- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
- Mesaje scrise: 885
- Masina: Omega 2001 Y22DTH
- deleted-11331
- 768 mesaje
- din 03 Nov 2007
deleted-11331
- Mesaje scrise: 768
- Cont inregistrat: 03 Nov 2007
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- Mesaje scrise: 765
- Cont inregistrat: 28 Sep 2006
- deleted-11331
- 768 mesaje
- din 03 Nov 2007
deleted-11331
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- deleted-11331
- 768 mesaje
- din 03 Nov 2007
deleted-11331
boditza a scris:pai erau deconectate sau cum? inversate? chiar nu inteleg si imi cer scuze daca te deranjeaza ca intreb
nu ma deranjeaza deloc, pt asta e forumul, erau inversate, mufele fiind identice ! iar a 3desi se potrivea la conectori cu electrovalva in cauza nu era de acolo, nu avea acelasi invelis( poate doar la mine...) insa sa vad ce e si cu celelalta mufa care e identica cu cea de la electrovalva dar care nu e pt electrovalva, deoarece inca primesc 2-3 mesaje de eroare pe Mid cand pornesc potorul, am sa fac poze azi dupa ce ma trezesc...
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- cangri
- 5,415 mesaje
- din 24 Sep 2010
cangri
- Mesaje scrise: 5,415
P1590 - Audi Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
Description
AC/heater air temperature control switch - open circuit
Cause
Wiring open circuit, AC/heater air temperature control switch
P1590 - Land Rover Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
Description
Antilock brake system (ABS) rough road signal - error message from ABS control unit
Cause
Wiring, ABS system
P1590 - Subaru Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
Description
Park neutral position (PNP) switch - voltage high
Cause
Wiring, PNP switch, ECM
P1590 - Volkswagen Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
Description
Cause
Nu am gasit nimic pentru Opel sau G.M.
Description
Cause
Description
Cause
Wiring, ABS system
Description
Cause
Description
Cause
- deleted-11331
- 768 mesaje
- din 03 Nov 2007
deleted-11331
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
ala cu frana imi apare si mie sa verifice daca merge stopul pe frana.. coolant level este defect senzorul din vas, presupunand ca ai nivelul cum trebuie iar la brake pad eu am taiat senzorul si am lipit firele intre ele ca erau mai scumpe cu 60-70 ron placutele cu senzor plus senzorul, si am considerat ca e prea mult
- deleted-11331
- 768 mesaje
- din 03 Nov 2007
deleted-11331
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
mr_blondu
- Mesaje scrise: 12
- Masina: Vectra 2001 Y22DTR
- Cont inregistrat: 04 Nov 2008
salut ,cine are idee ce semnifica cod eroare P1590-004.I-am facut testarea cu un tester cumparat din spania si la codul asta de eroare imi zice ENTRACIA BAJA DE LA SEÑAL DE FUNCIONAMENTO DEL MOTOR.(care tradus ar insemna INTRARE SEMNAL REDUS PENTRU FUNCTIONAREA MOTORULUI)mentionez ca atunci cind pornesc masina dimineata (un opel vectra b y2.2 dtr) porneste dupa foarte multe incercari,iar cind a pornit o perioada functioneaza in 3 pistoane scotind foarte mult fum,aproximativ un minut,apoi merge perfect)iar pe tester asta este singura eroare data care si ramane permanenta.
- iulian1971
- 7,081 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,081
- Masina: Astra 2008 Z19DTH
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
- iulian1971
- 7,081 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
- iulian1971
- 7,081 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- secarianu
- 885 mesaje
- din 13 Mar 2007
- Omega 2001 Y22DTH
secarianu
bosty80
- Mesaje scrise: 6
- Masina: Vectra 2001 Y20dth
- Cont inregistrat: 08 Jun 2016
Buna seara, la Vectra mea B cu motor Y20dth, de cateva zile, dupa pornire la cateva secunde se aprinde martor CheckEngine si nu mai trage...dupa ce ajungi cu a 1-a si apoi cu a 2-a pe la 2.500 rpm, se stinge si apoi trage bine, cand ajung la semafor si deci si la relanti iar se aprinde martorul...am facut o diagnoza si imi apare cod P1590...ma poate ajuta cineva?
