danx2003
- Mesaje scrise: 13
- Masina: Vectra 2007 z30dt
- Cont inregistrat: 14 Mai 2010
Am un opel vectra c 3.0 cdti, fabricatie 2007, s-a facut update la software de catre reprezentanta, tot ok.
De ceva timp imi aparea eroarea P0093-52 "Common rail pressure is too low", motorul pornea la a 2-3-a cheie dupa care nu a mai pornit deloc. In service la rucom au pornit-o cu spray ul dupa ce au schimbat filtrul de motorina, ceea ce m-a enervat. Deasemenea in mers cand motorul este rece masina tremura, ca si cand nu ar mai avea combustibil sau nu s-ar alimenta.
As dori o parere, unde pot face curatarea pompei injectoarelor etc daca se poatre in craiova, si care ar fi cauzele?
Din ceea ce am studiat, probleme poate fi la pompa de inalta cu SCV sau ceva valve de la common rail.
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Signum 2005 Z19DTH 190CP
- Timis
tonytm
- Mesaje scrise: 4,479
danx2003
- Mesaje scrise: 13
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
Subject: Engine Y30DT, High Pressure Pump - Lack of power during acceleration
Models: Engines: Option:
Vectra-C 2003...2007,Signum 2003...2007 Y30DT| Z30DT,Y30DT| Z30DT
Complaint: Engine lack of power during acceleration. During investigation with TECH2 a pressure drop between actual rail pressure and desired rail pressure is visible.
Cause: Blocked suction control valve (SCV) within the high pressure pump.
Production: Modified production process (earlier changing of manufacturing tools, improved cleanliness) implemented at supplier. Countermeasures were implemented with engine number 69692 (01.09.2006).
Remedy:
Before carrying out Technical Service Bulletin 1957 update ECU with modified software as of TIS 2000-DVD, version 76 (a modified software regarding high pressure diagnosis was implemented, improved DTC: P0093 detection).
If the DTC still occurs refer to the following snapshots in datalist 2 "NOK I". The snapshot shows an increased fuel flow restriction within the fuel feed circuit.
1: desired fuel pressure 2: actuel fuel pressure
We recommend to disconnect the fuel lines from the tank to the filter, blow them by compressed air (in disconnected condition) and finally to replace the fuel filter assembly.
The snapshot in datalist 2 "NOK II" shows a constant drop of actual fuel pressure and identified the suction control valves (SCV) failure.
In case of an identified suction control valves (SCV) failure replace both suction control valves (SCV) of the high pressure pump as discribed below.
Important: - During the complete procedure it is obligated to work in a clean environment. - Prevent contamination at SCV area. Small contaminations, which cannot be seen by eye, can cause major problems on engine performance. Particle size of 0,3 mm, can be already critical! - Do not use gloves. - Do not use SCV in case it has been dropped. - Make sure that pressure in the system is released before loosening the pressure connection pipe between pump and rail. - Disconnect battery after failure checking procedure. Wait for a few minutes before starting SCV replacement procedure in order to prevent any system action.
Dupa cum vezi, problema cu pompa de inalta duce la lipsa de putere, vibratii si mers in suturi la aprox 1500 RPM. Asa facea si la tine?
danx2003
- Mesaje scrise: 13
am desfacut cele 2 furtunase de retur
pe returul de la pompa atunci cand dau la cheie vine foarte multa motorinaiar pe cel de la commmon rail deloc
la ECU am masurat cu op-com in timpul cat dau la cheie: Desired common rail pressure care tre sa fie 33MPA
si actuala presiune care era de 0.50 MPA cu variatii intre 0,20 si 0,60 MPA adica nu face presiune deloc in common rail
am vazut pe net la altii exact remediul de l-ai propus tu mai sus adica ca ar fi SCV (suction contorl valve)
Deasemenea poate fi valva din capatul common rail?
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
danx2003
- Mesaje scrise: 13
Nu stiu in schimb unde e localizat valava de presiune din capul common rail. e una cu niste fire la un cap iar in celalt cap al common rail e retulrul, asa cum am spus atunci cand dau la cheie nu iese motorina pe acel retur, iese numai pe returul de la pompa de inalta presiune.
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
- crystinel_oo
- 82 mesaje
- din 25 Dec 2009
- Vectra 2007 Z19DT
- Dolj
crystinel_oo
- Mesaje scrise: 82
- Masina: Vectra 2007 Z19DT
- Cont inregistrat: 25 Dec 2009
danx2003
- Mesaje scrise: 13
Problema la simptomele pe care le-am descris pare sa fie SCV , probleme prezentat si in acel remediu. Cauza si mai multe informatii am vazut pe siteul: http://www.oknation.net/blo...009/03/11/entry-3 😭
folositi http://translate.google.com pentru a intelege ceva.
danx2003
- Mesaje scrise: 13
Intra-devar probleme a fost Field Remedy: 1957
Cum verificati un asemnea motor daca nu porneste: 1. Verificati sa vedeti daca motorul trage aer cand dati la cheie. 2. Verificati codurile de eroare. 3. Cand dati la cheie verificati presiunea in rampa dorita si cea actuala cu ajutorul opcom. 4. Verificati distributia curea lant etc. Curatati instalatia de alimentare/rezervorul. 5. Cand dati la cheie deconectati retururile de la pompa si cel din capatul common rail si vedeti pe care scoate motorina. Puteti deasemnea desface un injector sa vedeti daca da motorina, dar nu are sens.
- tonytm
- 4,479 mesaje
- din 10 Oct 2007
- Timis
tonytm
danx2003
- Mesaje scrise: 13
Cipa
- Mesaje scrise: 6
- Masina: Vectra 2008 Z30DT
- Cont inregistrat: 10 Oct 2010
- ghibirdic.sorin
- 289 mesaje
- din 26 Oct 2011
- Vectra 2007 Z30DT
- Valcea
ghibirdic.sorin
- Mesaje scrise: 289
- Masina: Vectra 2007 Z30DT
- Cont inregistrat: 26 Oct 2011
danx2003
- Mesaje scrise: 13
- ghibirdic.sorin
- 289 mesaje
- din 26 Oct 2011
- Vectra 2007 Z30DT
- Valcea
ghibirdic.sorin
- skipero
- 451 mesaje
- din 13 Feb 2011
- Vectra 2007 Z30DT
- Ilfov
skipero
- Mesaje scrise: 451
- Cont inregistrat: 13 Feb 2011
- ghibirdic.sorin
- 289 mesaje
- din 26 Oct 2011
- Vectra 2007 Z30DT
- Valcea
ghibirdic.sorin
- skipero
- 451 mesaje
- din 13 Feb 2011
- Vectra 2007 Z30DT
- Ilfov
skipero
