  3. Motoare diesel
  • rebotea
  • Mesaje scrise: 28
  • Masina: Vectra OPC 2003
  • Cont inregistrat: 14 Apr 2013
hi i have a problem in the Swirl Level Control Solenoid Valve Pulse where is it located? and what can i do
Thank´s
Motor type: Y20DTH
Total number of fault codes: 2
P0195 - <Unknown DTC>
(07) - Present
P0660 - Swirl Level Control Solenoid Valve Circuit Open
(04) - Present
  • Mesaje scrise: 7,038
Welcome.
First code seems to be caused by the Engine oil temperature sensor, check the switch.
For the second code check the F 15 fuse from the engine bay. If its ok, look at the swirl actuator (back of the radiator), see if it works.
  • rebotea
  • Mesaje scrise: 28
Thank´s
it was the conector since i have only one Swirl Level Control Solenoid Valve .
is this a read only valve or a control valve.
can someone explain becau-se now it is in 4% and i dont see it moving.
Thank´s again
I think its working ok:
"Tester Display Swirl Level Control Solenoid Valve Pulse Ratio
- Engine running at idle speed, operating temperature
- All consumers turned off
- Accelerator pedal not actuated
Note:
This data list parameter is in the data list 3 .
3.5 ... 5.5 %
Accelerator pedal actuated several times
Value changing briefly "
  3. Motoare diesel
