- comnic5
- 193 mesaje
- din 27 Jul 2006
- Omega 2001 y22dth
- Spania
comnic5
- Mesaje scrise: 193
- Masina: Omega 2001 y22dth
- Cont inregistrat: 27 Jul 2006
Dragi colegi opelisti,
Vin cu urmatoarea problema: De curand am cumparat un Astra H Z17DTH facut terci de un taran obosit din Spania. Masina are interiorul facut varza (tunning) dar problema reala e ca nu porneste.
Cand am cumparat-o am pus un tester cu bluetooth si Torque si mi-a dat urmatoarele erori:
-p0560
-p0100
-p1125
-p0500
-u2108
-p0650
-p0606
Asta a fost cu torque pe telefon. Le-am sters si am incercat sa pornesc. Dupa cateva incercari am lasat-o si mi-am pus OP-COM-ul la treaba.
Dupa cateva incercari de a o porni am scanat toata masina cu OP-COM si mi-a intors alte erori:
Pe modulul MOTOR:
P0070 - Ambient Air Temperature Sensor Error
(71) - Not present
P0500 - Vehicle Speed Signal Range/Performance
(74) - Not present
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(7F) - Not present
(70) - Not present
Pe modulul CIM:
B1012 - Steering Angle Sensor Not Calibrated
(00) - Present
Pe modulul Immobilizer:
(00) - Present
Pe modulul Instrument Control Unit:
B2652 - Instrument Dimming LED Output Circuit High Voltage
(01) - Present
Pe modulul ABS/ESP:
U2143 - CAN-Bus No Communication with SAS (Steering Angle Sensor)
(00) - Not present
C0460 - Steering Angle Sensor not Calibrated
(4B) - Present
C0460 - Steering Angle Sensor Signal Circuit Range/Performance
(5A) - Present
Pe modulul Electrohydraulic Power Steering:
U2139 - CAN-Bus ECM Message Range/Performance
(70) - Present
(00) - Not present
Cam astea ar fi toate cu OPCOM. Ceva idei?
-p0560
-p0100
-p1125
-p0500
-u2108
-p0650
-p0606
Pe modulul MOTOR:
(71) - Not present
(74) - Not present
(7F) - Not present
(70) - Not present
Pe modulul CIM:
(00) - Present
(00) - Present
(01) - Present
Pe modulul ABS/ESP:
(00) - Not present
(4B) - Present
(5A) - Present
(70) - Present
(00) - Not present
- comnic5
- 193 mesaje
- din 27 Jul 2006
- Omega 2001 y22dth
- Spania
comnic5
- Dariescu Claudiu
- 692 mesaje
- din 30 Jun 2008
- Astra 2003 Z18xe
Dariescu Claudiu
- Mesaje scrise: 692
- Masina: Astra 2003 Z18xe
- Cont inregistrat: 30 Jun 2008
- comnic5
- 193 mesaje
- din 27 Jul 2006
- Omega 2001 y22dth
- Spania
comnic5
- tase
- 1,985 mesaje
- din 29 Sep 2009
- Vectra 2006 z19dt
- Ilfov
tase
- Mesaje scrise: 1,985
- Masina: Vectra 2006 z19dt
- Cont inregistrat: 29 Sep 2009
