- dodo_13
- 4,545 mesaje
- din 11 Apr 2005
- Astra 2008 Z19DTH
dodo_13
- Mesaje scrise: 4,545
- Masina: Astra 2008 Z19DTH
- bucifer85
- 334 mesaje
- din 08 Jan 2008
- Vectra 2005 z19dth
bucifer85
- Mesaje scrise: 334
- Masina: Vectra 2005 z19dth
- Cont inregistrat: 08 Jan 2008
Saptamana asta am schimbat galeria de admisie, si am pus OPCOM-ul:
852 RPM
Battery Voltage,13.2 V
Fuel Pump Relay,Active
APP at Idle Position (Accelerator Pedal Position),Active
APP Sensor 1 (Accelerator Pedal Position),0.96 V
APP Sensor 2 (Accelerator Pedal Position),0.47 V
Calculated Pedal Position,0 %
Desired Engine Idle Speed,850 RPM
Engine Speed,852 RPM
Camshaft Speed,425 RPM
1530 RPP
Battery Voltage,13.5 V
APP at Idle Position (Accelerator Pedal Position),Inactive
APP Sensor 1 (Accelerator Pedal Position),1.41 V
APP Sensor 2 (Accelerator Pedal Position),0.68 V
Calculated Pedal Position,12 %
Engine Speed,1.530 RPM
Camshaft Speed,750 RPM
Idle Speed Modified,NO
Calculated Air Flow,72 kg/h
Mass Air Flow Sensor,72 kg/h
Charge Air Temperature,68 °C
Charge Air Temperature,1.39 V
Fuel Temperature,46 °C
Fuel Temperature,2.15 V
Barometric Pressure,100 kPa
Barometric Pressure,3.93 V
Boost Pressure Command,104 kPa
Boost Pressure,108 kPa
Boost Pressure,1.72 V
Pulse Ratio Boost Pressure Solenoid Valve,75 %
EGR Position Commanded (Exhaust Gas Recirculation),29 %
EGR Pulse Ratio (Exhaust Gas Recirculation),44 %
Swirl Level Control Solenoid Valve Pulse Ratio,78 %
Throttle Position PWM Servo Signal,0 %
Desired Common Rail Fuel Pressure,42.99 MPa
Common Rail Fuel Pressure,42.85 MPa
Common Rail Fuel Pressure,1.45 V
Rail Pressure Control Solenoid Valve PWM,39 %
Rail Pressure Control Solenoid Valve Current,0.91 a
Fuel Metering Solenoid Valve PWM,41 %
Fuel Metering Solenoid Valve Current,1.39 a
Glow Time Relay,Inactive 12V
Diagnosis Glow Time Relay,Inactive
Glow Time Telltale,Off 12V
Vehicle Speed,0 km/h
2068 RPM
APP Sensor 1 (Accelerator Pedal Position),1.70 V
APP Sensor 2 (Accelerator Pedal Position),0.84 V
Calculated Pedal Position,25 %
Engine Speed,2.068 RPM
Camshaft Speed,1.025 RPM
Calculated Air Flow,98 kg/h
Mass Air Flow Sensor,98 kg/h
Charge Air Temperature,69 °C
Charge Air Temperature,1.35 V
Fuel Temperature,47 °C
Fuel Temperature,2.13 V
Boost Pressure,118 kPa
Boost Pressure,1.87 V
Pulse Ratio Boost Pressure Solenoid Valve,71 %
EGR Position Commanded (Exhaust Gas Recirculation),25 %
EGR Pulse Ratio (Exhaust Gas Recirculation),47 %
Swirl Level Control Solenoid Valve Pulse Ratio,71 %
Desired Common Rail Fuel Pressure,61.71 MPa
Common Rail Fuel Pressure,62.19 MPa
Common Rail Fuel Pressure,1.86 V
Rail Pressure Control Solenoid Valve PWM,44 %
Rail Pressure Control Solenoid Valve Current,1.03 a
Fuel Metering Solenoid Valve PWM,40 %
Fuel Metering Solenoid Valve Current,1.34 a
2564 RPM
Battery Voltage,13.3 V
APP Sensor 1 (Accelerator Pedal Position),1.80 V
APP Sensor 2 (Accelerator Pedal Position),0.88 V
Calculated Pedal Position,30 %
Engine Speed,2.564 RPM
Camshaft Speed,1.275 RPM
Calculated Air Flow,157 kg/h
Mass Air Flow Sensor,157 kg/h
Boost Pressure Command,120 kPa
Boost Pressure,142 kPa
Boost Pressure,2.25 V
Pulse Ratio Boost Pressure Solenoid Valve,68 %
EGR Position Commanded (Exhaust Gas Recirculation),22 %
EGR Pulse Ratio (Exhaust Gas Recirculation),49 %
Swirl Level Control Solenoid Valve Pulse Ratio,45 %
Desired Common Rail Fuel Pressure,70.48 MPa
Common Rail Fuel Pressure,70.10 MPa
Common Rail Fuel Pressure,2.03 V
Rail Pressure Control Solenoid Valve PWM,47 %
Rail Pressure Control Solenoid Valve Current,1.09 a
2638 RPM
APP Sensor 1 (Accelerator Pedal Position),1.78 V
Calculated Pedal Position,29 %
Engine Speed,2.638 RPM
Camshaft Speed,1.300 RPM
Calculated Air Flow,166 kg/h
Mass Air Flow Sensor,166 kg/h
Fuel Temperature,53 °C
Fuel Temperature,1.89 V
Boost Pressure,132 kPa
Boost Pressure,2.09 V
Pulse Ratio Boost Pressure Solenoid Valve,67 %
EGR Position Commanded (Exhaust Gas Recirculation),31 %
EGR Pulse Ratio (Exhaust Gas Recirculation),43 %
Swirl Level Control Solenoid Valve Pulse Ratio,43 %
Desired Common Rail Fuel Pressure,65.32 MPa
Common Rail Fuel Pressure,65.49 MPa
Common Rail Fuel Pressure,1.93 V
Rail Pressure Control Solenoid Valve PWM,45 %
Rail Pressure Control Solenoid Valve Current,1.05 a
3054 RPM
Calculated Air Flow,50 kg/h
Mass Air Flow Sensor,50 kg/h
Charge Air Temperature,64 °C
Charge Air Temperature,1.50 V
Fuel Temperature,2.17 V
Boost Pressure,102 kPa
Boost Pressure,1.64 V
EGR Position Commanded (Exhaust Gas Recirculation),100 %
EGR Pulse Ratio (Exhaust Gas Recirculation),4 %
Swirl Level Control Solenoid Valve Pulse Ratio,79 %
Desired Common Rail Fuel Pressure,30.00 MPa
Common Rail Fuel Pressure,30.54 MPa
Common Rail Fuel Pressure,1.17 V
Rail Pressure Control Solenoid Valve PWM,36 %
Rail Pressure Control Solenoid Valve Current,0.81 a
Fuel Metering Solenoid Valve PWM,43 %
3554 RPM
APP Sensor 1 (Accelerator Pedal Position),2.19 V
APP Sensor 2 (Accelerator Pedal Position),1.07 V
Calculated Pedal Position,47 %
Engine Speed,3.554 RPM
Camshaft Speed,1.750 RPM
Calculated Air Flow,346 kg/h
Mass Air Flow Sensor,347 kg/h
Charge Air Temperature,67 °C
Charge Air Temperature,1.41 V
Fuel Temperature,2.11 V
Boost Pressure Command,144 kPa
Boost Pressure,193 kPa
Boost Pressure,3.03 V
Pulse Ratio Boost Pressure Solenoid Valve,57 %
Swirl Level Control Solenoid Valve Pulse Ratio,5 %
Desired Common Rail Fuel Pressure,78.39 MPa
Common Rail Fuel Pressure,78.45 MPa
Common Rail Fuel Pressure,2.23 V
Rail Pressure Control Solenoid Valve PWM,48 %
Rail Pressure Control Solenoid Valve Current,1.12 a
Fuel Metering Solenoid Valve Current,1.31 a
4137 RPM
Battery Voltage,13.4 V
APP Sensor 1 (Accelerator Pedal Position),2.25 V
APP Sensor 2 (Accelerator Pedal Position),1.11 V
Calculated Pedal Position,50 %
Engine Speed,4.137 RPM
Camshaft Speed,2.050 RPM
Calculated Air Flow,345 kg/h
Mass Air Flow Sensor,345 kg/h
Charge Air Temperature,1.37 V
Fuel Temperature,48 °C
Fuel Temperature,2.09 V
Boost Pressure Command,152 kPa
Boost Pressure,164 kPa
Boost Pressure,2.58 V
Pulse Ratio Boost Pressure Solenoid Valve,58 %
Desired Common Rail Fuel Pressure,75.41 MPa
Common Rail Fuel Pressure,76.48 MPa
Common Rail Fuel Pressure,2.19 V
Fuel Metering Solenoid Valve Current,1.33 a
EGR-ul l-am curata.
Senzorul de pe galerie arata cam rau... dar era curat (l-am curatat cu vaul de la cutter. Daca am atins chestia aia din interior posibil sa-l fi stricat ?)
Clapeta de acc. am curatat-o
Nici la mine nu cred ca sunt prea buni parametrii.
Partea buna este ca nu-mi da eroare.
Ce sa-i mai fac......
852 RPM
1530 RPP
2068 RPM
2564 RPM
2638 RPM
3054 RPM
3554 RPM
4137 RPM
EGR-ul l-am curata.
fratila
- Mesaje scrise: 15
- Masina: Vectra y22dth
- Cont inregistrat: 23 Sep 2009
- bucifer85
- 334 mesaje
- din 08 Jan 2008
bucifer85
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Signum 2005 Z19DTH 190CP
- Timis
tonytm
- Mesaje scrise: 4,479
fratila
- Mesaje scrise: 15
- bucifer85
- 334 mesaje
- din 08 Jan 2008
bucifer85
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
- bucifer85
- 334 mesaje
- din 08 Jan 2008
bucifer85
- CristianTM
- 3,721 mesaje
- din 15 Mar 2006
- Vectra 2005 Z19DTH
- Timisoara
CristianTM
- Mesaje scrise: 3,721
- Masina: Vectra 2005 Z19DTH
gmihai1
- Mesaje scrise: 3
- Cont inregistrat: 24 Jul 2010
ma poate lamuri cineva ce este cu aceste erori ? OP-COM - KW2000 Communication Window> 2004|Meriva|Engine|Z 17 DTH
Multumesc anticipat !
P0105 - Boost Pressure Sensor Circuit Range/Performance
(0A) - Present
P0093 - Rail Pressure Range/Performance
(00) - Not present
P0105 - Boost Pressure Sensor Circuit Low Input
(02) - Not present
(0A) - Present
(00) - Not present
(02) - Not present
bugscata
- Mesaje scrise: 59
- Cont inregistrat: 10 Jan 2011
dani_ddtz
- Mesaje scrise: 85
- Masina: Astra 2008 z19dth
- Cont inregistrat: 23 Sep 2010
Salutare, am o problema pe z19dth, cand pornesc masina cam 2 km nu face deloc boost iar dupa ce trece de aceea perioada face overboost, in loc de 1.6 sare spre 2 bar ! (motorul ii remapat), ce ar putea cauza aceste simptome ?
CristianTm: Ai rezolvat ceva curatand maf senzorul ? eu am 80000 km si nu am desfacut inca acel senzor !
dani_ddtz
- Mesaje scrise: 85
parula66
- Mesaje scrise: 14
- Cont inregistrat: 29 Feb 2012
salutare tuturor!
am o problema cu o astra h motor.z19dth,
pe la 2000rpm suiera ca naiba,daca scot furtunul de vacum de pe turbo,nu mai suera.
ma gandeam la electrovalva care comanda variabilul.
vreo sugestie?cum se verifica acea electrovalva?
sau daca este vreun coleg prin timisoara sau prin zona,care are una de proba,sa nu ma apuc sa cumpar si sa nu fie aceea
cu stima
cu stima
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
parula66
- Mesaje scrise: 14
tonytm
nu cred ca e de la pale ,faza e ca urmatoarea,geometria lucreaza dar ramane trasa la maxim cand e cuplat furtunul de vacum,indiferent de turatie ,cand scot furtunul revine pe minim,ma gandeam ca nu lucra electrovalva acea,lui cristiantm nu pot sai trimit PM,vad ca imi da eroare,ai tu ceva date de contact?daca da ,te rog trimite si mie
cu stima
cu stima
parula66
- Mesaje scrise: 14
parula66
- Mesaje scrise: 14
parula66
- Mesaje scrise: 14
