johnnytl
- Mesaje scrise: 13
- Masina: Astra 2004 Z17DTL
- Cont inregistrat: 10 Jul 2012
Am nevoie de un pic de ajutor din partea celor care au intalnit aceasta problema.
Va multumesc anticipat.
Masina porneste bine, trage nu da nici un simptom de defectiune, am schimbat injectoarele, am curatat EGR, clapeta de acceleratie, am schimbat cureaua de distributie, am verificat parametri pe tester si sunt ok... dar masina consuma 7.6l/100km in afara orasului.
Va rog ceva sfaturi.
Daca aveti nevoie de parametri ii pot scoate imediat.
Va multumesc
Model: Astra G
An fabricatie: 2004
Cod motor: Z17DTL
- nicusan75
- 149 mesaje
- din 09 Jan 2009
- Astra 2004 G Z17DTL
- Buzau
nicusan75
- Mesaje scrise: 149
- Masina: Astra 2004 G Z17DTL
- Cont inregistrat: 09 Jan 2009
johnnytl
- Mesaje scrise: 13
Battery Voltage,14.0 V
Ignition Status,On 12V
APP Sensor 1 (Accelerator Pedal Position),0 %
APP Sensor 1 (Accelerator Pedal Position),0.97 V
APP Sensor 2 (Accelerator Pedal Position),0 %
APP Sensor 2 (Accelerator Pedal Position),0.49 V
Barometric Pressure,101 kPa
Barometric Pressure,4.00 V
Boost Pressure Command,99 kPa
Boost Pressure,100 kPa
Boost Pressure,1.87 V
Mass Air Flow Sensor,410 mg/strk
Mass Air Flow Sensor,2.02 V
Intake Air Temperature,15 °C
Intake Air Temperature,3.11 V
Coolant Temperature,39 °C
Coolant Temperature,2.52 V
Desired Common Rail Fuel Pressure,24.00 MPa
Common Rail Fuel Pressure,24.42 MPa
Common Rail Fuel Pressure,1.04 V
Rail Pressure Control Valve Pulse Ratio,339 %
Engine Speed,900 RPM
Desired Injection Quantity,7.8 mm3
Actual Injection Quantity,7.8 mm3
Injection Pulse,1.2 ms
Pilot Injection Time,0.7 ms
Brake Switch 1,Inactive
Brake Switch 2,Inactive
Clutch Switch,Inactive
Throttle Position Switch,Active
Pulse Ratio Throttle Control Solenoid Valve,13 %
Pulse Ratio Boost Pressure Solenoid Valve,95.0 %
Swirl Plate Position Switch,Active
Swirl Level Control Solenoid Valve Pulse Ratio,90.0 %
EGR Position Feedback (Exhaust Gas Recirculation),0.2 %
EGR Position Feedback (Exhaust Gas Recirculation),0.95 V
EGR Pulse Ratio (Exhaust Gas Recirculation),90 %
Capacitor Voltage 1,826.4 V
A/C Information Switch (Air Conditioning),Active
A/C Relay (Air Conditioning),Active
A/C Pressure (Air Conditioning),408 kPa
Fan Relay 1,Inactive
Fan Relay 2,Inactive
Glow Time Relay,Active
Diagnosis Glow Time Relay,Inactive
Glow Time Telltale,Off
Service Vehicle Soon (SVS) Indicator,Off
Malfunction Indicator (MI),Off
Cruise Control Tip Switch,Inactive
Vehicle Speed,0 km/h
Immobiliser Function Programmed,Yes
Security Wait Time,Inactive
- svasile
- 1,693 mesaje
- din 14 Oct 2014
- Astra 2006 Z13DTH
- Covasna
svasile
- Mesaje scrise: 1,693
- Masina: Astra 2006 Z13DTH
- nicusan75
- 149 mesaje
- din 09 Jan 2009
- Buzau
nicusan75
- peski
- 311 mesaje
- din 18 Mai 2015
- Signum 2005 Z19DTH
- Bihor
peski
- Mesaje scrise: 311
- Masina: Signum 2005 Z19DTH
- Cont inregistrat: 18 Mai 2015
johnnytl
- Mesaje scrise: 13
- peski
- 311 mesaje
- din 18 Mai 2015
- Bihor
peski
johnnytl
- Mesaje scrise: 13
- peski
- 311 mesaje
- din 18 Mai 2015
- Bihor
peski
johnnytl
- Mesaje scrise: 13
- peski
- 311 mesaje
- din 18 Mai 2015
- Bihor
peski
- Adrian Cosma
- 254 mesaje
- din 07 Aug 2012
- Astra 2003 Y17DT
Adrian Cosma
- Mesaje scrise: 254
- Masina: Astra 2003 Y17DT
- Cont inregistrat: 07 Aug 2012
DiplomaT
- Mesaje scrise: 56
- Masina: Corsa 2005 Z13DT
- Cont inregistrat: 23 Jan 2015
- peski
- 311 mesaje
- din 18 Mai 2015
- Bihor
peski
DiplomaT
- Mesaje scrise: 56
- peski
- 311 mesaje
- din 18 Mai 2015
- Bihor
peski
- Adrian Cosma
- 254 mesaje
- din 07 Aug 2012
- Astra 2003 Y17DT
Adrian Cosma
- ahappyuser
- 6,794 mesaje
- din 05 Apr 2010
- Astra 2005 Z17DTH
ahappyuser
- Mesaje scrise: 6,794
- Masina: Astra 2005 Z17DTH
Am curatat admisia si EGR-ul la Astra G cu Z17DTL... dar la ce volum de munca a fost chiar n-am mai avut curiozitatea sa vad daca clapetele imi functioneaza. M-am bucurat ca motorul a plecat imediat si a disparut fumul... asa ca am presupus ca valva de vacum lucreaza corect si inchide (sau deschide?) clapetele din admisie la momentul cand e nevoie de ele. Daca stie cineva -la concret- cum testez cu masina in stationare si motorul pornit daca imi lucreaza electrovalva de vacum care comanda clapetele il rog sa detalieze aici in topic.
Cu Stima.
