- crisluca1985
- 116 mesaje
- din 29 Aug 2004
- Bucucresti
crisluca1985
- Mesaje scrise: 116
- Cont inregistrat: 29 Aug 2004
- MadDawg
- 101 mesaje
- din 08 Feb 2005
- Corsa 2001
MadDawg
- Mesaje scrise: 101
- Masina: Corsa 2001
- Cont inregistrat: 08 Feb 2005
TURBOCOMPRESÓR, Compresor format dintr-un stator ºi dintr-un rotor cu palete, folosit la comprimarea gazelor.
TURBOSUFLÁNTÃ, turbosuflante, s.f. Suflantã cu rotor.
De aici intelegi ce vrei... 😃.... sau....
turbocharger: An exhaust powered turbine super-charger. Turbochargers always use centrifugal-flow compressors, which operate efficiently at the high rotational speeds produced by the exhaust turbine.=blower: [1] Also called a "supercharger" or "turbocharger." This is a pump which forces air into the cylinders at higher than atmospheric pressure. The increased pressure forces more air into the cylinders than what would be drawn in normally. In this way the engine can burn more fuel and thus produce more power. There are two main types of blowers: the turbocharger, which uses some of the waste heat energy in the exhaust gases to drive a compressor and pump the air; and the belt-driven or shaft-driven supercharger which uses engine power to pump air.
Turbine: A type of engine in which all the parts that are in regular motion are rotating, making for very smooth operation. The basic gas turbine operates as follows: air enters the compressor and is compressed. It is then delivered to the combustion chamber under pressure and here the fuel is introduced, mixed with the air and burned, the quantity injected determining speed and power output. The hot, high-pressure burning gases then proceed to the first turbine, which drives the compressor, and continue to the power turbine, which delivers power to the output shaft through reduction gears. The gears are necessary because the speed of turbine rotation is measured in tens of thousands of rpm not thousands as with a typical piston engine. The turbine's attractions include its utter simplicity and directness in getting power from burning gas, its smoothness, easy cold starting and its ability to run on almost any hydrocarbon fuel. On the minus side are high cost, problems with materials because of the high temperatures and speed of rotation and relatively high NOx production.
- VectraDTI
- 685 mesaje
- din 10 Dec 2004
VectraDTI
- Mesaje scrise: 685
- Cont inregistrat: 10 Dec 2004
- crisluca1985
- 116 mesaje
- din 29 Aug 2004
- Bucucresti
crisluca1985
- Ingineru
- 1,086 mesaje
- din 24 Jun 2004
- Vectra 1998 X16XEL
Ingineru
- Mesaje scrise: 1,086
- Masina: Vectra 1998 X16XEL
1. Torbosuflanta sau turbocompresorul - este o turbina antrenata de catre gazele de ardere (evacuare) si care introduce aer fortat in motor creind o presiune mai mare decat cea rezultata prin depresiunea de la motoarele "normal aspirate".
2. Compresorul mecanic (sau Eaton sau suflanta Roots) - turbina antrenata prin curea de catre arborele cotit al motorului, avand acelasi rol.
La Opel, cel putin din cate stiu eu, apare doar prima varianta. Intercoolerul este un schimbator de caldura cu rolul de a raci aerul care intra in motor pt. o putere mai mare; nu exista obligatoriu, la Vectra B 2,0 16V Di (82 CP) de ex. nu exista.
- Slick
- 1,319 mesaje
- din 29 Apr 2004
- Astra 2004 Z20LET
Slick
- Mesaje scrise: 1,319
- Masina: Astra 2004 Z20LET
- Cont inregistrat: 29 Apr 2004
NU toate au intercooler. DTH-ul are intercooler. DTL-ul nu are intercooler... In rest tot ce e cu T are Turbo
- crisluca1985
- 116 mesaje
- din 29 Aug 2004
- Bucucresti
crisluca1985
- ToX
- 1,257 mesaje
- din 17 Mai 2004
- Astra OPC 2013 A20NFT
ToX
- Mesaje scrise: 1,257
logic, tuning romanesc. probabil ii crapase intercooleru fostului proprietar si ca sa nu mai dea banii pe altu a pus o teava
- sorin666
- 3,885 mesaje
- din 12 Mai 2004
- outside Manell's Land
sorin666
- Mesaje scrise: 3,885
- chiciuc
- 1,372 mesaje
- din 29 Apr 2004
- Vectra 1997 X20DTL
- Craiova
chiciuc
- Mesaje scrise: 1,372
- Masina: Vectra 1997 X20DTL
- roBERT
- 1,724 mesaje
- din 09 Mai 2004
- Astra 2002 Z20LET
roBERT
- Mesaje scrise: 1,724
- Masina: Astra 2002 Z20LET
- Slick
- 1,319 mesaje
- din 29 Apr 2004
- Astra 2004 Z20LET
Slick
- crisluca1985
- 116 mesaje
- din 29 Aug 2004
- Bucucresti
crisluca1985
- MadDawg
- 101 mesaje
- din 08 Feb 2005
- Corsa 2001
MadDawg
Poate ca se gasesc, dar mai trebuie si sa intelegi 😃
Rolul turbocompresorului este sa bage aer la presiune mai mare decat cel atmosferic, spre diferenta de turbosuflanta, care este antrenata de gaze iar al intercooler-ului de a racii aerul (aerul rece este mai dens) ceea ce duce la concluzia ca marind compresia in cilindrii creste puterea. Sau nu
- mirciulica
- 78 mesaje
- din 16 Feb 2005
- baia mare
mirciulica
- Mesaje scrise: 78
- Cont inregistrat: 16 Feb 2005
- crisluca1985
- 116 mesaje
- din 29 Aug 2004
- Bucucresti
crisluca1985
Deci de aici rezulta ca turbosuflanta nu este egala cu compresorul.
dap
De aici rezulta ca sunt =.
Eu ce draku sa mai cred? 😶 😶 😶 😶 😶 😶
- Slick
- 1,319 mesaje
- din 29 Apr 2004
- Astra 2004 Z20LET
Slick
compresor inseamna ceva (de obicei tot o "elice") ce baga aer cu presiune (comprima).
turbo-compresor = o turbina si un compresor. Turbina (elicea turbinei) este invartita de gazele de esapament iar la capatul celalalt al axului este compresorul (elicea compresorului) care baga are cu presiune in motor
turbo-suflanta = o turbina si o suflanta (elice) care "sufla" aer deci este acelasi lucru cu turbo-compresor.
Mercedes are doar "kompressor" unde compresorul cred ca este electric, nu este antrenat de o turbina antrenata de gazele de esapament
Sper ca am lamurit lumea..
mirciulica, uita-te sub capota, vezi in stanga fata unde e filtrul de aer, du-te pe conducta de aer in sus, ajunge in turbina (sus la jumate) si dup-aia porneste in fata inspre motor. Daca acea conducta se duce in fata spre radiator in ceva, ala e intercooler. Daca se duce direct in motor, nu ai intercooler (dupa cum banuiesc (DTL)).
- crisluca1985
- 116 mesaje
- din 29 Aug 2004
- Bucucresti
crisluca1985
- MadDawg
- 101 mesaje
- din 08 Feb 2005
- Corsa 2001
MadDawg
- Slick
- 1,319 mesaje
- din 29 Apr 2004
- Astra 2004 Z20LET
Slick
