De acum, EDS este prezent in Romania! Impreuna cu partenerul german, am agreat o lista de preturi adaptate pietei noastre.
Doar pentru membrii ClubOpel, acestea sunt:
Listele sunt actualizate permanent.
Diesel:
1.7 DTI - Y17DT - 98 CP si 215 Nm - 180 EUR
2.0 DTI - Y20DTH - 126 CP si 280 Nm - 200 EUR (inclusiv PSG16)
2.2 DTI - Y22DTR - 155 CP si 380 Nm - 200 EUR (inclusiv PSG16)
1.3 CDTI - Z13DT - 95 CP si 220 Nm - 250 EUR
1.3 CDTI - Z13DTH - 125 CP si 230 Nm - 250 EUR
1.3 CDTI - Z13DTJ - 100 CP si 220 Nm - 250 EUR
1.3 CDTi - B13DTC, B13DTR - 115CP si 230 Nm - 350 EUR
1.6 CDTI - B16DTC, B16DTE - 139 CP si 380 Nm - PROMO 350 EUR
1.6 CDTI - B16DTH, B16DTH - 160 CP si 400 Nm - PROMO 350 EUR
1.6 CDTI BiTurbo - 190 CP si 400 Nm - PROMO 350 EUR
1.7 CDTI - Z17DTL - 109 CP si 230 Nm - 200 EUR (180 EUR pentru Astra G)
1.7 CDTI - Z17DTH - 130 CP si 300 Nm - 225 EUR
1.7 CDTI Denso - Z17DTJ, Z17DTR, A17DTJ, A17DTR - 155 CP si 350 Nm - 300 EUR
1.7 CDTI - A17DTS Astra-J, Mokka, Corsa-D, Chevrolet Cruze - 175 CP si 400 Nm - 300 EUR
1.7 CDTI - A17DTC Astra-J - 175 CP si 400 Nm - 300 EUR
1.7 CDTI - A17DTE Astra-J - 170 CP si 380 Nm - 300 EUR
1.9 CDTI - Z19DTL si Z19DT - 160 CP si 380 Nm - 250 EUR
1.9 CDTI - Z19DTJ si Z19DTH - 200 CP si 430 Nm - 250 EUR
2.0 CDTI - Z20DMH Antara - 180 CP si 400 Nm - 275 EUR
2.0 CDTI - A20DTC,A20DTE, A20DT 2010+ Insignia 200 CP si 400 Nm - 400 EUR - inclusiv 2014+
2.0 CDTI - A20DTH 2010+ Insignia si Astra-J - 205 CP si 440 Nm - 400 EUR - inclusiv 2014+
2.0 CDTI - B20DTH, B20DTJ Insignia, Zafira-C - 210 CP si 450 Nm - 420 EUR
2.0 CDTI BiTurbo - A20DTR - 240 CP si 450 Nm - 450 EUR
2.0 CDTI - A20DTH 2009, A20DTJ 2009 Insignia - 350 EUR
3.0 CDTI - Y30DT - 210 CP si 450 Nm - 300 EUR
3.0 CDTI - Z30DT - 220 CP si 450 Nm - 300 EUR
Benzina Turbo:
1.4 Turbo Astra-J, Cascada - A14NEL, A14NET - max. 165 CP si 260 Nm - 300 EUR
1.4 Turbo Corsa-E B14NEJ, B14NEH - max 170 CP si 260 Nm - 350 EUR
1.4 Turbo Astra-K B14XFL, B14XFT - max 185 CP si 290 Nm - 400 EUR
1.6 Turbo Astra-J - A16LET - max. 210 CP si 300 Nm - 300 EUR
2.0 Turbo Astra-J OPC - A20NFT - max. 305 CP si 470 Nm - 350 EUR
1.6 Turbo Astra-H, Corsa-D - Z16LET, Z16LEL, Z16LER - 225 CP si 330 Nm - 300 EUR
2.0 Turbo - Z20LEL - 220 CP si 320 Nm - 300 EUR
2.0 Turbo - Z20LER - 237 CP si 340 Nm - 300 EUR
2.0 Turbo - Z20LET - 237 CP si 340 Nm - 300 EUR
2.0 Turbo Vectra C - Z20NET - 215 CP si 330 Nm - 300 EUR
2.0 Turbo Astra-OPC - Z20LEH - 275 CP si 430 Nm - 350 EUR
2.0 Turbo GT - Z20NHH - 310 CP si 450 Nm - 400 EUR
2.8 Turbo Vectra-OPC - Z28NEH, Z28NET, Z28NEL - 300 CP si 500 Nm - 400 EUR
2.0 Turbo Insignia - A20NHT - 285 CP si 450 Nm - 350 EUR.
2.8 Turbo Insignia - A28NET - 310 CP si 500 Nm - 400 EUR.
2.8 Turbo Insignia-OPC - A28NER - 355 CP si 550 Nm - 450 EUR.
Benzina aspirata (non-Turbo):
1.2 Twinport - A12XEL Adam - 90 CP - 200 EUR
1.4 Twinport - A14XEL, A14XER Adam - 110 CP - 200 EUR
1.4 Twinport - Z14XEP - 99 CP si 135 Nm - 180 EUR
1.6 Twinport - Z16XEP - 115-120 CP si 170-175 Nm - 200 EUR
1.6 VVT - Z16XER - 130 CP si 175 Nm - 200 EUR
1.8 16V- Z18XE - 140 CP si 195 Nm - 200 EUR
1.8 VVT - Z18XER - 155 CP si 200 Nm - 200 EUR
1.8 VVT - A18XER - 155 CP si 200 Nm - 200 EUR
2.6 V6 - Y26SE - 190 CP si 265 Nm - 250 EUR
3.2 V6 - Z32SE - 233 CP si 330 Nm - 250 EUR
Preturile sunt exprimate in EUR si sunt actualizate permanent.
Locatie: Bulevardul Theodor Pallady nr.57, intrarea din stanga, cu bariera (in incinta Anticorosiv).
Venind dinspre oras, veti merge pana la benzinaria MOL spre autostrada A2 si veti intoarce aproximativ 100 metri.
Coordonate GPS: N 44° 24’ 585’’ E 026° 12' 428'' sau 44.40995, 26.20695
Pentru detalii, click pe imagine
![](http://s3-eu-west-1.amazonaws.com/2013.clubopel.com/images/2013/blank.gif)
maiandrei - 0722.238.381, maiandrei pe gmail
mikki - 0722.762.448, mihaidb pe gmail
Nicu (Arad) - 0722.397.605, sudrijannicu pe gmail
Cristi (Alba Iulia) - c_pantazescu - 0743.119.367, c_pantazescu pe yahoo
Claudiu (Craiova) - 34KLA - 0744.510.853, claudiur2004 pe gmail
Raspunsuri la intrebari frecvente gasiti pe www.edsauto.ro
Programari la service - 0740.300.040
Ultima modificare făcută de maiandrei la Mie 16 Mai, 2018 2:25 pm, modificat de 64 ori în total
