bogdan447
- Mesaje scrise: 5
- Masina: Tigra 1995 Z17DTL
- Cont inregistrat: 05 Nov 2015
SALUT AM O PROBEMA CARE NU II POT DA DE CAP MA PUTETI AJUTA .?
AM UN OEPL INSIGNIA 2.0 CDTI AUTOMATA AF40 55562430
EROARE CUTEI DE VIZEZA AUTOMATA p0986 SHIFT SOLENOID VALVE 1 CONTROL CIRCUIT
HIGH VOLTAGE ( INTERMITENT SAU PERMANETN)
DUPA ACEA PE MOTOR DACA MERG CU MASINA MULT IMI DA P0700 TRANSIMISSION ONTROL SYSTEM (MIL REQUEST) (INTERMITENT SI PERMANENT )
DACA STERG EROARILE MASINA MERGE PERFECT CAM 40 50 KM SAU MAI NOU DACA O TIN MULT ACELERATA TEMPERATURA APEI PE MOTOR ESTE 88 89 90 97 GEN IAR DUPA CUTIE 100,99,102,105 ADICA NU ESTE ACEASI TEMPERATURA CA PE MOTOR
DUPA CE IMI DA EROARE PE CUTIE MASINA NU MAI SCHIMBA MERGI DOAR CU D1,D2 ,R
MA-M UITAT PE VALORI LA POZITIE MANETA VITEZA PE CALCULATORUL CUTIEI CITESTE P CHIAR DACA EA ESTE IN D UNEORI MAI TRECE PE R DAR ACOLO RAMANE DECI NU VEDE CALCULATORUL DE CUTIE POZITA MANETEI , DAR MASINA MERGE SE DEPLASAZA IN D,R
SI SINCER SUNT MECANIC AUTO SI NU STIU CE SAI FAC CAUT TOT ODATA SI UN ELECTRONIST POATE O FII DE VINA CALCULATORUL DE PE CUTEI POATE LA CALD SE DEZLIPESC LIPITURILE RECI STIU EU NU STIU
MODEL: insignia 2009
MOTOR: 2.0 CDTI
MOTOR: 2.0 CDTI
- iulian1971
- 7,081 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,081
- Masina: Astra 2008 Z19DTH
bogdan447
- Mesaje scrise: 5
- iulian1971
- 7,081 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- sebage
- 2,511 mesaje
- din 16 Jun 2019
sebage
- Mesaje scrise: 2,511
- Status: Online
Daca ai acces la mufele acelor bobine, ai putea sa masor valoarea rezistentei acestora (in special a bobinei pentru valva 1). Masurat la rece si apoi la cald, cand apare problema.
Din materialul in engleza, rezulta ca ar trebui sa aiba intre 11 ohm si 15 ohm. Mare atentie ca in romana este tradus intre 1 Ohm si 15 ohm.
Apoi, bagi la loc mufa in valva si daca spatiul si managementul cablurilor iti permite, ai putea sa te asiguri ca aceeasi valoare o poti masura si in mufa TCM (scoti mufa din TCM si masori pe pini). Astfel te asiguri ca nu ai contacte imperfecte pe traseu.
Toate acestea doar DACA ai acces la aceste componente, eu nu am vazut o astfel de cutie, nu am habar.
bogdan447
- Mesaje scrise: 5
bogdan447
- Mesaje scrise: 5
- mikyboy
- 5,735 mesaje
- din 08 Dec 2006
- Insignia 2014 A20TDH
mikyboy
- Mesaje scrise: 5,735
bogdan447
- Mesaje scrise: 5
