: DJTX
systemSupplierECUSoftwareVersionNumber: 0005
exhaustRegulationOrTypeApprovalNumber: D01004
systemNameOrEngineType: Z16XE
Identifier: 1594
CalibrationDate: P0201A07
Measuring blocks information:
Battery Voltage,14.0 V
Main Relay,Active
Fuel Pump Relay,Active
APP Sensor 1 (Accelerator Pedal Position),0.96 V
APP Sensor 2 (Accelerator Pedal Position),0.47 V
Calculated Pedal Position,0 %
APP at Idle Position (Accelerator Pedal Position),Active
TP Sensor 1 (Throttle Position),0.69 V
TP Sensor 2 (Throttle Position),4.33 V
Calculated Throttle Position,9 %
Throttle Position,Idle
Engine Speed,827 RPM
MAP Sensor (Manifold Absolute Pressure),1.17 V
MAP Sensor (Manifold Absolute Pressure),32 kPa
Coolant Temperature,3.39 V
Coolant Temperature,53 °C
Intake Air Temperature,3.86 V
Intake Air Temperature,17 °C
Tank Sensor,5.79 V
Tank Sensor,9 L
A/C Information Switch (Air Conditioning),Inactive
A/C Pressure (Air Conditioning),740 kPa
Brake Switch 1,Inactive
Brake Switch 2,Inactive
Clutch Switch,Active
Vehicle Speed,0 km/h
Cruise Control Tip Switch,Inactive
Cruise Control,Inactive
Vehicle Speed in Cruise Control Range,Active
EGR Valve (Exhaust-Gas Recirculation),Inactive
EGR Position Command (Exhaust- Gas Recirculation),0 %
EGR Position Feedback (Exhaust Gas Recirculation),1.59 V
Fuel Tank Ventilation Valve,0 %
Knock Control,Inactive
B1S1 O2 Sensor Heater (Bank 1 Sensor 1),Active
B1S1 O2 Sensor (Bank 1 Sensor 1),312 mV
B1S1 Air/Fuel Ratio (Bank 1 Sensor 1),Rich
B1S2 O2 Sensor Heater (Bank 1 Sensor 2),Active
B1S2 O2 Sensor (Bank 1 Sensor 2),828 mV
B1S2 Air/Fuel Ratio (Bank 1 Sensor 2),Lean
O2 Sensor Loop,Open
B1 Long Term Fuel Trim (Bank 1),2 %
B1 Short Term Fuel Trim (Bank 1),0 %
A/C Relay (Air Conditioning),Inactive
A/C Cutoff Mode (Air Conditioning),System OK
Malfunction Indicator (MI),Off
Service Vehicle Soon (SVS) Indicator,Off
Desired Idle Speed,825 RPM
Idle Speed Offset,Cold Start
Ignition Dwell Angle,1.9 ms
Injector Time,31 ms
Ignition Spark Angle,5.2 °CA
Knock Retard Cylinder 1,0 °CA
Knock Retard Cylinder 2,0 °CA
Knock Retard Cylinder 3,0 °CA
Knock Retard Cylinder 4,0 °CA
Ignition Status,On 12V
ETC Limp Home Mode (Electronic Throttle Control),Inactive
Total Misfire,0
Dec. Fuel Cutoff (Deceleration),Active
Fuel Tank Ventilation Valve,Inactive
Immobiliser Function Programmed,Yes
Security Wait Time,Inactive
