  3. Vectra B
  • peeter595
  • Mesaje scrise: 10
  • Masina: Vectra 1997
  • Cont inregistrat: 08 Feb 2017
aici am datele in urma testarii cu opcom
OP-COM 100219a - PC based diagnostic tool
Date and time>,07/02/2017. 21:2744
Workshop information:
Selected model>,1997 (V),Vectra-B,Engine,X 16 XEL
Control Unit:
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L000038V5101843
RepairShopCodeOrTesterSerialNumber: Not programmed
ProgrammingDate: FFFFFFFF
systemSupplierECUHardwareNumber: 16202280
vehicleManufacturerECUHardwareNumber 16202319 NL
systemSupplierECUSoftwareNumber: BZKU
systemSupplierECUSoftwareVersionNumber: 0004
exhaustRegulationOrTypeApprovalNumber: D96003
systemNameOrEngineType: X16XEL
Identifier: 0102
Measuring blocks information:
System Voltage,14.4 V
Immobiliser,Active
Immobiliser Signal,Received
Fuel Pump Relay,Active 0V
TPS Signal (Throttle Position Sensor),0 %
TPS Signal (Throttle Position Sensor),0.57 V
MAP Sensor (Manifold Absolute Pressure),0.36 bar
MAP Sensor (Manifold Absolute Pressure),1.73 V
Coolant Temperature,84 °C
Coolant Temperature,2.20 V
Intake Air Temperature,-40 °C
Intake Air Temperature,4.97 V
Transmission Coding,Manual Transmission
Park/Neutral Switch,R-D-3-2-1 12V
A/C Information Switch,Inactive 0V
A/C Load Signal (Air Conditioning),Inactive 0V
Injection Pulse,6.3 ms
Clear Flood Mode,Inactive
Spark Angle before TDC (Top Dead Centre),10 °CA
Knock Cell Number,10
Cyl.1 Knock Retard,0 °CA
Cyl.2 Knock Retard,0 °CA
Cyl.3 Knock Retard,5 °CA
Cyl.4 Knock Retard,0 °CA
Secondary Air Pump Relay,Inactive
Air Control Solenoid,Inactive
EGR Position Command (Exhaust- Gas Recirculation),0 %
EGR Position Feedback (Exhaust Gas Recirculation),0 %
Fuel Tank Ventilation Valve,0 %
O2 Sensor,119 mV
Air/Fuel Ratio,14.6
O2 Sensor Loop,Open
Air/Fuel Status,Lean
O2 Integrator,180 Steps
O2-Loop BLM Enable (Block Learn Map),Active
O2 BLM Cell Number (Block Learn Multiplier),18
O2 BLM Cell Content (Block Learn Multiplier),150
Engine Speed,850 RPM
IAC Control Enable (Idle Air Control),Active
Idle Air Control,44 Steps
Desired Idle P-N,900 RPM
Idle Adjust P-N,Not Modified
Desired Idle Drive (R-D-3-2-1),850 RPM
Idle Adjust Drive (R-D-3-2-1),Not Modified
Desired Engine Idle Speed,850 RPM
Idle Adjust,Not Modified
Engine Load,9 %
Torque Control,Inactive
A/C Relay (Air Conditioning),Inactive 12V
Air Conditioning,Not Present
Vehicle Speed Pulse,Not Received
Vehicle Speed,0 km/h
Telltale (Check Light),On 0V
Blink Code Request,Inactive 12V
Dec. Fuel Cutoff (Deceleration),Inactive
Full Load Enrichment,Inactive
  • peeter595
  • Mesaje scrise: 10
sa fi umblat cineva in ecu? masina e cumparata de curand are toba sport si cred ca si ambreiajul e sport
  • voicu petre
  • Cont inregistrat: 13 Aug 2015
salut si LA MULTI ANI....am un opel v b 1,6 16 v din 97si il pornesc....merge ok...dupa un timp cand se incalzeste incepe sa balbae sa mearga in 3 bujii cand il accelerez si consuma benzina ...scoate fum de parca nu ar reveni socul automat ...cred ca ramane blocat.am schimbat senzorul de la apa dar tot la fel merge ma poate ajuta cineva...mai poate fi si altceva?........va multumesc anticipat
  • corsa.timis
  • Mesaje scrise: 490
  • Masina: Corsa 2001 Z12XE
  • Cont inregistrat: 29 Dec 2014
Regulatorul de benzina, scoate furtunul de vacuum si vezi daca are benzina in el.
Neaparat trebuie cititi parametrii de functionare, fara ei ceri mult prea mult.. cei care iti dau "solutii" fara o analiza sunt simplii pareristi care te vor face sa schimbi piese degeaba.
  • raz40
  • Mesaje scrise: 71
  • Masina: Vectra 2001 Z16XE
  • Cont inregistrat: 14 Nov 2016
Eu la Vectra B 1.6. 16V 2001, am mers cu 22 litri - 400 km. Nu am depãșit 110 km/h.
  3. Vectra B
