- nelutzu_832000
- 49 mesaje
- din 07 Oct 2016
- Astra 2011 A17DTJ
- Buzau
nelutzu_832000
- Mesaje scrise: 49
- Masina: Astra 2011 A17DTJ
- Cont inregistrat: 07 Oct 2016
- DB77AAA
- 6,715 mesaje
- din 19 Jan 2007
- Vectra 2005 Z19DTH 200CP
- Dambovita
DB77AAA
- Mesaje scrise: 6,715
Pai prima oara incearca sa dezinstalezi orice versiune de driver pe care o ai.
Apoi instalezi driverele semnate digital, asa ar trebui sa aiba versiunea ta de soft. Banuiesc ca vorbim de o interfata originala sau cel putin HQclone. Cand instalezi driverele dai click dreapta si run as administrator.
Spor!
Spor!
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- Mesaje scrise: 5,916
- Masina: Corsa 2001 Z12XE
- DB77AAA
- 6,715 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
- nelutzu_832000
- 49 mesaje
- din 07 Oct 2016
- Astra 2011 A17DTJ
- Buzau
nelutzu_832000
- Mesaje scrise: 49
andreyy82
- Mesaje scrise: 85
- Masina: Vectra 2003 z18xel
- Cont inregistrat: 04 Aug 2010
- jgyprime
- 9,968 mesaje
- din 22 Dec 2010
- Vectra 2005 Z19DT
jgyprime
- Mesaje scrise: 9,968
- Masina: Vectra 2005 Z19DT
andreyy82
- Mesaje scrise: 85
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
andreyy82
- Mesaje scrise: 85
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
Nu e asa procedura corecta....ce ai facut tu este provizoriu...
To disable driver signature enforcement permanently in Windows 10, you need to do the following:
Open an elevated command prompt instance.
Type/paste the following text:
bcdedit.exe /set nointegritychecks on
Restart Windows 10.
This will disable the driver signature enforcement in Windows 10 permanently. This preference will be preserved even after the reboot. So, if you need to flash an Android phone or install some old or specific hardware drivers, you will be able to bypass the driver signature requirement.
To enable the driver signature enforcement back in Windows 10, type the following command in the elevated command prompt:
bcdedit.exe /set nointegritychecks off
Restart Windows 10.
andreyy82
- Mesaje scrise: 85
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
andreyy82
- Mesaje scrise: 85
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
radurusu
- Mesaje scrise: 26
- Masina: Astra 2013 A17DTE
- Cont inregistrat: 12 Mai 2009
- livcro
- 4,543 mesaje
- din 22 Jul 2005
- Grandland X 2018 D20DT
- SIBIU-RM. VALCEA
livcro
- Mesaje scrise: 4,543
Pisty10
- Mesaje scrise: 17
- Masina: Astra 2010
- Cont inregistrat: 16 Sep 2016
Buna seara,
Am opcom 2012,V1.161. O folosesc pentru Astra J din 2010. La 'Measuring block' imi apare N/A sau ceva de genul.
Oare ca sa pot sa vad si eu valorile, trebuie sa fac ce face tipul in video,adica sa setezi optiunile alea cu 'Present'? Sau este o alta modalitate?
Video-ul este : http://www.youtube.com/watch?v=fODi1KjykgE
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
Pisty10
- Mesaje scrise: 17
