  • mihailescu_e
  • Mesaje scrise: 21
  • Masina: Vectra 2004
  • Cont inregistrat: 17 Oct 2006
Am ajuns cu masina in fata blocului am urcat si cand am coborat sa plec nu a mai pornit, demarorul se invarte, motorina am, mi-a pus cineva un tester si am primit eroarea P0620 (Generator Control Circuit Malfunction ) ma puteti ajuta cu semnificatioa acestui cod de eroare, este vorba de un Vectra C 2004 diesel 2.2 hidramat.
  • ianc sergiu
  • Mesaje scrise: 451
  • Masina: Vectra 2004 z19dth
  • Cont inregistrat: 08 Feb 2010
Eroarea asta se refera la alternator....de el trebuie sa te legi cand incepi sa cauti problema.
  • cangri
  • Mesaje scrise: 5,296
P0620 - GM Type Powertrain - Computer and Auxiliary Outputs - ISO/SAE Controlled
Description
Generator Performance Conditions
Cause
Engine speed below 1000 rpm (low duty cycle test) or over 1300 rpm (high duty cycle test), Voltage Telltale lamp "on", then the PCM detected the 'L' terminal voltage was in a low state after commanding the generator on (condition met for 10 seconds) or that the 'F1 terminal PWM was less than 10% for 30 seconds, or the 'F' terminal was more than 95% for 60 seconds
  • mihailescu_e
  • Mesaje scrise: 21
Va multumesc ! La alternator a fost problema, am rezolvat-o .
  • Petronel Hrubaru
  • Mesaje scrise: 250
  • Masina: Vectra 2003 Y20DTH
  • Cont inregistrat: 08 Mai 2013
Care a fost mai exact problema!? Cum ai rezolvat-o? Ne poti spune si noua?
  • RLuca
  • Cont inregistrat: 19 Apr 2021
Sal. Oare ce problema ai avut la alternator oare
